Strange readings on a Qubino 3-phase Smart meter
Arjan444
Post by Arjan444 »
I have installed a Qubino 3-phase Smart meter (ZMNHXDx).
It is linked via aeotec Z-wave stick to a RPI (OpenZwave) running the latest stable version of Domoticz (4.10717)
The Qubino is being polled every 60 seconds.
The 3-phases all feed into an EV Charging point.
When there's no car charging the charging point is still using around 6 Watt.
I have to questions (see graph):
1) How can it be explained I get 'zero' readings (instead of the 6 Watt) once every hour or so?
2) Why does Domoticz report a 100 Wh energy usage a view times a day (while there is nothing charging).
Is this Domoticz misinterpreting Qubino data?
Is it a Qubino misreading?
Has it something todo with polling?
Hope someone had solved/explained this problem...
Thank you very much!
Best, Arjan444
Arjan444
Re: Strange readings on a Qubino 3-phase Smart meter
Post by Arjan444 »
Hello
Turned out I was looking at the kVAh value that ended up in the KWh meter field.
That explained the slightly higher values.
I did some more research and testing.
I also upgraded Domoticz to the latest beta (4.11786)
That made the problem even more interesting because now there are 6 values written to the same field with the name ‘kWh meter’.
These 6 values all cary the label 'Total Readings Electric’.
Only the last one (this time it is 'kVarh') ends up in Domoticz.
All other 5 values are there for a split second before they are overwritten.
The first one of the 6 'Total Readings Electric’ is the actual kWh value.
That’s the one that should end up (and stay) in the kWh meter field.
I only need the kWh value.
Am not sure if this is a Openzwave of Domoticz problem.
Can I somehow change a config file or a script to stop reading the other values?
Or is there another way to get the right kWh value on the Domoticz dashboard?
Hope someone can help.
Thanks. Arjan444
sbjbjoer
Post by sbjbjoer »
I have similar issue readings changing
And total reding not correct or 0 all the time tryed a lot of settings not stable or correct in history log ither
Enybody knows witch readings or diwices that works
I am comfused wat actual works
