Lua script for uploading energy values to PVoutput
Re: Lua script for uploading energy values to PVoutput
@waaren
where can I find the latest dzevents script for uploading to PVoutput ?
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC with Node-Red and MQTT / SolarEdge SE3500H modbus_tcp / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
- waaren
I use below version
local scriptVar = 'PVOutput'
dzVents version of pvOutput script.
api and id stored in domoticz uservariables type string
return
on =
timer =
'every 6 minutes',
devices =
'PVTrigger', -- Only for test. Can be ignored or removed
httpResponses =
scriptVar
logging =
level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when all OK
marker = scriptVar,
execute = function(dz, item)
local function post2PVOutput(PVSettings, postData)
dz.openURL(
url = PVSettings.url,
method = 'POST',
headers = {
['X-Pvoutput-Apikey'] = PVSettings.api,
['X-Pvoutput-SystemId'] = PVSettings.id
callback = scriptVar,
postData = postData
local function makepostData()
-- Change device names to reflect yours
local P1 = dz.devices('Power')
local Youless = dz.devices('Youless')
local temperature = dz.devices('temperatuur Rotterdam')
local voltage = dz.devices('Synology UPS - UPS AC Input')
local round = dz.utils.round
local postdDataAsString =
'd=' .. os.date("%Y%m%d") ..
'&t=' .. os.date("%H:%M") ..
'&v1=' .. P1.return1 + P1.return2 ..
'&v2=' .. P1.usageDelivered ..
'&v3=' .. P1.usage1 + P1.usage2 ..
'&v4=' .. P1.usage ..
'&v5=' .. round(temperature.temperature,1) ..
'&v6=' .. round(voltage.sValue,1) ..
'&c1=1'
v1 - energy generation
v2 - power generation W from
v3 - energy consumption
v4 - power consumption
v5 - temperature
v6 - voltage
'&c1= .. c1
'&n= .. n
Donation mode only parms
'&delay=' .. Delay
'&v7=' .. WaterConsumption
'&v8=' .. InverterFrequency
'&v11=' .. InverterTemp
'&v12=' .. GasConsumption
dz.log(postdDataAsString,dz.LOG_DEBUG)
return postdDataAsString
if item.isHTTPResponse then
dz.log("Return from PVOutput ==>> " .. item.data,dz.LOG_DEBUG)
PVSettings =
url = 'HTTPS://pvoutput.org/service/r2/addstatus.jsp',
api = dz.variables('PVoutput_API').value, -- change to name of your uservariable containing your API key
id = dz.variables('PVoutput_ID').value, -- change to name of your uservariable containing your ID
post2PVOutput(PVSettings, makepostData())
tnx @waaren,
I notice you sent the info from your P1 to PVoutput.
I just want to sent the info from my solaredge - modbus to PVoutput, I personally think the info thru the solaredge management platform is rather unstable ...
I will let you know
I use the calculation script, with the integrated P1 logger from Domoticz.
Did all as said in the wiki... All works ok, but keep getting an error about every minute in the logs:
2022-02-05 20:18:00.446 Error: EventSystem: in script_device_calculate_consumption: [string "-- This script collects the values below from..."]:82: attempt to index a nil value (global 'devicechanged')
Seems like the note on the first lines isn't commented out correctly. The script should start with -- and not with "-- is that the case?SterkeJerke wrote: ↑Saturday 05 February 2022 20:20 Hi,
I'm not a programmer but learn by doing and trial and error but maybe you can paste your code here so we can look at what's wrong.
Currently I use the code below to calculate the consumption.
and the code below to post the data to PVoutput.
This script collects the values below from Domoticz
* The Power and energy values (import and export) from a smartmeter
* The Power and energy values from a Solar power inverter
It then calculates the (average) consumed power and energy from the values above with the formula's
* EnergyConsumption = EnergyGeneration + EnergyImport - EnergyExport
* PowerConsumption = PowerGeneration + PowerImport - PowerExport
The average power is calculated because it fluctuates much and can cause negative consumption due to timing issues.
It then updates a virtual device which displays the consumed power and energy in Domoticz
The base of this scrip comes from
https://www.domoticz.com/forum/viewtopic.php?f=61&t=4714&p=251778#p251778
local smartMeterIDX = 10-- IDX of Smart meter device
local solarPanelsIDX = 20 -- IDX of Solar Panels device
local consumptionIDX = 30 -- IDX of Own Usage / calculated value / dummy Elekta kWh + counter
active = true,
on =
devices =
-- Devices on which this calculation script should trigger.
