Help me. My hikvision cameras works fine on my computer, but don't work on android tablet. I tried wallPanel, fully kiosk, chrome ect. but nothing.
config.js
buttons.webcam_sarok = {forcerefresh:true, width:12, isimage:true, refreshimage: 2000, refreshurl: 2000, refresh:1000, image: 'http://xxxx:[email protected]/ISAPI/ ... 02/picture'}
Dachticz and hikvision cameras
ducyka
- tablet
- tablet.jpg (369.36 KiB) Viewed 939 times
- computer
- computer.jpg (344.45 KiB) Viewed 939 times
djdacore
- Domoticz version: 4.11670
Re: Dachticz and hikvision cameras
Instead of image: try btnimage:
mvzut
Has this been solved? I am running into a similar issue with my Hikvision cameras. I am using the new Camera block type. My two Foscam cameras show up fine in Fully Kiosk, my two Hikvision camera's show some sort of "not found" icon. It works fine on a PC. And I can also open the URLs in Chrome on the same tablet. Any ideas what this could be?
- madpatrick
- Domoticz version: 2025.2
I'm using 3 Hikvision cameras and they are working fine within Dashticz and Fully admin
This is my block which you can use as an example
blocks['camera_1'] = {
type: 'camera',
title: 'Voordeur',
isimage: true,
refresh: 5,
width: 4,
height:180,
forcerefresh: 1,
slidedelay : 10,
imageUrl: 'https://IPADDRESS:9300/camsnapshot.jpg?idx=1',
mvzut
Ok, thanks I'll give that URL a try. Which Hikvision cameras are you using? And is 9300 the port that you actively assigned to the https connection? I dont use https at the moment, but I don't think that makes the difference right?
- madpatrick
I’m using as much as possible secure connections. Should not make a difference.
The port 9300 is my Domoticz connection and not related to the camera. Those have each a seperate IP
All your cameras must be configurated in Domoticz. If they are working in Domoticz, this will also working in Dashticz
