Dashticz Dial - Features, Fixes & Updates
csuti
- Domoticz version: 2024.2
Re: Dashticz Dial - Features, Fixes & Updates
Hi Lokonli,
it works well with beta! Thanks a lot!
regards
regards
Ierlandfan
Is it possible to extend a dial so it also displays an extra on/off status?
Something like this:
blocks['myItho'] = {
type: 'dial',
min: 0,
max: 255,
values : [
value: '?' (dimmer switch type) Main value to show in Dial and needle can be used to change this value
idx: 422
value: '?' (On or off switch type) //Set dial to "Off" (Like a button) when not online
idx: 423,
icon: 'fas fa-fan',
stephanvdplas
- Domoticz version: 2023.1
Re: Dashticz Dial
Can you please explain what you mean by "configure Toon as dummy devices"? I have Toon working in Domoticz by using the ToonAPIlib4Domoticz plugin. How can I create dummy devices that represent the current state and setpoint for my Toon instead of using this plugin?clinkadink wrote: Tuesday 02 June 2020 23:01 The beta branch has now been updated, including new dial features.
Dials now support Toon thermostat and controller. The thermostat block config can now accept a "temp" idx. This will then show both the Toon temperature device and the Toon Setpoint on the same dial (exactly how it works with EvoHome devices). The Toon devices will need to be configured in Domoticz as dummy devices. The controller needs to a switch with "SwitchType" : "Selector". The temperature device needs to be "Type" : "Temp", and the thermostat "Type" : "Thermostat".
Toon controller and thermostat, with their block config below:
In addition to supporting Toon, there have been some addition parameters added to the dial block.
- last_update - same as standard block (default: true)
- flash - same as standard block but around the outer dial with user or default color (default: 0)
- dialimage - an image instead of the calendar icon (default: false)
- dialicon - a different font awesome icon instead of the default calendar icon (default: 'fas fa-calendar-alt')
Screenshots of the above parameters enabled are here: https://github.com/Dashticz/dashticz/pull/501
- showring - always show the outer color ring (default: false)
- Running LMS, Domoticz and Dashticz on a windows 11 laptop.
- LMS (11 players) / Hue (26 lights, 2 switches) / Z-wave (14 devices) / Toon (unrooted) / Chromecast
stephanvdplas
When I choose a type:'dial' for one of my blocks, it doesn't show up at all.
When checking what happens in my browser i see this:
/tpl/dial.tpl?13 file or directory not found.
The file /tpl/dial.tpl does exist in the wwwroot.
I'm running latest beta (3.7.3). What can be wrong?
Last edited by stephanvdplas on Thursday 11 February 2021 15:28, edited 1 time in total.
Lokonli
Do you have /tpl/dail.tpl or /tpl/dial.tpl in wwwroot?
On what kind of system is Dashticz installed?
stephanvdplas
Dashticz is installed on IIS (Windows 10). the file /tpl/dial.tpl is present (and IIS_IUSRS has RX permissions).
stephanvdplas
I found the solution. We had to create a MIME type for ptl extensions.
See https://bobcares.com/blog/http-error-404-3-not-found/ and https://forums.iis.net/t/1095097.aspx?M ... +is+blank+ for more information. After following these instructions, the dials do work!
Chris12
- Domoticz version: 2021.1
Now that this feature is available in the latest beta releases it is working fine. Thanks for adding!Lokonli wrote: Thursday 28 January 2021 17:54 Currently text devices are not supported in dials.
I'll add that to the feature request list.
One question here, can the text size be somehow auto-set to fit in the dial ? As I use the dails to visable show the status of pi-hole blocked domains/adds etc. the number of blocked domains has grown out of the dail and ain't fitting nicely anymore.
Or should I add some code into the custom.css ? which css code controls the text format/size of a dial?
And maybe another feature request regarding the dails:
Can the outer ring have a different color depending on the value of the device?
