Which dimmers are supported by Domoticz and zigbee2mqtt?
gert3d
Domoticz version: 20202
Post by gert3d »
EddyG
Re: Which dimmers are supported by Domoticz and zigbee2mqtt?
Post by EddyG »
Did you search (Ctrl-F) on this page for "dimmer"? https://www.zigbee2mqtt.io/information/ ... vices.html
gert3d
Post by gert3d »
Yes did, the ones I mentioned are not listed.
New question: does listing in the devices list that they will - by definition - be operating in Domoticz with no problem?
The Ledvance Plug can also be added to the suppoted devices list:
https://www.bol.com/nl/p/ledvance-smart ... 123968484/
EddyG
Post by EddyG »
gert3d wrote: Monday 22 March 2021 12:10 Yes did, the ones I mentioned are not listed.
Yes, with the exception that on newly added devices there could be some problems, but mostly they are tackled soon.
That is an Osram plug and is already mentioned. https://www.zigbee2mqtt.io/devices/AB32 ... b3257001nj
A lot, and I mean a lot, are just rebranded items.
MikeF
Domoticz version: V2022.2
Post by MikeF »
I use this one: Aurora Lighting AU-A1ZB2WDM, which is a module which fits behind a faceplate, and turns an existing 'dumb' dimmer into a smart one. It is supported by zigbee2mqtt and recognised by the Domoticz plugin.
Available through electrical suppliers (in UK, at least).
Cyroq
Post by Cyroq »
I'm using the Ecobright (model Eco-Dim.07) with a cc2652R stick and it works flawlessly. I assume the Eco-Dim.10 will work as well.
