Lua script for uploading energy values to PVoutput
eddieb
Re: Lua script for uploading energy values to PVoutput
Post by eddieb »
@waaren
where can I find the latest dzevents script for uploading to PVoutput ?
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
eddieb wrote: Wednesday 24 February 2021 11:16 @waaren
I use below version
local scriptVar = 'PVOutput'
        dzVents version of pvOutput script.
        api and id stored in domoticz uservariables type string
return
    on =
        timer =
            'every 6 minutes',
        devices =
            'PVTrigger', -- Only for test. Can be ignored or removed
        httpResponses =
            scriptVar
    logging =
        level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when all OK
        marker = scriptVar,
    execute = function(dz, item)
        local function post2PVOutput(PVSettings, postData)
            dz.openURL(
                url = PVSettings.url,
                method = 'POST',
                headers = {
                    ['X-Pvoutput-Apikey'] = PVSettings.api,
                    ['X-Pvoutput-SystemId'] = PVSettings.id
                callback = scriptVar,
                postData = postData
        local function makepostData()
            -- Change device names to reflect yours
            local P1 = dz.devices('Power')
            local Youless = dz.devices('Youless')
            local temperature = dz.devices('temperatuur Rotterdam')
            local voltage = dz.devices('Synology UPS - UPS AC Input')
            local round = dz.utils.round
            local postdDataAsString =
            'd=' .. os.date("%Y%m%d") ..
            '&t=' .. os.date("%H:%M") ..
            '&v1=' .. P1.return1 + P1.return2 ..
            '&v2=' .. P1.usageDelivered ..
            '&v3=' .. P1.usage1 + P1.usage2 ..
            '&v4=' .. P1.usage ..
            '&v5=' .. round(temperature.temperature,1) ..
            '&v6=' .. round(voltage.sValue,1) ..
            '&c1=1'
                v1 - energy generation
                v2 - power generation            W from
                v3 - energy consumption
                v4 - power consumption
                v5 - temperature
                v6 - voltage
            '&c1= ..  c1
            '&n= .. n
                                            Donation mode only parms
            '&delay=' .. Delay
            '&v7=' .. WaterConsumption
            '&v8=' .. InverterFrequency
            '&v11=' .. InverterTemp
            '&v12=' .. GasConsumption
            dz.log(postdDataAsString,dz.LOG_DEBUG)
            return postdDataAsString
        if item.isHTTPResponse then
            dz.log("Return from PVOutput ==>> " .. item.data,dz.LOG_DEBUG)
            PVSettings =
                url = 'HTTPS://pvoutput.org/service/r2/addstatus.jsp',
                api = dz.variables('PVoutput_API').value, -- change to name of your uservariable containing  your API key
                id  = dz.variables('PVoutput_ID').value,   -- change to name of your uservariable containing your ID
            post2PVOutput(PVSettings, makepostData())
eddieb
Post by eddieb »
waaren wrote: Wednesday 24 February 2021 11:34
tnx @waaren,
I notice you sent the info from your P1 to PVoutput.
I just want to sent the info from my solaredge - modbus to PVoutput, I personally think the info thru the solaredge management platform is rather unstable ...
I will let you know
SterkeJerke
Post by SterkeJerke »
I use the calculation script, with the integrated P1 logger from Domoticz.
Did all as said in the wiki... All works ok, but keep getting an error about every minute in the logs:
2022-02-05 20:18:00.446 Error: EventSystem: in script_device_calculate_consumption: [string "-- This script collects the values below from..."]:82: attempt to index a nil value (global 'devicechanged')
SterkeJerke
roblom wrote: Tuesday 07 July 2020 11:42 Thanks for the help! But I found out that I have negative consumption values so I have to sort that out first.
Did you solve it?? I have the same
roblom
Post by roblom »
SterkeJerke wrote: Saturday 05 February 2022 20:20 Hi,
Seems like the note on the first lines isn't commented out correctly. The script should start with -- and not with "-- is that the case?
