align streamplayer icon/image in css Topic is solved
whoami
- Target OS: -
How to make the icon or image of the streamplayer (letter A in the example) bigger and center vertically? I tried a lot but can't find the right description in CSS.
tried a lot with .streamplayer in custom.css
whoami
- Target OS: -
Re: align streamplayer icon/image in css
Nobody knows this? If I use .streamplayer only the titles of the radio is changed not the icon in front...
Lokonli
Try the following in custom.css:whoami wrote: Sunday 17 January 2021 13:43 Nobody knows this? If I use .streamplayer only the titles of the radio is changed not the icon in front...
.streamplayer .col-icon {
display:flex;
align-items: center;
width: 100px !important;
max-width: 100px;
.streamplayer .col-icon .fas{
font-size: 100px;
whoami
- Target OS: -
Yes, that works great!! You know a lotLokonli wrote: Sunday 17 January 2021 20:44Try the following in custom.css:whoami wrote: Sunday 17 January 2021 13:43 Nobody knows this? If I use .streamplayer only the titles of the radio is changed not the icon in front...
.streamplayer .col-icon { display:flex; align-items: center; width: 100px !important; max-width: 100px; } .streamplayer .col-icon .fas{ font-size: 100px; }
Do you also know how to avoid that the musicstreamer stops playing after a refresh of Dashticz? I can turn of the refresh, but then my weather is not updated anymore...
Lokonli
Most browsers don't allow to start autoplay after page load. I did not find a workaround.whoami wrote: Sunday 17 January 2021 22:10Yes, that works great!! You know a lotLokonli wrote: Sunday 17 January 2021 20:44Try the following in custom.css:whoami wrote: Sunday 17 January 2021 13:43 Nobody knows this? If I use .streamplayer only the titles of the radio is changed not the icon in front...
Probably it's better to try to fix the weather update. Can you post your weather block?
whoami
- Target OS: -
I just use the owm module:Lokonli wrote: Monday 18 January 2021 10:53Most browsers don't allow to start autoplay after page load. I did not find a workaround.whoami wrote: Sunday 17 January 2021 22:10Yes, that works great!! You know a lotLokonli wrote: Sunday 17 January 2021 20:44
config['owm_api'] = 'xxxxxxx';
config['owm_city'] = 'xxxxxxx';
config['owm_name'] = 'xxxxxxx';
config['owm_country'] = 'nl';
config['owm_lang'] = 'nl';
config['owm_cnt'] = '5';
config['owm_days'] = 0;
config['owm_min'] = 1;
columns[3] = {}
columns[3]['blocks'] = ['titelradio','streamplayer', 'weather_owm', 'currentweather_big_owm']
columns[3]['width'] = 6;
This one does not update when there is no refresh of Dashticz.
Also I can’t show 2 times weather_owm, one with day interval and other with 3 hours interval. Is that possible too?
Lokonli
I've checked the code, but indeed, weather_owm (and weather) don't have any refresh functionality.
I'll improve this in a next update, including support for multiple blocks with different block parameters.
whoami
- Target OS: -
That would be nice!Lokonli wrote: Tuesday 19 January 2021 17:43 I've checked the code, but indeed, weather_owm (and weather) don't have any refresh functionality.
Where can I check the new releases?
Lokonli
here in the forum
whoami
- Target OS: -
I see there is a new beta, is this also in the update I can't find in the release notes, but maybe it is not described.Lokonli wrote: Tuesday 19 January 2021 17:43 I've checked the code, but indeed, weather_owm (and weather) don't have any refresh functionality.
Lokonli
No, weather update/refresh has not been implemented yet.
whoami
- Target OS: -
Do you know already a planning when it is possibleto refresh the weather block?Lokonli wrote: Wednesday 27 January 2021 12:12 No, weather update/refresh has not been implemented yet.
And in v3.7.3 you decribed that you could add 2 of the same blocks, but how can I add the weather_owm 2 times?
One with the 3 hour interval and 1 with the daily interval, in the config lines I can only choose between day or hourly updatess
(I know that you're doing a great job, don't get rushed by my question
