LED strip lights RGB WIFI Smart Controller
Does anyone have any experience with this LED strip lights RGB WIFI Smart Controller?
https://www.aliexpress.com/store/produc ... 7651.html
Or:
https://www.aliexpress.com/item/DC-5V-1 ... autifyAB=0
Can it be controlled from Domoticz? I've read that it can be turned on/off but no full support for color changing.
I'm looking for a cheap led strip controller to control from Domoticz?
I have a RFLink running, so an 433 controller is also possible.
Thanks,
Jos Vink
Or:
Thanks,
Jos Vink
- Domoticz version: V2024.4
Re: LED strip lights RGB WIFI Smart Controller
yes the wifi one should work with the Arilux AL-LC0x hardware, have two of them
- Domoticz version: 4.10717
Can I use this with the latest stable version?
What do I have to enter as hardware?
What would be recommended?
This should go on and off and I would also like to have one or more colors displayed at a certain time.
Today, I installed this controller which I got from AliExpress. Just add hardware of type Arilux AL-LC0x. Then link to your controller by entering its IP address.
Which colour and white stripes can you recommend?
Hi, just quick question.
If Arilux AL-LC0x is supported, does it mean that AL-LC11 (orLC10) is not? Or is it just the name of whole standard.
https://www.banggood.com/ARILUX-AL-LC11 ... rehouse=CN
- Domoticz version: 3.8153
On aliexpress i only found the Arilux Al-LC11 12 and 13. Are these also full supported in domoticz?
Does anyone know?CaesarPL wrote:Hi, just quick question.
- Domoticz version: 2024.7
I got the Arilux AL-LC02 like this https://www.aliexpress.com/store/produc ... 47651.html
Activated the Arilux worker in Domoticz V4.9700 on Synology and I made in Switches a Device with the name of the Hardware and type Dimmer and type LightwaveRF with its IP-address. In the logfile in the Arilux I can see it recieves HTTP-commands. So far, so good. But then I am wondering how further on..
Uploaded ESP Easy Mega GIT version mega-20190202, version ESP8285 to it but that has no plugin in it for PWM...
No hints in the Wiki so can someone explain how he got them working??
Synology with Domoticz build (V2024.7) in Docker
- Domoticz version: 2022.2
Today I got this working in 15min. Aliexpress https://www.aliexpress.com/item/3281541 ... 4c4dit8usx
Download the associated APP, change the IP address and SSID to your LAN and Wifi and add hardware of type Arilux AL-LC0x.
Works like a charm.
Works like a charm.
How? I got one also. Installed the app. Made a note of the IP. In Domoticz I added Arilux under 'hardware' then 'add light' and added my controllers IP address. It now appears under devices, and I can click it on an off, but I'm trying to control it using scrips (dzVents) and am having absolutely zero joy. Scripts which work fine for other lights, when I change the device to my shiny new Arilux I just get log entries saying ' attempt to call a nil value (field 'LedOff')' or 'attempt to call a nil value (field 'setRGB')' or 'attempt to call a nil value (field 'switchOff')' etc.DickNL wrote: ↑Saturday 05 September 2020 18:23 Today I got this working in 15min. Aliexpress https://www.aliexpress.com/item/3281541 ... 4c4dit8usx
Works like a charm.
Can anyone help please?
Bob
Bob, Your problem consists of not being able to get a LED strip to work at all or having trouble controlling it by script(s)? I can help you making it work, yet not with scripting.
