domoticz in synology as package! Available now.
jellex87
Post by jellex87 »
eSbek wrote: Thursday 24 September 2020 11:41 check Jumbotrol's website:
http://www.jadahl.com/
Already checked it a few times. On the website you can't see what's the latest version for your device. You can only see that the latest Domoticz is not available for the Synology DS213. There are no downloads...
jumbotroll
Post by jumbotroll »
jellex87 wrote: Thursday 24 September 2020 15:10
DS213 use arch-88f6282 cpu.
The toolchain from synology is to old and it's not possible to build latest domoticz with this old toolchain.
Latest build for DS213 with arch-88f6282 is for DSM 5.2.
I don't know if this is compatible with DSM 6.x but you can test if you want.
Download: http://www.jadahl.com/domoticz_beta_5.2 ... 8922-7.spk
https://paypal.me/Jumbotroll
Jumbotroll
tbryel
Post by tbryel »
Fyi: I'm running the Jadahl Synology package happily however I tried getting a dzVents script to work (see here: viewtopic.php?f=72&t=23717&p=256908#p256908).
I'm running domoticz (the Jadahl package) on a 112j. I'm using the following package which isn't the latest stable version but I felt unsure about upgrading to 2020.1 just yet (2020.1 package might already include the JSON.lua fix?).:
Domoticz Stable V4.10717 for DSM 6.2
The issue I faced was that the JSON.lua wasn't included in the "../domoticz/dzVents/runtime/" folder after downloading it (here: http://regex.info/code/JSON.lua) and inserting it in that directory (dzVents/runtime) my isuse was resolved. I also inserted it in to the /scripts/lua folder as it also wasn't included there.
Thanks Jumbotroll for the package, it's really great.
schulpr
Post by schulpr »
I'm trying to install the latest Synology package on my DS215J, the v2020.2.12494-8. It won't start on my NAS. The package seems a lot smaller then the previous version I have, v2020.2.12393-8. 58 MB vs. 19 MB. Should the new version work or is something wrong?
Thanks for your help!
Regards, Rob
jumbotroll
schulpr wrote: Friday 23 October 2020 18:47 Hi,
Regards, Rob
This is because it not include Python 3 and you have to install synology python 3 package for domoticz to start.
It was reported many bugs with python include, so I rolled this back..
Jumbotroll
schulpr
Post by schulpr »
Hi, I have the Python 3 package installed already. It was in use with the previous package. At this moment I don't need Python. Will there be a package without python available soon?
jumbotroll
schulpr wrote: Friday 23 October 2020 21:32 Hi, I have the Python 3 package installed already. It was in use with the previous package. At this moment I don't need Python. Will there be a package without python available soon?
Yes!
DS215j arch-armada375 without python.
http://www.jadahl.com/domoticz_2020.2_6 ... =armada375
Jumbotroll
schulpr
Post by schulpr »
Great! Thank you :!:
eSbek
Post by eSbek »
jumbotroll wrote: Friday 23 October 2020 19:30
Regards, Rob
@Jumbotroll
has anyone reported python plugins working in the latest (no python included version)?
I installed the new one + installed the python 3.7 and have the problem reported before, domoticz doesn't start, expecting (?) python libs inside domoticz folder or something?
2020-10-28 14:41:35.842  Status: Domoticz V2020.2 (build 12494) (c)2012-2020 GizMoCuz
2020-10-28 14:41:35.863  Status: Build Hash: f6c3b1e94-modified, Date: 2020-10-20 08:53:17
2020-10-28 14:41:35.863  Status: Startup Path: /usr/local/domoticz/
2020-10-28 14:41:36.008  Sunrise: 06:41:00 SunSet: 16:19:00
2020-10-28 14:41:36.009  Day length: 09:38:00 Sun at south: 11:30:00
2020-10-28 14:41:36.009  Civil twilight start: 06:03:00 Civil twilight end: 16:56:00
2020-10-28 14:41:36.009  Nautical twilight start: 05:21:00 Nautical twilight end: 17:38:00
2020-10-28 14:41:36.009  Astronomical twilight start: 04:40:00 Astronomical twilight end: 18:19:00
2020-10-28 14:41:36.135  Error: Domoticz(pid:32633, tid:32633('domoticz')) received fatal signal 6 (Aborted)
2020-10-28 14:41:36.136  Error: siginfo address=0x7f79, address=0x7f5b1f27d907
