Any idea what causes it?
Grayed-out UI item in Utility Sensors Topic is solved
- philchillbill
Just noticed something I've never seen before, a dark/grayish UI entry for one of my sensors:
- waaren
Re: Grayed-out UI item in Utility Sensors
Is this on the default theme?philchillbill wrote: Tuesday 01 December 2020 18:57 Just noticed something I've never seen before, a dark/grayish UI entry for one of my sensors:
- philchillbill
Yeswaaren wrote:Is this on the default theme?philchillbill wrote: Tuesday 01 December 2020 18:57 Just noticed something I've never seen before, a dark/grayish UI entry for one of my sensors:
MikeyMan
Greyed out sensor
Just noticed today; one of the sensors being greyed out:
It is working; didn't see it before. What could this be?
Br,
Michael
Br,
Michael
MikeyMan
Anyone got any clue what causes this?
JohnOosterlaken
I have the same "issue" also with the water meter.
JohnOosterlaken
if fixed it by recreating the item via the GUI and not using a url.
it seems that this way the hardware type is not unknown anymore.
MikeyMan
Doesnt that screw up the history?JohnOosterlaken wrote: Wednesday 23 December 2020 21:39 if fixed it by recreating the item via the GUI and not using a url.
free_nsc
Go into Hardware -> select relevant item and check off Enabled tick box ☑ then click update
MikeyMan
Its not under hadeware i'm afraid.
- waaren
In domoticz terms a device object is connected to a hardware object.
If the hardware object is disabled (look at the hardware tab of your GU) and the hardware is one of the Python plugins, the device object tiles connected to that hardware object are greyed out in the switches-, weather, utility or temperature tab.
MikeyMan
Hmm... Strange... I recall it's always been the same, just not greyed out:
I dont think i ever had any hardware attached... And it is working as it should...
Very weird...
Very weird...
- waaren
It should not be possible to create a device without a 'parent' hardware without entering it directly in the database using an external program.MikeyMan wrote: Monday 25 January 2021 10:53 I dont think i ever had any hardware attached... And it is working as it should...
Also: devices are removed from the system when the 'parent' hardware is deleted in domoticz.
I can only guess what's happened but assume that some time in the past the hardware that this device was connected to was removed with an external program or something else in the database happened causing the connection between your device and the 'parent' to got lost.
I don't see any direct issue for the state of the system other then the greyed out tile but to be sure I would reconnect it to one of your hardware objects.
To identify all devices without a 'parent' hardware and to show all hardware objects can you please do
dzDir=/home/pi/domoticz # change to your domoticz dir
sudo sqlite3 --header $dzDir/domoticz.db "SELECT Name, Id , HardwareID FROM DeviceStatus WHERE HardwareID NOT IN (SELECT ID FROM Hardware)"
sudo sqlite3 --header $dzDir/domoticz.db "SELECT Id, Enabled, Type, Name FROM Hardware"
MikeyMan
Followed this guide:
https://ehoco.nl/watermeter-uitlezen-in ... on-script/
Dont see any hardware created here if i'm correct. So maybe the guide is not good
- waaren
The guide is not complete.MikeyMan wrote: Monday 25 January 2021 11:49 Followed https://ehoco.nl/watermeter-uitlezen-in ... on-script/
in the line http: //192.168.2.152:8080/json.htm?type=createvirtualsensor&idx=29&sensorname=Water&sensortype=113 ,
29 is the hardware ID. You should change that number to the ID of one of your hardware objects and preferable your "Dummy (Does nothing, use for virtual switches)" hardware as it shown on the hardware tab.
MikeyMan
Can i run that now still? Or will that mess up the history?waaren wrote: Monday 25 January 2021 12:04The guide is not complete.MikeyMan wrote: Monday 25 January 2021 11:49 Followed https://ehoco.nl/watermeter-uitlezen-in ... on-script/
- waaren
No don't do that. Can you execute the sqlite3 commands I posted earlier? With that information I can advise you how to solve it.MikeyMan wrote: Monday 25 January 2021 14:02 Can i run that now still? Or will that mess up the history?
MikeyMan
Sure!
Name|ID|HardwareID
Water|43|29
pi@raspberrypi:~ $ sudo sqlite3 --header $dzDir/domoticz.db "SELECT Id, Enabled, Type, Name FROM Hardware"
ID|Enabled|Type|Name
1|1|67|Domoticz Internal
2|1|4|Slimme Meter
3|1|75|Evohome
5|1|64|Zonnepanelen
6|1|15|Somfy Alarm
9|1|78|Weer
10|1|15|Graaddagen
11|1|15|Tempsensoren
13|1|94|Shelly
14|1|15|Backup
19|1|21|Zwave- waaren
OK. You can doMikeyMan wrote: Monday 25 January 2021 15:20Code: Select all
sudo sqlite3 --header $dzDir/domoticz.db "SELECT Name, Id , HardwareID FROM DeviceStatus WHERE HardwareID NOT IN (SELECT ID FROM Hardware)" Name|ID|HardwareID Water|43|29 sudo sqlite3 --header $dzDir/domoticz.db "SELECT Id, Enabled, Type, Name FROM Hardware" ID|Enabled|Type|Name 1|1|67|Domoticz Internal
sudo service domoticz stop
sudo cp $dzDir/domoticz.db domoticz.db_keep # just to be sure
sudo sqlite3 $dzDir/domoticz.db "UPDATE DeviceStatus SET HardwareID = 1 WHERE ID = 43"
sudo service domoticz start
MikeyMan
That fixed it!
Is that a reserved hardware ID? The internal one?
