I was looking at the following dimmes, is there any experience with these or others? (I am using the cc2531 gateway stick)
- https://www.aliexpress.com/item/1005002164359835.html
- https://www.aliexpress.com/item/1005001599812277.html
- https://www.leddirect.nl/yphix-draadloz ... igbee-230v
- https://www.ecobright.nl/led-dimmer/zig ... dule-250w/
- https://www.beaumotica.nl/icasa-iczb-iw ... 1257407014
- https://www.amazon.nl/iolloi-inbouwdimm ... B08FLD1SK4
are there any with positive results?
thanks
Which dimmers are supported by Domoticz and zigbee2mqtt?
Re: Which dimmers are supported by Domoticz and zigbee2mqtt?
Did you search (Ctrl-F) on this page for "dimmer"? https://www.zigbee2mqtt.io/information/ ... vices.html
gert3d
- Domoticz version: 20202
Yes did, the ones I mentioned are not listed.
New question: does listing in the devices list that they will - by definition - be operating in Domoticz with no problem?
The Ledvance Plug can also be added to the suppoted devices list:
https://www.bol.com/nl/p/ledvance-smart ... 123968484/
Yes, with the exception that on newly added devices there could be some problems, but mostly they are tackled soon.gert3d wrote: Monday 22 March 2021 12:10 Yes did, the ones I mentioned are not listed.
That is an Osram plug and is already mentioned. https://www.zigbee2mqtt.io/devices/AB32 ... b3257001njThe Ledvance Plug can also be added to the suppoted devices list:
A lot, and I mean a lot, are just rebranded items.
MikeF
- Domoticz version: V2022.2
I use this one: Aurora Lighting AU-A1ZB2WDM, which is a module which fits behind a faceplate, and turns an existing 'dumb' dimmer into a smart one. It is supported by zigbee2mqtt and recognised by the Domoticz plugin.
Available through electrical suppliers (in UK, at least).
- 33D75D1C-05B1-4BE1-AFD4-07BDF7570F26.jpeg (13.6 KiB) Viewed 1209 times
Cyroq
I'm using the Ecobright (model Eco-Dim.07) with a cc2652R stick and it works flawlessly. I assume the Eco-Dim.10 will work as well.
