SOLVE - Osram bulb - Error has device seems not to be created
soulearth
Post by soulearth »
I have an osram bulb that was still working fine a few months ago. But now she is no longer seen.
I tried removing it and pairing it again. But now the pairing no longer works.
I have the following error in the logs:
Time : "10/02/2021 16:21:03"
Module : "Input"
nwkid : "a109"
PluginHealth : "Ready"
message : "Device Annoucement: NwkId: a109 Ieee: 7cb03eaa0a03c25c MacCap: 8e - Error has device seems not to be created !!!"
PermitToJoin : Object {"Duration":0,"Starttime":1613042681}
Thread : "ZiGateForwarder_4"
I update domoticz, zigate plugin and zigate firmware but it is not the solution.
Can you help me ?
Best regards,
pipiche
Re: Osram bulb - Error has device seems not to be created
Post by pipiche »
could you please provide the logs and not only the single error line. It is important to get the context .
I suspect some inconsistent between Domoticz database and Plugin database.
Do a restart of the plugin and check the log from start (please attach them here ).
You can also check the Plugin Web admin page ( Device Management list), try to see if you can find '7cb03eaa0a03c25c' in case you find it and there is a Trash icon on the left side, do press in order to remove it.
After that , try to re-pair your Bulb
Wiki is available here.
Zigbee for Domoticz FAQ
soulearth
Post by soulearth »
Thank you for this quick response.
Unfortunately the bulb is not in the list of objects.
Can you tell me where are the logs?
Regards,
pipiche
Post by pipiche »
the logs are the domoticz logz
soulearth
Post by soulearth »
I attach the logs after the restart of plugin. But it's short ...
But I fount this in log error ( today ):
2021-02-11 18:12:47.189 Error: Python Plugin System: (Zigate) DeviceExist - Found some inconsistency Inputs: a109 7cb03eaa0a03c25c instead of None
2021-02-11 18:12:50.634 Error: (Zigate) Device creation failed, Domoticz settings prevent accepting new devices.
2021-02-11 18:12:50.634 Error: Python Plugin System: (Zigate) Domoticz widget creation failed. Check that Domoticz can Accept New Hardware [ID: -1, Name: 'Classic A60 W clear - LIGHTIFY_LvlControl-7cb03eaa0a03c25c-03', nValue: 0, sValue: '']
2021-02-11 18:16:55.037 Error: Python Plugin System: (Zigate) Device Annoucement: NwkId: a109 Ieee: 7cb03eaa0a03c25c MacCap: 8e - Error has device seems not to be created !!!
Regards,
log_restart.txt
(3.71 KiB) Downloaded 16 times
pipiche
Post by pipiche »
Is "Accepting New Hardware" in Domoticz enabled ? You must do that in order for the plugin to create devices in Domoticz
soulearth
Post by soulearth »
Yes. I allow during 5 minutes when i add a device ( in paramètre -> système -> matériel / dispositif )
pipiche
Post by pipiche »
The message "Device creation failed, Domoticz settings prevent accepting new devices." seems to indicate something different.
soulearth
Post by soulearth »
It was fine, but with a little mystery.
Instead of allowing 5 minutes, I allowed permanent all night. During the night the bulb was extinguished. This morning the buld was turned on but without any attempt to pairing. A this moment, the bulb have finish the pairing.
Now all it's ok.
For the futur, i will use only the "permanent allow add new device".
Thank you for your help,
Best regards.
