I have an osram bulb that was still working fine a few months ago. But now she is no longer seen.
I tried removing it and pairing it again. But now the pairing no longer works.
I have the following error in the logs:
Time : "10/02/2021 16:21:03"
Module : "Input"
nwkid : "a109"
PluginHealth : "Ready"
message : "Device Annoucement: NwkId: a109 Ieee: 7cb03eaa0a03c25c MacCap: 8e - Error has device seems not to be created !!!"
PermitToJoin : Object {"Duration":0,"Starttime":1613042681}
Thread : "ZiGateForwarder_4"
I update domoticz, zigate plugin and zigate firmware but it is not the solution.
Can you help me ?
Best regards,
SOLVE - Osram bulb - Error has device seems not to be created
soulearth
Re: Osram bulb - Error has device seems not to be created
could you please provide the logs and not only the single error line. It is important to get the context .
I suspect some inconsistent between Domoticz database and Plugin database.
Do a restart of the plugin and check the log from start (please attach them here ).
You can also check the Plugin Web admin page ( Device Management list), try to see if you can find '7cb03eaa0a03c25c' in case you find it and there is a Trash icon on the left side, do press in order to remove it.
After that , try to re-pair your Bulb
soulearth
Thank you for this quick response.
Unfortunately the bulb is not in the list of objects.
Can you tell me where are the logs?
Regards,
Regards,
the logs are the domoticz logz
soulearth
I attach the logs after the restart of plugin. But it's short ...
But I fount this in log error ( today ):
2021-02-11 18:12:47.189 Error: Python Plugin System: (Zigate) DeviceExist - Found some inconsistency Inputs: a109 7cb03eaa0a03c25c instead of None
2021-02-11 18:12:50.634 Error: (Zigate) Device creation failed, Domoticz settings prevent accepting new devices.
2021-02-11 18:12:50.634 Error: Python Plugin System: (Zigate) Domoticz widget creation failed. Check that Domoticz can Accept New Hardware [ID: -1, Name: 'Classic A60 W clear - LIGHTIFY_LvlControl-7cb03eaa0a03c25c-03', nValue: 0, sValue: '']
2021-02-11 18:16:55.037 Error: Python Plugin System: (Zigate) Device Annoucement: NwkId: a109 Ieee: 7cb03eaa0a03c25c MacCap: 8e - Error has device seems not to be created !!!
Regards,
Regards,
- log_restart.txt
- (3.71 KiB) Downloaded 23 times
Is "Accepting New Hardware" in Domoticz enabled ? You must do that in order for the plugin to create devices in Domoticz
soulearth
Yes. I allow during 5 minutes when i add a device ( in paramètre -> système -> matériel / dispositif )
The message "Device creation failed, Domoticz settings prevent accepting new devices." seems to indicate something different.
soulearth
It was fine, but with a little mystery.
Instead of allowing 5 minutes, I allowed permanent all night. During the night the bulb was extinguished. This morning the buld was turned on but without any attempt to pairing. A this moment, the bulb have finish the pairing.
Now all it's ok.
For the futur, i will use only the "permanent allow add new device".
Thank you for your help,
Best regards.
Now all it's ok.
Best regards.
