Sonoff ZBMini in Phoscon/deCONZ etc not working
Dave21w
Domoticz version: Stable
Post by Dave21w »
Have I got ahead of myself here, I thought the ZBmini was already supported by Phoscon/deConz etc. When trying to pair it Phoscon see's nothing but it does appear in deCONZ and in Domoticz however if it's off I can turn it on in Domoticz but it's icon always shows off and I can't switch it off from Domoticz, toggling it's state using the button or switch contact on the device do not change anything in Domoticz.
Also deCONZ see's the vendor as Heiman not Sonoff or iTead ?
Any pointers would be appreciated
Dave
Thorgal789
Re: Sonoff ZBMini in Phoscon/deCONZ etc not working
Post by Thorgal789 »
Hello
If you have the deconz GUI.
- In phoscon, "add new light"
- Then return in deconz and read the basic attribute (Basic cluster 0x0000, press the "read" button)
I think it will be enought, but if you have some time, I will be happy if you can send me the log (deconz one, not domoticz) during the inclusion when it fail (and have heiman) so before doing the previous manipulation, else you will no more have "heiman"
- Go in help / log, take "info" and "info_l2"
- Re include the device
I need the part about "missing manufacture name"
Dave21w
Post by Dave21w »
So, I go into deconz and click the help button I only have User Manual or About deCONZ, no option for log or anything else ?
Thorgal789
Wich one deconz version have you ?
It seem it work out of the box, but the issue on this device is 1 month old https://github.com/dresden-elektronik/d ... ssues/3632
But don't worry for log, I just need them to solve the "heiman" bug, if you don't want to update your version, you can just try the procedure for the inclusion, if will find the log somewhere else.
Dave21w
Post by Dave21w »
Hi, my version is
I'm happy to update to get the log, I assumed obviously wrongly that my version was current as it's number matches that of Phoscon which states its up to date.
The really strange thing is that after being left on for a few hours the zbmini and domoticz were fine, stayed in sync etc but just after install it didnt work properly at all.
Dave
Thorgal789
It happen generally for sensor, the inclusion for deconz is realy complicated, and for lazy sensor, realy miss often, but deconz use some monitoring that work automticaly when problem are detected, for exemple the polling is trigger when the reporting stop working, and is disabled automatically at next report.
But your device is a powered one, so .... (magic ?)
And yes your version is realy old ^^, we are ATM on deconz version v2.6.0 equal at V 2.05.88, you are 10 version old.
The message "the version is up to date" is not for deconz version but the firmware version according to your deconz version. If you update deconz, this message will change for purpose the new firmware.
But don't worry, if you don't need it, don't update it ^^, update can be worse than old version. And if you want to update, never forget the backup.
Dave21w
Post by Dave21w »
OK thanks for the reply, think I will wait for the weekend and take an image of my Pi SSD before I decide to upgrade anything !!
Thorgal789
But even if you want to upgrade all your system, and make a macke of the whole system, make too a zigbee backup trought phoscon, on this one you can backup too the setting present in the conbee.
