Dashticz v3.7.6 beta
Lokonli
Post by Lokonli »
I've just releases Dashticz v3.7.6 beta
It mainly contains dial related changes.
You can now add multiple values to most dial types.
or, add a needle representing the value of another device to for instance a dial switch :
blocks['sw1'] = {
  idx: 1056,
  type:'dial',
  values: [
      idx: 1057,
      isNeedle: true
  width: 6,
  showring: true,
  shownumbers: true,
  min: 0,
  max: 10
or, show multiple values of a P1 meter:
blocks['p1counters'] = {
    type: 'dial',
    idx: 43,
    values: [
        value: 'Data0',
        unit: 'kWh',
        label: 't1',
        scale: 0.001
        value: 'Data1',
        unit: 'kWh',
        label: 't2',
        scale: 0.001
        value: 'Data2',
        unit: 'kWh',
        label: 'ret t1',
        scale: 0.001
        value: 'Data3',
        unit: 'kWh',
        label: 'ret t2',
        scale: 0.001
    showvalue: false,
    animation: false,
    shownumbers: true,
    fixed: true,
    width: 6
More info in the release notes:
https://dashticz.readthedocs.io/en/beta ... -12-3-2021
If you're using dial values already, don't forget to read the upgrade instructions:
https://dashticz.readthedocs.io/en/beta ... /v376.html
Krenstik
Re: Dashticz v3.7.6 beta
Post by Krenstik »
NIce, but most of the ikons extend size.. :-)
So change something in css.? or?
Snímek obrazovky 2021-03-12 200203.jpg (196.78 KiB) Viewed 1868 times
Lokonli
Post by Lokonli »
Krenstik wrote: Friday 12 March 2021 20:02 NIce, but most of the ikons extend size.. :-)
I made indeed quite some changes to the css files.
I'll check what creates bigger icons.
Lokonli
Post by Lokonli »
I can't reproduce the issue.
Can it be that you change the icon sizes in your custom.css?
Krenstik
Post by Krenstik »
Yes, I change the size for battery status.... But I don not remember how :-D
As I try in this "test" version all changes, I can´t recognize what is still necessary and what not. Only I can say, in the last beta was all fine.
.block_25 .on { color: #06FE17;}
.block_25 .off { color: #FEFEFE;}
.block_29 .on { color: #06FE17;}
.block_29 .off { color: #FEFEFE;}
.block_13 .on { color: #06FE17;}
.block_13 .off { color: #FEFEFE;}
.block_10 .on { color: #06FE17;}
.block_10 .off { color: #FEFEFE;}
.block_8 .on { color: #06FE17;}
.block_8 .off { color: #FEFEFE;}
.block_14 .on { color: #06FE17;}
.block_14 .off { color: #FEFEFE;}
.block_16 .on { color: #06FE17;}
.block_16 .off { color: #FEFEFE;}
.block_17 .on { color: #06FE17;}
.block_17 .off { color: #FEFEFE;}
.block_154 .on { color: #06FE17;}
.block_154 .off { color: #FEFEFE;}
.block_147_1 .on { color: #06FE17;}
.block_147_1 .off { color: #FEFEFE;}
.block_134 .on { color: #06FE17;}
.block_134 .off { color: #FEFEFE;}
.graph_header {  display: none;}
.graph_title {  display: none;}
.graphclose { display: none; }
.fa-temperature-low {color:blue !important;}
.fa-temperature-high {color:red !important;}
// zvetseni ikony
.warning {   background: rgba(199,44,44,0.3) !important;    background-clip: padding-box;}
.block_147_1 {     color:red !important; }
.warningblue {   background: rgba(45,119,204,0.3) !important;    background-clip: padding-box;}
.lastupdate.lu_warningred {	color: red !important;}
.far.fa-border-all:before {  font-size: 44px;}
.fas.fa-border-all::before { font-size: 44px;}
.fas.fa-cloud-sun:before {  font-size: 30px;}
.far.fa-cloud-sun:before {  font-size: 30px;}
.far.fa-door-closed:before {  font-size: 44px;}
.fas.fa-door-closed:before { font-size: 44px;}
.far.fa-door-open:before {  font-size: 44px;}
.fas.fa-door-open:before { font-size: 44px;}
.block_44 {font-size: 24px; !important;}
.block_44 .icon {width: 300px;  height: auto;}
.block_16.icon { height: 70px !important; }
.clock {font-size: 150px ;}
.weekday,.date {font-size: 30px !important;}
.sunset {font-size: 30px; !important;}
.sunrise {font-size: 25px; !important;}
.sunset .icon {width: 300%;  height: auto;}
.wi-sunrise	{ color: yellow;!important;}
.wi-sunset	{ color: indigo; !important;}
.far,.fas,.wi {   font-size:24px !important;}
// termostaty bez popisu
.block_130 .icon {   font-size: 44px;   height: auto;}
.block_130 .title,das
.block_130 br:nth-child(2) {      display: none;}
