Smart meter plugin tramsmits strange MQTT messages
willem9136
Post by willem9136 »
When I look at the MQTT traffic by using my MQTT tool I see strange messages coming from the smart-meter plugin.
Please have a look at the 2 attachements.
The come in groups of 4 around every 5 seconds.
can someone tell me the cause of this and is this normal behaviour?
header
header
payload
payload
Re: Smart meter plugin tramsmits strange MQTT messages
willem9136 wrote: Monday 14 December 2020 9:16 When I look at the MQTT traffic by using my MQTT tool I see strange messages coming from the smart-meter plugin.
  • is your smart-meter plugin the P1 Smart Meter USB or P1 Smart Meter LAN ( on the hardware tab ) or do you refer to something else?
  • what tool do you use to look at the MQTT messages?
  • can you try to monitor MQTT traffic on your RPI with
    mosquitto_sub -F "%U - %t - %p" -v -p 1883 -t "#"
willem9136
Hello Waaren, I use the USB version of the P1 smart-meter plug in.
I use the MQTTool on my iPad. See attachement.
And the MQTT traffic log is in the attachements as well.
mqtt.log
(8.82 KiB) Downloaded 37 times
willem9136 wrote: Monday 14 December 2020 10:16 Hello Waaren, I use the USB version of the P1 smart-meter plug in.
What you call a plugin is generally referred to as Hardware module (native part of domoticz). This to prevent confusion with the various Python plugins
I use the MQTTool on my iPad. See attachment.
So it seems this tool does see things that are not send by domoticz.
willem9136
There is nothing else on this PI-0 running. I killed NodeRed.
I know when I stop Domicticz these messages will stop.
Also when I remove the P1 smartMeter for USB the messages will stop.
eddieb
Post by eddieb »
looks like domoticz is sending confirmations of the P1 signals thru MQTT using domoticz/out
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
willem9136
So nothing to worry about?
It’s strange that this showed up since last week.
Before they were not there.
erem
Domoticz version: 2021.1
Post by erem »
@willem9136
which poses the question: What changed? Did you update domoticz?
Regards,
Rob
willem9136
All I did was removing NodeRed. And for testing I killed Domoticz to check if the messages disappeared. They did so I did a reboot.
Then I removed the hardware module P1 for USB.
Also the messages stopped.
Reinstalled the P1 smartmeter USB again. And the messages were there.....
willem9136
I did not update Domoticz. I did press the update button but Domoticz was up to date.
willem9136 wrote: Monday 14 December 2020 14:08 All I did was removing NodeRed.
According to this post you also started the MQTT hardware module. That would explain the MQTT message to domoticz/out but not the funny ones with only "{"
These are not send by domoticz.
willem9136
Why do they stop when I remove the P1 plug-in?
willem9136 wrote: Monday 14 December 2020 23:14 Why do they stop when I remove the P1 plug-in?
Because the real MQTT messages to domoticz/out for the P1 device are send when the P1 device is updated and this device gets updated via the P1 hardware module. The funny ones seem to be a kind of echo created by something else then domoticz.
If you want to convince yourself and your are not convinced by the mosquitto_sub command I posted earlier then install a network sniffer tool and monitor the network for port 1883
sudo apt install tcpdump
sudo tcpdump -vv -X -i any  port 1883
willem9136
Ok, I will run WireShark on it. Good idea!
FireWizard
Post by FireWizard »
Hi, @willem9136
Can you tell us, which steps you toke when you removed Node Red?
willem9136
I read in an American forum that these “strange” MQTT messages and by domoticz/out are normal.
