Fibaro FGBS-001 sensors lost
Ron
Domoticz version: 2.2284
Post by Ron »
My Fibaro FGBS-001 sensor has been working perfectly for years, but a few weeks ago the three one-wire sensors lost connection to Domoticz.
On the temperature tab you van see they last connected at 26-11-2020:
Sensors Domoticz.JPG (51.21 KiB) Viewed 823 times
While looking at the hardware tab, Aeotec Z-Stick S2, settings, you can see that the Fibaro Sensor is active:
Binaire sensor actief.JPG (16.61 KiB) Viewed 823 times
While looking at the OpenZwave control panel you can see that the temperature sensors are working and are showing the right temperatures:
OZW Control panel.JPG (52.01 KiB) Viewed 823 times
So, i think the sensor is fine but the Z-Wave stick is not corresponding the temperatures to the Domoticz dashboard.
Maybe a kind of database problem?
Wat could be wrong?
Ron
Re: Fibaro FGBS-001 sensors lost
Post by Ron »
Nobody any idea?
Ron
Post by Ron »
So, i have to answer myself...
After a month, three new sensors suddenly were visibly as "new" unused devices.
Now these devices appear as "Temp + Humidity WTGR800" ones, this is strange as in fact they are DS18B20 one wire sensors...
So i deleted the old ones as they didn't work and added the three new devices.
Updating the old ones whith the new ones was not possible.
dmtcaz
Domoticz version: 2022.2
Post by dmtcaz »
Check out this one:
viewtopic.php?p=264337#p264337
I run Domoticz as a service on a RPi3B armv7 Buster
Z-wave (Aeotec GEN5 usb-stick), Hue, Mqtt, loads of switches, lights, and sensors.
Everspring, Fibaro, Qubino.