I'm not a programmer but learn by doing and trial and error but maybe you can paste your code here so we can look at what's wrong.
roblom
Post by roblom »
Currently I use the code below to calculate the consumption.
	This script collects the values below from Domoticz
	  * The Power and energy values (import and export) from a smartmeter
	  * The Power and energy values from a Solar power inverter
	It then calculates the (average) consumed power and energy from the values above with the formula's
	  * EnergyConsumption = EnergyGeneration + EnergyImport - EnergyExport
	  * PowerConsumption = PowerGeneration + PowerImport - PowerExport
	The average power is calculated because it fluctuates much and can cause negative consumption due to timing issues.
	It then updates a virtual device which displays the consumed power and energy in Domoticz
	The base of this scrip comes from
	https://www.domoticz.com/forum/viewtopic.php?f=61&t=4714&p=251778#p251778
local smartMeterIDX = 10-- IDX of Smart meter device
local solarPanelsIDX = 20 -- IDX of Solar Panels device
local consumptionIDX = 30 -- IDX of Own Usage / calculated value / dummy Elekta kWh + counter
	active = true,
	on =
		devices =
			-- Devices on which this calculation script should trigger.
			smartMeterIDX,
			solarPanelsIDX,
	logging =
		--level = domoticz.LOG_DEBUG,
		level = domoticz.LOG_ERROR,
		marker = 'Consumption',
	data =
		PowerImportHistory = { history = true, maxMinutes = 4 },
		PowerExportHistory = { history = true, maxMinutes = 4 },
		PowerGenerationHistory = { history = true, maxItems = 24 },
		-- Domoticz IDX of the needed devices
		local Smartmeter = dz.devices(smartMeterIDX)
		local Generation = dz.devices(solarPanelsIDX)
		local Consumption = dz.devices(consumptionIDX)
		-- Smartmeter
		-- Energy import and export
		local EnergyImportLow = Smartmeter.usage1
		dz.log('EnergyImportLow	 = ' .. EnergyImportLow/1000 .. ' kWh ', dz.LOG_DEBUG)
		local EnergyImportHigh = Smartmeter.usage2
		dz.log('EnergyImportHigh = ' .. EnergyImportHigh/1000 .. ' kWh ', dz.LOG_DEBUG)
		local EnergyExportLow = Smartmeter.return1
		dz.log('EnergyExportLow	 = ' .. EnergyExportLow/1000 .. ' kWh ', dz.LOG_DEBUG)
		local EnergyExportHigh = Smartmeter.return2
		dz.log('EnergyExportHigh = ' .. EnergyExportHigh/1000 .. ' kWh ', dz.LOG_DEBUG)
		local EnergyImport = EnergyImportLow + EnergyImportHigh
		local EnergyExport = EnergyExportLow + EnergyExportHigh
		-- Power import and export
		-- Add new data for calculating average
		if item == Smartmeter then
			dz.data.PowerImportHistory.add(Smartmeter.usage)
			dz.data.PowerExportHistory.add(Smartmeter.usageDelivered)
		-- Generation
		-- Energy generated
		local EnergyGeneration = Generation.WhTotal
		dz.log('EnergyGeneration = ' .. EnergyGeneration .. ' Wh ', dz.LOG_DEBUG)
		-- Power generated
		if item == Generation then
			dz.data.PowerGenerationHistory.add(Generation.actualWatt)
