LED strip lights RGB WIFI Smart Controller
josvink66
Post by josvink66 »
Does anyone have any experience with this LED strip lights RGB WIFI Smart Controller?
https://www.aliexpress.com/store/produc ... 7651.html
Or:
https://www.aliexpress.com/item/DC-5V-1 ... autifyAB=0
Can it be controlled from Domoticz? I've read that it can be turned on/off but no full support for color changing.
I'm looking for a cheap led strip controller to control from Domoticz?
I have a RFLink running, so an 433 controller is also possible.
Thanks,
Jos Vink
zak45
Domoticz version: V2024.4
Re: LED strip lights RGB WIFI Smart Controller
Post by zak45 »
yes the wifi one should work with the Arilux AL-LC0x hardware, have two of them
ProjektC
Domoticz version: 4.10717
Post by ProjektC »
Can I use this with the latest stable version?
What do I have to enter as hardware?
What would be recommended?
This should go on and off and I would also like to have one or more colors displayed at a certain time.
Muyz
Post by Muyz »
Today, I installed this controller which I got from AliExpress. Just add hardware of type Arilux AL-LC0x. Then link to your controller by entering its IP address.
ProjektC
Post by ProjektC »
Which colour and white stripes can you recommend?
CaesarPL
Post by CaesarPL »
Hi, just quick question.
If Arilux AL-LC0x is supported, does it mean that AL-LC11 (orLC10) is not? Or is it just the name of whole standard.
https://www.banggood.com/ARILUX-AL-LC11 ... rehouse=CN
denman091
Domoticz version: 3.8153
Post by denman091 »
On aliexpress i only found the Arilux Al-LC11 12 and 13. Are these also full supported in domoticz?
denman091
Post by denman091 »
CaesarPL wrote:Hi, just quick question.
Does anyone know?
PieterS
Domoticz version: 2024.7
Post by PieterS »
I got the Arilux AL-LC02 like this https://www.aliexpress.com/store/produc ... 47651.html
Activated the Arilux worker in Domoticz V4.9700 on Synology and I made in Switches a Device with the name of the Hardware and type Dimmer and type LightwaveRF with its IP-address. In the logfile in the Arilux I can see it recieves HTTP-commands. So far, so good. But then I am wondering how further on.. :roll:
Uploaded ESP Easy Mega GIT version mega-20190202, version ESP8285 to it but that has no plugin in it for PWM...
No hints in the Wiki so can someone explain how he got them working??
Muyz wrote: Wednesday 31 January 2018 21:39 Today, I installed this controller which I got from AliExpress. Just add hardware of type Arilux AL-LC0x. Then link to your controller by entering its IP address.
Synology with Domoticz build (V2024.7) in Docker
DickNL
Domoticz version: 2022.2
Post by DickNL »
Today I got this working in 15min. Aliexpress https://www.aliexpress.com/item/3281541 ... 4c4dit8usx
Download the associated APP, change the IP address and SSID to your LAN and Wifi and add hardware of type Arilux AL-LC0x.
Works like a charm.
holybob
Post by holybob »
DickNL wrote: Saturday 05 September 2020 18:23 Today I got this working in 15min. Aliexpress https://www.aliexpress.com/item/3281541 ... 4c4dit8usx
Works like a charm.
How? I got one also. Installed the app. Made a note of the IP. In Domoticz I added Arilux under 'hardware' then 'add light' and added my controllers IP address. It now appears under devices, and I can click it on an off, but I'm trying to control it using scrips (dzVents) and am having absolutely zero joy. Scripts which work fine for other lights, when I change the device to my shiny new Arilux I just get log entries saying ' attempt to call a nil value (field 'LedOff')' or 'attempt to call a nil value (field 'setRGB')' or 'attempt to call a nil value (field 'switchOff')' etc.
Can anyone help please?
Bob
DickNL
Post by DickNL »
Bob, Your problem consists of not being able to get a LED strip to work at all or having trouble controlling it by script(s)? I can help you making it work, yet not with scripting.