Like active color ring is green, in-active device value color ring is red. So I can cleary see when for example the pi-hole proces monitored via monit is up/down.
Or something like when temperature is above/below certain setpoint etc.
Domoticz beta | Dashticz beta | Synology DS415+ | Wall tablet Teclast 11.6inch (Android) | TADO v3 controlled heating
besix
Hello
I am using Dashticz beta and Domoticz beta.
Dial is great but I have a problem with the switch type as below
In CONFIG.js I have this Push On Button so declared
In Dashticz I get Dial, but instead of the icon there is NaN and after clicking, an empty graph opens as for the sensor.
What am I doing wrong ?
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 9,
"Data" : "On",
"Description" : "",
"DimmerType" : "none",
"Favorite" : 1,
"HardwareDisabled" : false,
"HardwareID" : 24,
"HardwareName" : "Salon RM2",
"HardwareType" : "Broadlink RM2 with Kodi Remote",
"HardwareTypeVal" : 94,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "0018000E",
"Image" : "Generic",
"InternalState" : "On",
"IsSubDevice" : false,
"LastUpdate" : "2021-03-05 07:50:11",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 100,
"Name" : "Klima Off",
"Notifications" : "false",
"PlanID" : "15",
"PlanIDs" :
15
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Switch",
"SwitchType" : "Push On Button",
"SwitchTypeVal" : 9,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "push",
"Unit" : 14,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "332"
"status" : "OK",Code: Select all
blocks[332] = {title: 'Klima OFF',type: "dial",color: "#57c4d6",iconSwitch:'fas fa-power-off',switchMode:'On',width: 2,}What am I doing wrong ?
Chris12
@lokonli, maybe an other option as well if the color change can be initiated by a device/switch on/off. The TADO smart heating devices I have configured with a dail button in dashticz, have a 'Heating On' device in domoticz as well (switch on/off). So that can be a trigger to for example color the outside ring to red as there is currently a heating demand for that room then.Chris12 wrote: Tuesday 02 March 2021 20:08Now that this feature is available in the latest beta releases it is working fine. Thanks for adding!Lokonli wrote: Thursday 28 January 2021 17:54 Currently text devices are not supported in dials.
Lokonli
I can reproduce the problem.besix wrote: Friday 05 March 2021 9:00 Hello
Dial is great but I have a problem with the switch type as belowIn CONFIG.js I have this Push On Button so declaredCode: Select all
"AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CustomImage" : 9, "Data" : "On", "Description" : "", "DimmerType" : "none", "Favorite" : 1, "HardwareDisabled" : false, "HardwareID" : 24, "HardwareName" : "Salon RM2", "HardwareType" : "Broadlink RM2 with Kodi Remote", "HardwareTypeVal" : 94, "HaveDimmer" : true, "HaveGroupCmd" : true, "HaveTimeout" : false, "ID" : "0018000E", "Image" : "Generic", "InternalState" : "On", "IsSubDevice" : false, "LastUpdate" : "2021-03-05 07:50:11", "Level" : 0, "LevelInt" : 0, "MaxDimLevel" : 100, "Name" : "Klima Off", "Notifications" : "false", "PlanID" : "15", "PlanIDs" : [ 15 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "Status" : "", "StrParam1" : "", "StrParam2" : "", "SubType" : "Switch", "SwitchType" : "Push On Button", "SwitchTypeVal" : 9, "Timers" : "false", "Type" : "Light/Switch", "TypeImg" : "push", "Unit" : 14, "Used" : 1, "UsedByCamera" : false, "XOffset" : "0", "YOffset" : "0", "idx" : "332" } ], "status" : "OK",In Dashticz I get Dial, but instead of the icon there is NaN and after clicking, an empty graph opens as for the sensor.Code: Select all
The Push On Button (and Push Off Button) switchtypes are not detected correctly.