2020-10-28 14:41:36.170  Error: Failed to start gdb, will use backtrace() for printing stack frame
2020-10-28 14:41:36.232  Error: #0  /usr/local/domoticz/bin/domoticz() [0x6d8570]
2020-10-28 14:41:36.233  Error: #1  /usr/local/domoticz/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x27d [0x6d900d]
2020-10-28 14:41:36.233  Error: #2  /lib/libpthread.so.0 :  + 0x101c0 [0x7f5b205e51c0]
2020-10-28 14:41:36.233  Error: #3  /lib/libc.so.6 : gsignal + 0x37 [0x7f5b1f27d907]
2020-10-28 14:41:36.233  Error: #4  /lib/libc.so.6 : abort + 0x16a [0x7f5b1f27ecda]
2020-10-28 14:41:36.233  Error: #5  /usr/local/domoticz/lib/libpython3.4m.so : Py_FatalError + 0x4b [0x7f5b1e9e622b]
2020-10-28 14:41:36.233  Error: #6  /usr/local/domoticz/lib/libpython3.4m.so :  + 0x172563 [0x7f5b1e9e6563]
2020-10-28 14:41:36.233  Error: #7  /usr/local/domoticz/lib/libpython3.4m.so : _Py_InitializeEx_Private + 0x23a [0x7f5b1e9e6e4a]
2020-10-28 14:41:36.233  Error: #8  /usr/local/domoticz/bin/domoticz : Plugins::CPluginSystem::StartPluginSystem() + 0x2bd [0xa754ad]
2020-10-28 14:41:36.233  Error: #9  /usr/local/domoticz/bin/domoticz : MainWorker::Start() + 0x6dd [0x6a802d]
2020-10-28 14:41:36.233  Error: #10 /usr/local/domoticz/bin/domoticz : main + 0x899 [0x5ed959]
2020-10-28 14:41:36.233  Error: #11 /lib/libc.so.6 : __libc_start_main + 0xf0 [0x7f5b1f26a030]
2020-10-28 14:41:36.233  Error: #12 /usr/local/domoticz/bin/domoticz() [0x61c6f2]
EDIT: there could be something else. I uninstall all, installed the python 3.7.7, then clean install of Domoticz, crash again.
Reverting back to the last one I have with python included in the package.
2020-10-28 16:19:59.957  Status: Domoticz V2020.2 (build 12494) (c)2012-2020 GizMoCuz
2020-10-28 16:19:59.957  Status: Build Hash: f6c3b1e94-modified, Date: 2020-10-20 08:53:17
2020-10-28 16:19:59.957  Status: Startup Path: /usr/local/domoticz/
2020-10-28 16:20:00.130  Error: Domoticz(pid:6517, tid:6517('domoticz')) received fatal signal 6 (Aborted)
2020-10-28 16:20:00.130  Error: siginfo address=0x1975, address=0x7fbe5f1ce907
2020-10-28 16:20:00.154  Error: Failed to start gdb, will use backtrace() for printing stack frame
2020-10-28 16:20:00.156  Error: #0  /usr/local/domoticz/bin/domoticz() [0x6d8570]
2020-10-28 16:20:00.157  Error: #1  /usr/local/domoticz/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x27d [0x6d900d]
2020-10-28 16:20:00.157  Error: #2  /lib/libpthread.so.0 :  + 0x101c0 [0x7fbe605361c0]
2020-10-28 16:20:00.157  Error: #3  /lib/libc.so.6 : gsignal + 0x37 [0x7fbe5f1ce907]
2020-10-28 16:20:00.157  Error: #4  /lib/libc.so.6 : abort + 0x16a [0x7fbe5f1cfcda]
2020-10-28 16:20:00.157  Error: #5  /usr/local/domoticz/lib/libpython3.4m.so : Py_FatalError + 0x4b [0x7fbe5e93722b]
2020-10-28 16:20:00.157  Error: #6  /usr/local/domoticz/lib/libpython3.4m.so :  + 0x172563 [0x7fbe5e937563]
2020-10-28 16:20:00.157  Error: #7  /usr/local/domoticz/lib/libpython3.4m.so : _Py_InitializeEx_Private + 0x23a [0x7fbe5e937e4a]
2020-10-28 16:20:00.158  Error: #8  /usr/local/domoticz/bin/domoticz : Plugins::CPluginSystem::StartPluginSystem() + 0x2bd [0xa754ad]
2020-10-28 16:20:00.158  Error: #9  /usr/local/domoticz/bin/domoticz : MainWorker::Start() + 0x6dd [0x6a802d]
2020-10-28 16:20:00.158  Error: #10 /usr/local/domoticz/bin/domoticz : main + 0x899 [0x5ed959]
2020-10-28 16:20:00.158  Error: #11 /lib/libc.so.6 : __libc_start_main + 0xf0 [0x7fbe5f1bb030]
2020-10-28 16:20:00.158  Error: #12 /usr/local/domoticz/bin/domoticz() [0x61c6f2]
EDIT 2: So one thing I found the previous version with Python inside apart whole Python folder and files related had two files "libpython3.7m.so" and "libpython3.7m.so.1.0" , here it seems we have files for Python3.4 (libpython3.4m.so/libpython3.4m.so.1.0).
artstam
211+ synology
Post by artstam »
I tried to install the domomticz (node-mydomoathome-0.2.39 ) package on a a 211+ synology, but i get the warning that node.js_v4 is not installed. I can not find how to do this!
An earlier version (domoticz_88f6282-6.2_3.0.9483-7) seems to work ok.
