Adding the values of one month for these two tables together is what I showed in my previous post. Below script will do that for all months.bofisko wrote: Tuesday 22 December 2020 1:52 It is not working. I get tablecool and tableheat but no together table.
How can I do it? I need this in want.jpg in attachment.
The code is all standard Lua, without any link to domoticz, so please visit the official Lua documentation site if you need more clarification
local id = fibaro:getSelfId();
local ip = fibaro:get(id, "IPAddress");
local port = fibaro:get(id, "TCPPort");
local Daikin = Net.FHttp(ip, port)
function tprint (t, indent, done)
local done = done or {}
indent = indent or 0
for key, value in pairs (t) do
pre = (string.rep (" ", indent)) -- indent it
if type (value) == "table" and not done[value] then
done [value] = true
fibaro:debug(pre .. tostring (key) .. ":");
tprint (value, indent + 2, done)
elseif type(value) == 'function' and not done[value] then
fibaro:debug( pre .. (tostring (key) .. "()"))
pre = pre .. (tostring (key) .. ": ")
fibaro:debug(pre .. tostring(value))
r,s,e = Daikin:GET("/aircon/get_year_power_ex")
if e == 0 then
local a = {}
local myTable = {}
for v in r:gmatch('([^,]+)') do
table.insert(a, v)
local function sum(line)
local total = 0
local myTable = {}
for str in line:gmatch("(%d+)" ) do
table.insert(myTable, str)
total = total + tonumber(str)
return myTable, total
-- creating heating and cooling table
local myHeatingTable, heatingTotal = sum(a[2])
local myCoolingTable, coolingTotal = sum(a[4])
-- creating totalized table and sum
local myTotalizedTable = {}
local yearTotal = 0
for key, value in ipairs(myHeatingTable) do
table.insert(myTotalizedTable, value + myCoolingTable[key] )
yearTotal = yearTotal + myTotalizedTable[#myTotalizedTable]
fibaro:debug('-- Now dumping table a')
tprint(a)
fibaro:debug('-- Now dumping heating and cooling and Total tables')
tprint(myHeatingTable)
tprint(myCoolingTable)
tprint(myTotalizedTable)
thisMonth = math.floor(os.date('%m'))
fibaro:debug('Month total : ' .. thisMonth ..' - '.. myTotalizedTable[thisMonth] )
fibaro:debug('Year total: ' .. yearTotal )
