I will answer in English as this is an English forum.Thuis wrote: ↑Wednesday 10 February 2021 13:06 Ojee ik zie dat goeree overflakkee nu weer, sinds 1 januari 2021, een andere afval kalender gebruikt van RAD.
Ik ben benieuwd hoelang webadapter.watsoftware.nl nog werkt.
Geen idee of deze ook gebruikt wordt bij de nieuwe afval kalender. (wasteprod2portal.ximmio.com)
https://wasteprod2portal.ximmio.com/mod ... verflakkee
Hij krijgt nog wel nieuwe data binnen zol ijkt het.
@jvdz kun je me vertellen of dit iets uitmaakt of zou het gewoon blijven werken. Mij viel wel op dat de bakken maandag volgens webadapter wel werden opgehaald en op RAD stond dinsdag en woensdag. De laatste klopte met de werkelijkheid in vermelding met de sneeuw.
I see that the link you provided is one for ximmio, so that module should work when you use that m_ximmio module.... but:
when I tried it wasn't working and several other zipcodes I have in my testrun weren't working anymore. While researching I found out that some are using a different API hostname so I tested with that and found your address works and the ones that failed in in test process also worked with that host.... but sadly the working ones on the original hostname didn't work anymore. So I decided to simply try the second hostname when the first one fails and now they all work including yours.
m_goeree-overflakkee: papier en karton: din 16 feb ; restafval: maa 22 feb ; groente-, fruit- en tuinafval: maa 1 maa ;
m_ximmio: grey: woe 10 feb ; paper: din 16 feb ; green: maa 1 maa ;
Please try this development version of ximmio and let me know whether that works. This also count for those currently seeing issues with the ximmio module as it could be they are moved to that new hostname too.
Jos
