Sorry for question, since I'm newbie in dzVents, there is a lot of things I don't know. I'm reading the wiki, but still I'm confused with some concepts.
I want to give a variable a value (value 1) if a device changes its state 3 or more times in a minute. In other case value should be 0 by default.
In that way, I can use that variable to start one or other script depending its value.
What I don't know if it's possible to evaluate if a device has changed x times in a period of time. could be possible?
Thanx in advance. Very interesting all the capabilities the system offer. It's great. I've achieved already control surplus of PV installation and give power to three resistences (in waterfall sequence, for heating house) and system looks very robust¡¡
activate from change state in a device
- waaren
Re: activate from change state in a device
Could look like below examplezuputrus wrote: Saturday 23 January 2021 16:47 I want to give a variable a value (value 1) if a device changes its state 3 or more times in a minute. In other case value should be 0 by default.
return
on =
devices =
'myDevice', -- change to your device name
logging =
level = domoticz.LOG_DEBUG,
marker = '3 in a row',
data =
deviceHistory =
initial =
firstTime = ( os.time() - 61 ),
counter = 0,
lastState = 'unknown',
execute = function(dz, item)
local myVar = dz.variables('threeChanges') -- your varname as type integer with initial value of 0
if dz.data.deviceHistory.lastState ~= item.state then
dz.log(item.name ..' changed state from ' .. dz.data.deviceHistory.lastState .. ' to ' .. item.state
.. ' (' .. item.lastUpdate.secondsAgo .. ' seconds ago)' , dz.LOG_DEBUG )
dz.data.deviceHistory.lastState = item.state
if dz.data.deviceHistory.firstTime < ( os.time() - 60 ) then -- last State change more then 60 seconds ago
dz.data.deviceHistory.firstTime = os.time()
dz.data.deviceHistory.counter = 1
dz.data.deviceHistory.counter = dz.data.deviceHistory.counter + 1
dz.log('Number of times the state changed is ' .. dz.data.deviceHistory.counter, dz.LOG_DEBUG )
if dz.data.deviceHistory.counter >= 3 then
if myVar.value == 0 then
dz.log('Setting the var to 1', dz.LOG_DEBUG )
myVar.cancelQueuedCommands()
myVar.set(1)
myVar.set(0).afterSec(60).silent()
dz.data.deviceHistory.counter = 0
dz.log('Var already set to 1', dz.LOG_DEBUG )
zuputrus
- Domoticz version: 2022.1
Thanks a lot Waaren¡¡ I'm going to work with it. I'll tell you how it works. Great¡