.block_130 .col-data select {   font-size: 150%;   width: 100%;   background-color: rgb(242,242,242);}
.block_131 .icon {   width: 85%;   height: auto;}
.block_131 .title,das
.block_131 br:nth-child(2) {      display: none;}
.block_131 .col-data select {   font-size: 150%;   width: 100%;   background-color: rgb(242,242,242);}
.block_132 .icon {   width: 85%;   height: auto;}
.block_132 .title,das
.block_132 br:nth-child(2) {      display: none;}
.block_132 .col-data select {   font-size: 150%;   width: 100%;   background-color: rgb(242,242,242);}
.block_133 .icon {   width: 85%;   height: auto;}
.block_133 .title,das
.block_133 br:nth-child(2) {      display: none;}
.block_133 .col-data select {   font-size: 150%;   width: 100%;   background-color: rgb(242,242,242);}
.block_134 .icon {   width: 85%;   height: auto;}
.block_134 .title,das
.block_134 br:nth-child(2) {      display: none;}
.block_134 .col-data select {   font-size: 150%;   width: 100%;   background-color: rgb(242,242,242);}
/* DOTS BELOW SCREEN SWITCH SCREENS */
.swiper-pagination-bullet {background: #c7c7c7; width: 30px !important; height: 30px !important; float:centre; position:relative; right:35px;}
.transbg.col-xs-1,
.transbg.col-xs-2,
.transbg.col-xs-3,
.transbg.col-xs-4,
.transbg.col-xs-5,
.transbg.col-xs-6,
.transbg.col-xs-7,
.transbg.col-xs-8,
.transbg.col-xs-9,
.transbg.col-xs-10,
.transbg.col-xs-11,
.transbg.col-xs-12 {
	padding-top:15px;
	padding-bottom:15px;
	border: 2px solid rgba(255,255,255,0);		/* border: 7px -> 3px - Smaller space between blocks */
	background: rgba(0,0,0,0.2);
	border-radius: 16px;
/code]
Krenstik
Post by Krenstik »
I get it:
madpatrick
Domoticz version: 2025.2
Post by madpatrick »
I did the update, but the icons are now off centre.
They are shifted a liitle bit to the left
Lokonli
Post by Lokonli »
Krenstik wrote: Friday 12 March 2021 22:32 I get it:
That line indeed sets the icon size to a fixed value. The !important addition makes it overrrule other settings.
The dials are responsive: they scale according the dial width. So, setting it to a fixed value is not a good idea (in general).
It might already be sufficient to remove the !important part. If for the dial, or for other blocks, the icon size is not what you expect, please post an example.
If you want to change the icon size specifically for dials, you could add '.dial' in front, like:
.dial .far,.dial .fas,.dial .wi { font-size: 150%}
or if you want to change the icon size for regular Domoticz blocks, add .mh in front, like:
.mh .far,.mh .fas,.mh .wi { font-size: 24px}
In both cases you might have to add !important. You've to experiment a bit.
Krenstik
Post by Krenstik »
I remove it, as is not nessesary and is fine ;-)
NOw I have to clean values, to have not a double value.
Snímek obrazovky 2021-03-12 232553.jpg (161.91 KiB) Viewed 1838 times
Lokonli
Post by Lokonli »
I made some small styling changes. Please pull latest beta version. (the unit behind the main value will become a bit smaller)
Krenstik
Post by Krenstik »
two questions:
How I can get two (three) lines on dial? Always two lines? Like in dial "odber /409 Watt" In the case of the dial " Pracovna" with CO2 (ppm), if the text is shorter, It mixes it two status.
Can I add spares between value and unit in dial " Odber"? (277Watt)
Thank you.
Snímek obrazovky 2021-03-13 032531.jpg (94.86 KiB) Viewed 1820 times
Lokonli
Post by Lokonli »
Krenstik wrote: Saturday 13 March 2021 3:32
Add the following to the item definition in the values part, to give the item the full width:
  addClass: 'w100'
I've increased the left margin of the unit a little bit in latest beta. Sufficient?
Krenstik
Post by Krenstik »
Lines - much better, great.
I do not see a big change, but I can say enough.
Is any way how to put in dial sunrise and sunset?
and also, manual for non-programming guys, how to change the color of status for example of ppm in my case? Or any kind of value in dials?
Thank you.
{ value: 'Quality',label:'status', type: 'text', idx: 43 ,addClass: 'w100'      },
Snímek obrazovky 2021-03-13 100020.jpg (74.28 KiB) Viewed 1792 times
pvklink
Domoticz version: latest b
Post by pvklink »
I got a little issue.
I use a dimmer switch to manage the volume of my alarm (devices), off, on with volume x-y.
I made a dial for this switch.