smartMeterIDX,
solarPanelsIDX,
logging =
--level = domoticz.LOG_DEBUG,
level = domoticz.LOG_ERROR,
marker = 'Consumption',
data =
PowerImportHistory = { history = true, maxMinutes = 4 },
PowerExportHistory = { history = true, maxMinutes = 4 },
PowerGenerationHistory = { history = true, maxItems = 24 },
-- Domoticz IDX of the needed devices
local Smartmeter = dz.devices(smartMeterIDX)
local Generation = dz.devices(solarPanelsIDX)
local Consumption = dz.devices(consumptionIDX)
-- Smartmeter
-- Energy import and export
local EnergyImportLow = Smartmeter.usage1
dz.log('EnergyImportLow = ' .. EnergyImportLow/1000 .. ' kWh ', dz.LOG_DEBUG)
local EnergyImportHigh = Smartmeter.usage2
dz.log('EnergyImportHigh = ' .. EnergyImportHigh/1000 .. ' kWh ', dz.LOG_DEBUG)
local EnergyExportLow = Smartmeter.return1
dz.log('EnergyExportLow = ' .. EnergyExportLow/1000 .. ' kWh ', dz.LOG_DEBUG)
local EnergyExportHigh = Smartmeter.return2
dz.log('EnergyExportHigh = ' .. EnergyExportHigh/1000 .. ' kWh ', dz.LOG_DEBUG)
local EnergyImport = EnergyImportLow + EnergyImportHigh
local EnergyExport = EnergyExportLow + EnergyExportHigh
-- Power import and export
-- Add new data for calculating average
if item == Smartmeter then
dz.data.PowerImportHistory.add(Smartmeter.usage)
dz.data.PowerExportHistory.add(Smartmeter.usageDelivered)
-- Generation
-- Energy generated
local EnergyGeneration = Generation.WhTotal
dz.log('EnergyGeneration = ' .. EnergyGeneration .. ' Wh ', dz.LOG_DEBUG)
-- Power generated
if item == Generation then
dz.data.PowerGenerationHistory.add(Generation.actualWatt)
-- Check historical storage entries
if dz.data.PowerImportHistory.size < 3 or dz.data.PowerGenerationHistory.size < 3 then
dz.log('Not enough data points yet to produce something useful', dz.LOG_DEBUG)
dz.log('PowerImportHistory entries = ' .. dz.data.PowerImportHistory.size, dz.LOG_DEBUG)
dz.log('PowerGeneration entries = ' .. dz.data.PowerGenerationHistory.size, dz.LOG_DEBUG)
return
-- Calculate
-- Average power generated
local PowerGeneration = dz.utils.round(dz.data.PowerGenerationHistory.avgSince('00:02:00'), 2)
dz.log('PowerGeneration = ' .. PowerGeneration .. ' W ', dz.LOG_DEBUG)
-- Average power imported and exported
local PowerImport = dz.utils.round(dz.data.PowerImportHistory.avgSince('00:02:00'), 2)
dz.log('PowerImport = ' .. PowerImport .. ' W ', dz.LOG_DEBUG)
local PowerExport = dz.utils.round(dz.data.PowerExportHistory.avgSince('00:02:00'), 2)
dz.log('PowerExport = ' .. PowerExport .. ' W ', dz.LOG_DEBUG)
-- Power consumption
local PowerConsumption = dz.utils.round(PowerGeneration + PowerImport - PowerExport, 0)
dz.log('PowerConsumption = ' .. PowerConsumption .. ' W ', dz.LOG_DEBUG)
-- Debug for negative power consumption
if PowerConsumption < 0 then
dz.log('(NEGATIVE) PowerConsumption = PowerGeneration + PowerImport - PowerExport', dz.LOG_INFO)
dz.log('' .. PowerConsumption .. ' W = ' .. PowerGeneration .. ' W + ' .. PowerImport .. ' W - ' .. PowerExport, dz.LOG_INFO)
dz.log('PowerConsumption set to 0', dz.LOG_INFO)
local PowerConsumption = 0
dz.log('PowerConsumption = PowerGeneration + PowerImport - PowerExport', dz.LOG_INFO)
-- Energy consumption
local EnergyConsumption = dz.utils.round(EnergyGeneration + EnergyImport - EnergyExport, 0)
dz.log('EnergyConsumption = ' .. EnergyConsumption/1000 .. ' kWh ', dz.LOG_DEBUG)
-- Update device
Consumption.updateElectricity(PowerConsumption, EnergyConsumption)
-- The base of this scrip comes from
-- https://www.domoticz.com/forum/viewtopic.php?f=61&t=4714&p=251778#p251778
-- https://www.domoticz.com/forum/viewtopic.php?f=59&t=28056&p=261029#p261029
timer = { 'every 1 minutes'},
httpResponses = { scriptVar },
logging = {
level = domoticz.LOG_INFO,
-- level = domoticz.LOG_DEBUG,
marker = scriptVar
dz.openURL({
method = 'POST',
headers = {
postData = postData
local Solar = dz.devices(10) -- (v1+v2) IDX of Solar Panels
local Consumption = dz.devices(20) -- (v3+v4) IDX of Consumption device (from consumption.lua script)
local Temperature = dz.devices(30) -- (v5) IDX of outside temp device
local Voltage = dz.devices(40) -- (v6) IDX of a device with a Voltage value
local c1 = 1 -- (c1) Cumulative Flag. c1 = 0 when v1 is today's energy. c1 = 1 when v1 is lifetime energy.
