activate from change state in a device
zuputrus
Domoticz version: 2022.1
Post by zuputrus »
Sorry for question, since I'm newbie in dzVents, there is a lot of things I don't know. I'm reading the wiki, but still I'm confused with some concepts.
I want to give a variable a value (value 1) if a device changes its state 3 or more times in a minute. In other case value should be 0 by default.
In that way, I can use that variable to start one or other script depending its value.
What I don't know if it's possible to evaluate if a device has changed x times in a period of time. could be possible?
Thanx in advance. Very interesting all the capabilities the system offer. It's great. I've achieved already control surplus of PV installation and give power to three resistences (in waterfall sequence, for heating house) and system looks very robust¡¡
Re: activate from change state in a device
zuputrus wrote: Saturday 23 January 2021 16:47 I want to give a variable a value (value 1) if a device changes its state 3 or more times in a minute. In other case value should be 0 by default.
Could look like below example
return
    on =
        devices =
            'myDevice', -- change to your device name
    logging =
        level = domoticz.LOG_DEBUG,
        marker = '3 in a row',
    data =
        deviceHistory =
            initial =
                firstTime = ( os.time() - 61 ),
                counter = 0,
                lastState = 'unknown',
    execute = function(dz, item)
        local myVar = dz.variables('threeChanges') -- your varname as type integer with initial value of 0
        if dz.data.deviceHistory.lastState ~= item.state then
            dz.log(item.name ..' changed state from ' .. dz.data.deviceHistory.lastState .. ' to ' .. item.state
                            .. ' (' .. item.lastUpdate.secondsAgo .. ' seconds ago)' , dz.LOG_DEBUG )
            dz.data.deviceHistory.lastState = item.state
            if dz.data.deviceHistory.firstTime < ( os.time() - 60 ) then  -- last State change more then 60 seconds ago
                dz.data.deviceHistory.firstTime = os.time()
                dz.data.deviceHistory.counter = 1
                dz.data.deviceHistory.counter = dz.data.deviceHistory.counter + 1
                dz.log('Number of times the state changed is ' .. dz.data.deviceHistory.counter, dz.LOG_DEBUG )
                if dz.data.deviceHistory.counter >= 3 then
                    if myVar.value == 0 then
                        dz.log('Setting the var to 1', dz.LOG_DEBUG )
                        myVar.cancelQueuedCommands()
                        myVar.set(1)
                        myVar.set(0).afterSec(60).silent()
                        dz.data.deviceHistory.counter = 0
                        dz.log('Var already set to 1', dz.LOG_DEBUG )
zuputrus
Post by zuputrus »
Thanks a lot Waaren¡¡ I'm going to work with it. I'll tell you how it works. Great¡
