I installed a P1 power / gas sensor
when i have a look into the utility i see the 3 phazes, usage 1 , usage 2, usage 3, delivery 1, delivery 2, delivery 3, power and gas.
only when i have a look to the log off the Power i only see Usage 1 and Usage 2, then i can't see the third ?
how can i change that so i also see the third one ?
smart energy P1
- FireWizard
Re: smart energy P1
Hello @kozzen.
You said:
What you see is the Usage Low Tariff T1 and Usage High Tariff T2 (indicated as Usage 1, resp Usage 2)
These figures indicate the cost.
Usage 1 is the low cost energy and Usage 2 is the standard cost.
Usage 1 you pay in night and weekend hours, while Usage 2 are the hours during the day in the week. (As you are probably Dutch: Gebruik 1 is het nachttarief of weekend tarief) In Belgium it is different and it depends on you energy contract.
Even if you don't use two tariffs they might be indicated, but showing a 0 value.
If you have solar panels, you will also see Return 1 and Return 2
I hope this explains reading.
You said:
This means that you have a 3 phase connection.when i have a look into the utility i see the 3 phazes, usage 1 , usage 2, usage 3, delivery 1, delivery 2, delivery 3, power and gas.
You cannot, as there is not.only when i have a look to the log off the Power i only see Usage 1 and Usage 2, then i can't see the third ?
kozzen
Re: smart energy P1 (solved)
thanks for your reaction