		-- Check historical storage entries
		if dz.data.PowerImportHistory.size < 3 or dz.data.PowerGenerationHistory.size < 3 then
			dz.log('Not enough data points yet to produce something useful', dz.LOG_DEBUG)
			dz.log('PowerImportHistory entries = ' .. dz.data.PowerImportHistory.size, dz.LOG_DEBUG)
			dz.log('PowerGeneration entries = ' .. dz.data.PowerGenerationHistory.size, dz.LOG_DEBUG)
			return
		-- Calculate
		-- Average power generated
		local PowerGeneration = dz.utils.round(dz.data.PowerGenerationHistory.avgSince('00:02:00'), 2)
		dz.log('PowerGeneration = ' .. PowerGeneration .. ' W ', dz.LOG_DEBUG)
		-- Average power imported and exported
		local PowerImport = dz.utils.round(dz.data.PowerImportHistory.avgSince('00:02:00'), 2)
		dz.log('PowerImport = ' .. PowerImport .. ' W ', dz.LOG_DEBUG)
		local PowerExport = dz.utils.round(dz.data.PowerExportHistory.avgSince('00:02:00'), 2)
		dz.log('PowerExport = ' .. PowerExport .. ' W ', dz.LOG_DEBUG)
		-- Power consumption
		local PowerConsumption = dz.utils.round(PowerGeneration + PowerImport - PowerExport, 0)
		dz.log('PowerConsumption = ' .. PowerConsumption .. ' W ', dz.LOG_DEBUG)
		-- Debug for negative power consumption
		if PowerConsumption < 0 then
			dz.log('(NEGATIVE) PowerConsumption = PowerGeneration + PowerImport - PowerExport', dz.LOG_INFO)
			dz.log('' .. PowerConsumption .. ' W = ' .. PowerGeneration .. ' W + ' .. PowerImport .. ' W - ' .. PowerExport, dz.LOG_INFO)
			dz.log('PowerConsumption set to 0', dz.LOG_INFO)
			local PowerConsumption = 0
			dz.log('PowerConsumption = PowerGeneration + PowerImport - PowerExport', dz.LOG_INFO)
		-- Energy consumption
		local EnergyConsumption = dz.utils.round(EnergyGeneration + EnergyImport - EnergyExport, 0)
		dz.log('EnergyConsumption = ' .. EnergyConsumption/1000 .. ' kWh ', dz.LOG_DEBUG)
		-- Update device
		Consumption.updateElectricity(PowerConsumption, EnergyConsumption)
and the code below to post the data to PVoutput.
-- The base of this scrip comes from
-- https://www.domoticz.com/forum/viewtopic.php?f=61&t=4714&p=251778#p251778
-- https://www.domoticz.com/forum/viewtopic.php?f=59&t=28056&p=261029#p261029
			on =	{
						timer = { 'every 1 minutes'},
						httpResponses = { scriptVar },
		logging =	{
						level   =   domoticz.LOG_INFO,
--						level   =   domoticz.LOG_DEBUG,
						marker  =   scriptVar
			dz.openURL({
				method = 'POST',
				headers = {
				postData = postData
			local Solar 				= dz.devices(10)	-- (v1+v2) IDX of Solar Panels
			local Consumption 			= dz.devices(20)	-- (v3+v4) IDX of Consumption device (from consumption.lua script)
			local Temperature 			= dz.devices(30) 	-- (v5) IDX of outside temp device
			local Voltage 				= dz.devices(40) 	-- (v6) IDX of a device with a Voltage value
			local c1 					= 1 				-- (c1) Cumulative Flag. c1 = 0 when v1 is today's energy. c1 = 1 when v1 is lifetime energy.
