Dashticz - Module - 112 Meldingen (Dutch) Topic is solved
FinalX
Re: Dashticz - Module - 112 Meldingen (Dutch)
Post by FinalX »
ik looks like the block is not reading the config file at all.
config file:
blocks['alarmmeldingen'] = {
title: 'Alarm meldingen',
rss: 'https://alarmeringen.nl/feeds/city/hoeven.rss',
filter: 'Hoeven', //filter the messages for your town and if you want the cities around you
show_lastupdate: true,
width: 12,
refresh: 300, //refresh rate in seconds
results: 5 //number of recent results to show
Lokonli
Post by Lokonli »
That indeed seems to be the default block.
Do you maybe redefine the alarmmeldingen block a second time?
If you post your complete CONFIG.js I'll have a look.
FinalX
Post by FinalX »
found it :D
Last edited by FinalX on Wednesday 30 December 2020 13:57, edited 1 time in total.
Lokonli
Post by Lokonli »
On line 86 you redefine blocks={}.
The alarmmeldingen definition is then lost.
Lokonli
Post by Lokonli »
Lokonli wrote: Wednesday 30 December 2020 13:42 On line 86 you redefine blocks={}.
and line 483 as well. You can remove it.
FinalX
Post by FinalX »
NVM found it i moved alarm meldingen to my blocks section now it works.
hsvt
Post by hsvt »
Is it possible to play a sound when there is a new notification?