local n = 0 -- (n) Net Flag. n = 0 is default, n = 1 When the net export/import and generation/consumption data is uploaded separately
--local Water = dz.devices(50) -- (v7) IDX of the water consumption
local InverterFrequency = dz.devices(60) -- (v8) IDX of the inverter frequency
local InverterVoltage = dz.devices(70) -- (v9) IDX of the inverter temperature
local InverterCurrent = dz.devices(80) -- (v10) IDX of the inverter current
local InverterTemperature = dz.devices(90) -- (v11) IDX of the inverter temperature
local Gas = dz.devices(100) -- (v12) IDX of Smart Gas Meter
dz.log('-- Energy generation (v1) = ' .. Solar.WhTotal/1000 .. ' Wh ', dz.LOG_DEBUG)
dz.log('-- Power generation (v2) = ' .. Solar.actualWatt .. ' W ', dz.LOG_DEBUG)
dz.log('-- Energy consumption (v3) = ' .. Consumption.WhTotal/1000 .. ' Wh ', dz.LOG_DEBUG)
dz.log('-- Power consumption (v4) = ' .. Consumption.actualWatt .. ' W ', dz.LOG_DEBUG)
dz.log('-- Temperature (v5) = ' .. round(Temperature.temperature,1) .. ' C ', dz.LOG_DEBUG)
dz.log('-- Voltage (v6) = ' .. round(Voltage.voltage,1) .. ' V ', dz.LOG_DEBUG)
dz.log('-- c1 = ' .. c1 .. ' ', dz.LOG_DEBUG)
dz.log('-- n = ' .. n .. ' ', dz.LOG_DEBUG)
--dz.log('-- Water (v7) = ' .. Water.counterToday .. ' l ', dz.LOG_DEBUG)
dz.log('-- Inverter Frequency FAC (v8) = ' .. InverterFrequency.rawData[1] .. ' Hz ', dz.LOG_DEBUG)
dz.log('-- Inverter voltage VAC (v9) = ' .. round(InverterVoltage.voltage,1) .. ' V ', dz.LOG_DEBUG)
dz.log('-- Inverter current UAC (v10) = ' .. InverterCurrent.rawData[1] .. ' A ', dz.LOG_DEBUG)
dz.log('-- Inverter Temperature (v11) = ' .. round(InverterTemperature.temperature,1) .. ' C ', dz.LOG_DEBUG)
dz.log('-- Gas (v12) = ' .. Gas.counterToday .. ' m3 ', dz.LOG_DEBUG)
v5 - Temperature
v6 - Voltage
v7 - Water Consumption in l
v8 - Frequency (FAC)
v9 - Voltage (VAC)
v10 - Current (IAC)
v11 - Inverter Temperature
v12 - Gas Consumption
'&v1=' .. Solar.WhTotal ..
'&v2=' .. Solar.actualWatt ..
'&v3=' .. Consumption.WhTotal ..
'&v4=' .. Consumption.actualWatt ..
'&v5=' .. round(Temperature.temperature,1) ..
'&v6=' .. round(Voltage.voltage,1) ..
'&c1=' .. c1 ..
'&n=' .. n ..
--'&v7=' .. Water.counterToday ..
'&v8=' .. InverterFrequency.rawData[1] ..
'&v9=' .. round(InverterVoltage.voltage,1) ..
'&v10=' .. InverterCurrent.rawData[1] ..
'&v11=' .. round(InverterTemperature.temperature,1) ..
'&v12=' .. Gas.counterToday
if item.statusText=='OK' then
dz.log("Data successfully added to PVoutput")
dz.log("Error: the return from PVOutput was : " .. item.data,dz.LOG_ERROR)
PVSettings =
I hope someone can help me please.
my SD card corrupt last week breaking my Domoticz which had been running perfectly for years and so I had to start from scratch. I seems to have everything back and working ok apart from my script to upload my generated and usage to PVOutput. It was using @simonrg's old LUA script but the same script wont work now. I'm getting an error to say "Error: EventSystem: in pvoutput: [string "-- /home/pi/domoticz/scripts/lua/script_time_..."]:71: attempt to index a nil value (field '?')" I'd be grateful for any help please.
Can't find a lua script of simonrg in this topic...
Sorry
Its the LUA time scrip from here that isn't working: https://www.domoticz.com/wiki/Upload_en ... o_PVoutput