When i turn the volume to 0 (i use zero for off) then domoticz gives a value 1 (so not off in my case)
blocks['volume']	= {
	title: 'Volume',
	idx:	2272,
	values:	[
		idx: 2272,
		decimals: 0,
		setpoint: 60,
		isSetpoint: true
	layout: 1,
	type: 'dial',
        color: 'white',
	width: 3,
//	icon: '',
	hide_data: false,
	switch: false,
        min: 0,
        max: 100,
        showring: true,
        showunit: true,
	decimals: 0,
	animation: true,
//	fixed: true,
        shownumbers: true,
        last_update: true}
Jablotron connection, Ikea
Lokonli
Post by Lokonli »
Krenstik wrote: Saturday 13 March 2021 10:02 and also, manual for non-programming guys, how to change the color of status for example of ppm in my case? Or any kind of value in dials?
Thank you.
There are a few steps:
1) Add the right device status
You can use the recently added device hook functionality. You have to do some programming...
Add the following to custom.js:
function deviceHook(device) {
    if (device.idx==43) {  //Check that device 43 is indeed the correct Domoticz device id
        var ppmvalue = parseFloat(device.Data);
        device.deviceStatus = ppmvalue> 500 ? 'bad':'good';
In this example the deviceStatus will be labeled 'bad' or 'good', depending on the ppm value.
The deviceStatus will be added as CSS class name to the dial values that use this device.
2) Set the styling in custom.css
.item.bad {
  color: 'red' !important
.item.good {
   color: 'green' !important
Lokonli
Post by Lokonli »
madpatrick wrote: Friday 12 March 2021 22:59 I did the update, but the icons are now off centre.
Can you add a picture?
No things that could influence this in your custom.css?
Lokonli
Post by Lokonli »
pvklink wrote: Monday 15 March 2021 18:33 I got a little issue.
	title: 'Volume',
	idx:	2272,
	values:	[
		idx: 2272,
		decimals: 0,
		setpoint: 60,
		isSetpoint: true
	layout: 1,
	type: 'dial',
        color: 'white',
	width: 3,
//	icon: '',
	hide_data: false,
	switch: false,
        min: 0,
        max: 100,
        showring: true,
        showunit: true,
	decimals: 0,
	animation: true,
//	fixed: true,
        shownumbers: true,
        last_update: true}
Should work better now. Can you test latest beta?
Chris12
Domoticz version: 2021.1
Post by Chris12 »
Lokonli wrote: Monday 15 March 2021 21:19
.item.bad {
.item.good {
Does this work for Dials with text values shown as well?
I have a dial basically showing me the status of my RPi Active/inactive using Monit, on that RPi I run Pihole.
So it would be great if I can see if the status is OK (Active) or Not OK (Inactive)
I tried this custom.js code:
    if (device.idx==1032) {  //Domoticz device ID
        var rpiactive = parseFloat(device.Data);
        device.deviceStatus = rpiactive=='Active' ? 'good':'bad';
And added the css code as well. But I cannot see any changes for the specific dial (I expect that it will be green, as status is active)
The device ID is correct (it's a text device in Domoticz)
Domoticz beta | Dashticz beta | Synology DS415+ | Wall tablet Teclast 11.6inch (Android) | TADO v3 controlled heating
pvklink
Post by pvklink »
lokonli is great... :-)
Problem solved and you also solved a problem i wanted to adress after this:
- when you change a value in domoticz, this dashticz dial does not refresh, this also solved :-)
for me last questions are:
0. how do i get rid of "0 level" in the dial , see attachment.
hide_data: true, does not help
@update: solved, by removing the values part and add isSetpoint: true in the main part of the block
1. what does "fixed" do?
2. In my case do i have to repeat idx 2272 in the main part as well as in the values part
@update: solved, values part removed
3. Does setpoint: 60 has any use ? i thougt you could influence the colors of the ring when below or above this point
4. what does layout do
My current volume(dimmer) dial
	title: 'Volume',
	idx:	2272,
	values:	[
		idx: 2272,
		decimals: 0,
		setpoint: 60,
		isSetpoint: true
	layout: 1,
	type: 'dial',
        color: 'white',
	width: 3,
//	icon: '',
	hide_data: true,
	switch: false,
        min:0,
        max:100,
        showring: true,
        showunit: true,
	decimals: 0,
	animation: true,
//	fixed: true,
        shownumbers: true,
        last_update: false}
Lokonli
Post by Lokonli »
Chris12 wrote: Tuesday 16 March 2021 11:03
.item.bad {
.item.good {
The data of your text device is already a string, so you have to remove parseFloat, otherwise it will be interpreted as a number. Like this:
        var rpiactive = device.Data;
Formatting the main value of a dial is also slightly different. You can use the following:
.good .value {
    color: green;
.bad .value {
    color: red;
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
