LUA scene string Topic is solved
Re: LUA scene string
bofisko wrote: Tuesday 22 December 2020 1:52 It is not working. I get tablecool and tableheat but no together table.
How can I do it? I need this in want.jpg in attachment.
Adding the values of one month for these two tables together is what I showed in my previous post. Below script will do that for all months.
The code is all standard Lua, without any link to domoticz, so please visit the official Lua documentation site if you need more clarification
local id = fibaro:getSelfId();
local ip = fibaro:get(id, "IPAddress");
local port = fibaro:get(id, "TCPPort");
local Daikin = Net.FHttp(ip, port)
function tprint (t, indent, done)
	local done = done or {}
	indent = indent or 0
	for key, value in pairs (t) do
		pre = (string.rep (" ", indent)) -- indent it
		if type (value) == "table" and not done[value] then
			done [value] = true
			fibaro:debug(pre .. tostring (key) .. ":");
			tprint (value, indent + 2, done)
		elseif type(value) == 'function' and not done[value] then
			fibaro:debug( pre .. (tostring (key) .. "()"))
			pre = pre .. (tostring (key) .. ": ")
			fibaro:debug(pre .. tostring(value))
r,s,e = Daikin:GET("/aircon/get_year_power_ex")
if e == 0 then
	local a = {}
	local myTable = {}
	for v in r:gmatch('([^,]+)') do
		table.insert(a, v)
	local function sum(line)
		local total = 0
		local myTable = {}
		for str in line:gmatch("(%d+)" ) do
			table.insert(myTable, str)
			total = total + tonumber(str)
		return myTable, total
	-- creating heating and cooling table
	local myHeatingTable, heatingTotal = sum(a[2])
	local myCoolingTable, coolingTotal = sum(a[4])
	-- creating totalized table and sum
	local myTotalizedTable = {}
	local yearTotal = 0
	for key, value in ipairs(myHeatingTable) do
		table.insert(myTotalizedTable, value + myCoolingTable[key] )
		yearTotal = yearTotal + myTotalizedTable[#myTotalizedTable]
	fibaro:debug('-- Now dumping table a')
	tprint(a)
	fibaro:debug('-- Now dumping heating and cooling and Total tables')
	tprint(myHeatingTable)
	tprint(myCoolingTable)
	tprint(myTotalizedTable)
	thisMonth = math.floor(os.date('%m'))
	fibaro:debug('Month total : ' .. thisMonth ..' - '.. myTotalizedTable[thisMonth] )
	fibaro:debug('Year total: ' .. yearTotal )
bofisko
Post by bofisko »
THANK YOU NOW I WORKING... If you send me privat message a I would like to somehow reward you for your perfect work.
And I apologize once again for my amateurism.
bofisko wrote: Tuesday 22 December 2020 12:11 THANK YOU NOW I WORKING
I do not look for another reward then your thx. Happy that I could be of any help.
bofisko
Post by bofisko »
waaren wrote: Tuesday 22 December 2020 12:15
Then just one thing - many thanks. And I will finish here by publishing a VD for measuring air conditioning consumption if anyone is interested.
