Zigate plugin Error on Synology: fatal signal 11
Knarf99
Post by Knarf99 »
After having installed the Zigate plugin on my Syno DS215+ and restarting Domoticz, everything works fine.
However, when I add the hardware (Zigate USB) the web UI of Domoticz is not accesible anymore ("hangs") but Domoticz runs when I inspect the package center.
I managed to catch this from the log:
zigate error.JPG (70.6 KiB) Viewed 381 times
pipiche
Re: Zigate plugin Error on Synology: fatal signal 11
Post by pipiche »
That is a known issue on syno, please do edit the file
Conf/PluginConf-xx.json where xx is the HardwareID in Domoticz
and add the following line in that file (please do keep the syntax correct in the file, so I suggest that you put it in the middle of the file)
"internetAccess": 0,
Knarf99
Post by Knarf99 »
Thnx for your quick reply pipiche, did read your suggestion already, but it did not solve the problem.
When I delete the Zigate folder, Domoticz works fine again.
But that soes not solve the problem of course. Any other suggestions?
pipiche
Post by pipiche »
Please provide the full log when starting the plugin
Please provide the file PluginConf-xx.json
Knarf99
Post by Knarf99 »
Just installed the plugin again, (this time not via putty and "sudo git clone ...." command, but just copying the folder with Winscp).
Added the hardware again and guess what: it works!
Don't know if the different installation method did the trick?
pipiche
Post by pipiche »
Maybe some access right issues