I'll fix it this weekend, together with some other dial related changes.
marcojpolet
- Target OS: -
What kind of display hardware do you use with the dials? I have a small OrangePi with a 15" touchscreen, but this is resistive, which is fine for buttons etc, but dials are not working quite well.
pvklink
- Domoticz version: latest b
WOULD BE GREAT!!
frnandu wrote: Tuesday 12 January 2021 1:54 Great work on the dial.
Here's an idea that maybe is worth implementing:
Power meter with switch on/off.
Since there are so many smart plugs with power metering, would be great to be able to combine the function of a dial on/off switch with a power meter showing current wattage and energy in kWh.
So, basically just joining this 2 blocks into one.
Capture.PNGCode: Select all
blocks['media kwh'] = { idx: '5', // A General / kWh Type device title: 'Media Power', type: 'dial', min: 0, max: 100, last_update: false, showunit: true, values: ['Usage','CounterToday'], width: 3, showring: true } blocks['media'] = { idx:6, // A Light/Switch / Switch Type device title: 'Media', type: 'dial', width: 3 }
What do you guys think about this?
Jablotron connection, Ikea
floris74
Hi!
Clinkadink, thank you for all your work.
hopefully someone can help me.
I finally got time these days to get my wind-dial done. It works well, but is there a way to get the windspeed in the middle instead of the direction? so i can see the direction by the needle, and the windspeed in the center of the dial, and as big as possible. i dont need other info (like temp etc) I have a small tablet and older eyes so i need the windspeed big in the center
thanks in advance
thanks in advance
Lokonli
In CONFIG.js define your block as follows:floris74 wrote: Sunday 11 April 2021 1:01 Hi!
I finally got time these days to get my wind-dial done. It works well, but is there a way to get the windspeed in the middle instead of the direction? so i can see the direction by the needle, and the windspeed in the center of the dial, and as big as possible. i dont need other info (like temp etc) I have a small tablet and older eyes so i need the windspeed big in the center![]()
thanks in advance
blocks['wind'] = {
type: 'dial',
idx: 39,
values: [
value: 'Speed',
addClass: 'bigwind',
decimals: 1,
showvalue: false,
width: 12
.bigwind {
font-size: 600% !important;
color: white !important;
floris74
yessss, thank you !!
Vondee
I have a custom dial with a 'CounterToday' value, but it does show now the 'Data' field of the variable with the 3.8.0 version. Version 3.6.7 do show 'CounterToday' correctly.
Lokonli
Can you post your block definition?Vondee wrote: Monday 12 April 2021 13:53 I have a custom dial with a 'CounterToday' value, but it does show now the 'Data' field of the variable with the 3.8.0 version. Version 3.6.7 do show 'CounterToday' correctly.
and the Domoticz json ouput of your device:
http://domotics-ip:port/json.htm?type=devices&rid=123
Preferably add a screen shot of the problem as well.
- HansieNL
@floris74 Is it possible to post a picture of you wind dial? Then I’ll add it to the documentation as an example.
Blah blah blah
floris74
Hi HansieNL
Of cource i can! I edited it a bit for my siuation, so it fits for me very well (the colors of the dial and the needle, and the height of the speed) ,although it would me even better if the compas-direction would be in the dial (N,NNE,NE,ENE,E, etc etc, or in Dutch; N,NNO, NO,O etc)
CONFIG.js
custom.css
CONFIG.js
blocks['wind'] = {
idx: 2442,
title: 'knopen',
type: 'dial',
color: '#57c4d6',
values: [
value: 'Speed',
decimals: 0,
setpoint: 18, // the entire outer ring will change color based on this s
offset: 0, // 0 will point to the wind source, 180 will point to wind d
showvalue: false,
width: 12,
showring: true,
showunit: true,
shownumbers: true,
last_update: false
}Code: Select all
.dial-center {
height: 65%!important;
width: 65%!important;
[data-id='wind'] .dial-needle::before {
border-bottom-color: red!important;
.bigwind {
font-size: 300% !important;
height: 40px !important;
