smart energy P1
kozzen
smart energy P1
Post by kozzen »
I installed a P1 power / gas sensor
when i have a look into the utility i see the 3 phazes, usage 1 , usage 2, usage 3, delivery 1, delivery 2, delivery 3, power and gas.
only when i have a look to the log off the Power i only see Usage 1 and Usage 2, then i can't see the third ?
how can i change that so i also see the third one ?
FireWizard
Re: smart energy P1
Post by FireWizard »
Hello @kozzen.
This means that you have a 3 phase connection.
You cannot, as there is not.
What you see is the Usage Low Tariff T1 and Usage High Tariff T2 (indicated as Usage 1, resp Usage 2)
These figures indicate the cost.
Usage 1 is the low cost energy and Usage 2 is the standard cost.
Usage 1 you pay in night and weekend hours, while Usage 2 are the hours during the day in the week. (As you are probably Dutch: Gebruik 1 is het nachttarief of weekend tarief) In Belgium it is different and it depends on you energy contract.
Even if you don't use two tariffs they might be indicated, but showing a 0 value.
If you have solar panels, you will also see Return 1 and Return 2
I hope this explains reading.
kozzen
Re: smart energy P1 (solved)
Post by kozzen »
thanks for your reaction
