Tasmota Domoticz
Piacco
Tasmota Domoticz
Post by Piacco »
I'm using the Houzetek 4AC 3USB Power Strip, flashed with Tasmota 9.1.0.
Everytink works fine exception relay 5, i can't configure it in the domoticz tab, i can only configure 4 relays.
I've tried to make a rule, but this one is not working.
Rule1 ON command#idx =1066 DO POWER5 toggle ENDON
Has someone an sollution for this?
Greeting Piacco
besix
Re: Tasmota Domoticz
Post by besix »
This can be
rule on POWER5#state=1 DO publish domoticz/in {"idx":XXX,"nvalue":1} endon on POWER5#state=0 DO publish domoticz/in {"idx":XXX,"nvalue":0} endon
rule1 1
Piacco
Post by Piacco »
Thanks,
but this only worked from tasmota to domoticz and not from domoticz to tasmota :oops:
This rule
rule3 on domoticz/out#idx=1067 DO Power5 toggle ENDON
also does'n work
besix
Post by besix »
In domoticz you can use http commands in the actions of the On / OFF switch
add
http://192.168.x.xxx/cm?cmnd=Power5%20On
http://192.168.x.xxx/cm?cmnd=Power5%20off
192.168.x.xxx - is the IP of the module from tasmota
If you have the password for tasmota web
then http commands
http://192.168.x.xxx/cm?user=admin&password=xxxxxxx&cmnd=Power5%20On
Piacco
Post by Piacco »
Thanks, that did the trick :D
Now it works like a charm