			local n 					= 0					-- (n) Net Flag. n = 0 is default, n = 1 When the net export/import and generation/consumption data is uploaded separately
			--local Water 				= dz.devices(50)	-- (v7) IDX of the water consumption
			local InverterFrequency 	= dz.devices(60)	-- (v8) IDX of the inverter frequency
			local InverterVoltage 		= dz.devices(70)	-- (v9) IDX of the inverter temperature
			local InverterCurrent 		= dz.devices(80) 	-- (v10) IDX of the inverter current
			local InverterTemperature 	= dz.devices(90)	-- (v11) IDX of the inverter temperature
			local Gas 					= dz.devices(100)	-- (v12) IDX of Smart Gas Meter
			dz.log('-- Energy generation (v1) = ' .. Solar.WhTotal/1000 .. ' Wh ', dz.LOG_DEBUG)
			dz.log('-- Power generation (v2) = ' .. Solar.actualWatt .. ' W ', dz.LOG_DEBUG)
			dz.log('-- Energy consumption (v3) = ' .. Consumption.WhTotal/1000 .. ' Wh ', dz.LOG_DEBUG)
			dz.log('-- Power consumption (v4) = ' .. Consumption.actualWatt .. ' W ', dz.LOG_DEBUG)
			dz.log('-- Temperature (v5) = ' .. round(Temperature.temperature,1) .. ' C ', dz.LOG_DEBUG)
			dz.log('-- Voltage (v6) = ' .. round(Voltage.voltage,1) .. ' V ', dz.LOG_DEBUG)
			dz.log('-- c1 = ' .. c1 .. ' ', dz.LOG_DEBUG)
			dz.log('-- n = ' .. n .. ' ', dz.LOG_DEBUG)
			--dz.log('-- Water (v7) = ' .. Water.counterToday .. ' l ', dz.LOG_DEBUG)
			dz.log('-- Inverter Frequency FAC (v8) = ' .. InverterFrequency.rawData[1] .. ' Hz ', dz.LOG_DEBUG)
			dz.log('-- Inverter voltage VAC (v9) = ' .. round(InverterVoltage.voltage,1) .. ' V ', dz.LOG_DEBUG)
			dz.log('-- Inverter current UAC (v10) = ' .. InverterCurrent.rawData[1] .. ' A ', dz.LOG_DEBUG)
			dz.log('-- Inverter Temperature (v11) = ' .. round(InverterTemperature.temperature,1) .. ' C ', dz.LOG_DEBUG)
			dz.log('-- Gas (v12) = ' .. Gas.counterToday .. ' m3 ', dz.LOG_DEBUG)
				v5 - Temperature
				v6 - Voltage
				v7 - Water Consumption in l
				v8 - Frequency (FAC)
				v9 - Voltage (VAC)
				v10 - Current (IAC)
				v11 - Inverter Temperature
				v12 - Gas Consumption
			'&v1=' .. Solar.WhTotal ..
			'&v2=' .. Solar.actualWatt ..
			'&v3=' .. Consumption.WhTotal ..
			'&v4=' .. Consumption.actualWatt ..
			'&v5=' .. round(Temperature.temperature,1) ..
			'&v6=' .. round(Voltage.voltage,1) ..
			'&c1=' .. c1 ..
			'&n=' .. n ..
			--'&v7=' .. Water.counterToday ..
			'&v8=' .. InverterFrequency.rawData[1] ..
			'&v9=' .. round(InverterVoltage.voltage,1) ..
			'&v10=' .. InverterCurrent.rawData[1] ..
			'&v11=' .. round(InverterTemperature.temperature,1) ..
			'&v12=' .. Gas.counterToday
			if item.statusText=='OK' then
				dz.log("Data successfully added to PVoutput")
				dz.log("Error: the return from PVOutput was : " .. item.data,dz.LOG_ERROR)
			PVSettings =
markk
Post by markk »
I hope someone can help me please.
my SD card corrupt last week breaking my Domoticz which had been running perfectly for years and so I had to start from scratch. I seems to have everything back and working ok apart from my script to upload my generated and usage to PVOutput. It was using @simonrg's old LUA script but the same script wont work now. I'm getting an error to say "Error: EventSystem: in pvoutput: [string "-- /home/pi/domoticz/scripts/lua/script_time_..."]:71: attempt to index a nil value (field '?')" I'd be grateful for any help please.
roblom
Post by roblom »
Can't find a lua script of simonrg in this topic...
markk
Post by markk »
Sorry
Its the LUA time scrip from here that isn't working: https://www.domoticz.com/wiki/Upload_en ... o_PVoutput