Is my synology 211+ to old for the latest domoticz?
Thomas
C4coer
Post by C4coer »
can you help me, please.
hello I switched to a 720+ syno, but the package http://www.jadahl.com/domoticz_2020.2_p ... geminilake.
I tried the version without python, to try to add it but impossible.
Can you give me a link for the previous version with python which worked, because I no longer have a functional domoticz
thanks you
I found a solution here is what I did:
install the version with python
installing python 3.7.7 is here:
https://synocommunity.com/package/python3
then I copy the folder "python3.7" which is in / volume1 / @ appstore / python3 / lib
to put it in / volume1 / @ appstore / domoticz / lib
THEN I un-installed python to install the synology version in 3.8
and it works
j'ai trouvé une solution voila ce que j'ai fait:
installation de la version avec python
installation de python 3.7.7
ensuite j'ai copier le dossier "python3.7" qui se trouve dans /volume1/@appstore/python3/lib
pour le mettre dans /volume1/@appstore/domoticz/lib
ENSUITE j'ai de-insallé python pour installer la version syno en 3.8
et la miracle cela fonctionne
TonyB
Post by TonyB »
My Domoticz_geminilake-6.2_2020.2.12728-8.spk (Beta) is not working ok. It stops 4-7 times a day! This is for both the Python and the non python version. Same problem with 2020.2.12731-8.spk.
I migrated from Apollolake, on my DS1019+ everything was working fine.
Yes I know these are all Beta version, however I can't find a stable Jadahl version.
My Geminilake on DS1520+ (and former DS1019+) works with ZWave, RFX, Fritz telephone logging, DS1520+ internal sensors, Solarsystem Enphase amoung others.
I didn't install the USB serial driver (I als didn't on my DS1019+) it worked without it.
Any idea how to solve this? Is there a stable version soon expected. Is there a method to check if Domoticz is running and start automatic if it stopped?
I am a littlebit desparate what to do.Starting by hand 7 times a day is not nice to do.
mcwieger
Domoticz version: 2020.1
Re: 211+ synology
Post by mcwieger »
artstam wrote: Saturday 21 November 2020 17:31 I tried to install the domomticz (node-mydomoathome-0.2.39 ) package on a a 211+ synology, but i get the warning that node.js_v4 is not installed. I can not find how to do this!
Thomas
It's not on the website of Jumbotroll, so it looks there's no 2020.1 package for the 211+. Support for new versions by Jumbotroll has ended, as it seems. One of the reasons for me to move to Home Assistant soon. Too bad...
I moved to HomeAssistant. It was fun while it lasted!
mcwieger
Post by mcwieger »
TonyB wrote: Tuesday 26 January 2021 10:59 My Domoticz_geminilake-6.2_2020.2.12728-8.spk (Beta) is not working ok. It stops 4-7 times a day! This is for both the Python and the non python version. Same problem with 2020.2.12731-8.spk.
It doesn't solve the root cause, but consider using Monit to automatically restart Domoticz. Please search the forum for how to set it up.
boggiz
Domoticz version: 2024.4
Post by boggiz »
I'm desperately trying to launch a Python version of Domoticz 2020.1 or .2 but I can't do it.
This app is correctly installed and Python 3.7.15 is OK.
Someone can help me ?
NAS Syno DS718+ with 12Go ram
RFXtrx433XL v1044 with 3dBi antenna
Domoticz 2024.4 on Docker
TFA rain gauge, 4 ways automatic watering program, LINKY consumption, waterflow counter
mcwieger
Post by mcwieger »
@jumbotroll Any chance you can build a 1520+ package?
mcwieger wrote: Friday 05 February 2021 17:08 @jumbotroll Any chance you can build a 1520+ package?
From Jadahl.com site
Domoticz for synology will no longer be updated by Jadahl.
There is a time for everything and I have been compiling domoticz for synology since 2015.
Now I see that it is becoming more difficult and more complicated to build these packages for synology.
Another solution might be to use the Docker, or switch to Raspberry Pi or similar device.
Thanks for now!
I do not reply to emails regarding domoticz.
Latest available domoticz package for 1520+ = v2020.2.12731-8
mcwieger
Post by mcwieger »
Ah thanks, overlooked the beta :roll:
eSbek
Post by eSbek »
guys,
it seems it's time to buy a raspberry pi and be up to date with Domoticz. I already ordered pi 3B, found somwhere around here that 3B should be enough to run the home automation.
EDIT: I received the 3B+ and set it up yesterday, Rasp OS Lite + domoticz beta + python (modbus and viessmann API - PyVicare), it's superfast comparing to how domoticz was running on my DS412+. Also I was fed up with z-wave stick changing usb port from time to time causing no z-wave communication until updated to a proper usb port. Very recomended.
RogerSch
Post by RogerSch »
Maybe check if the Domoticz version in the Synocommunity might be an alternative:
https://synocommunity.com/package/domoticz
Users browsing this forum: Menno and 1 guest
