"Power usage to high" Error logged by P1 and Enphase hardware
rrozema
Post by rrozema »
I get the below error listed in my Domoticz log several times since I had my kitchen redone. A quooker, microwave, oven plus an induction cooker where installed. Naturally sufficient new groups were added. Since this time however I see these error messages logged in Domoticz. I wasn't aware that there was such a setting. Can someone please show me where to reconfigre this 'Max Usage" setting?
The erorr is even logged twice. Once by the P1 meter hardware, plus another time by the Enphase hardware (solar panel Envoy-S metered installed for metering). I would like to get rid of these error messages, as they are not an error at all. My net connection is rated for at least 8KW.
2020-11-23 14:51:21.317 Error: P1 Meter: Power usage to high! Usage: 5620 Watt. Max Usage configured: 4000. (NodeID: 0x0000, ChildID: 0x0001, SID: Usage L1)
2020-11-23 14:51:41.913 Error: Enphase: Power usage to high! Usage: 5098 Watt. Max Usage configured: 4000. (NodeID: 0x0002, ChildID: 0x0003, SID: Enphase kWh Net
rrozema
Re: "Power usage to high" Error logged by P1 and Enphase hardware
Post by rrozema »
Found it... It's in the settings for Domoticz under Meters/Tellers, labeled "Max Power".
rrozema wrote: Monday 23 November 2020 15:28 Found it... It's in the settings for Domoticz under Meters/Tellers, labeled "Max Power".
Recent changes in beta can be found / identified on this wiki page
rrozema
Post by rrozema »
Thanks waaren. Even after reading gizmocuz' writings I don't understand the logic of this feature. I have an induction cooker that on it's own can use over 4KW (the standard for these devices is to install them behind 2 16 Amp breakers). Run that cooker in combination with a dishwasher, quooker, microwave and oven, and 8KW can be reached occasionally. When I upgraded my kitchen I was worried about these numbers too, but the electrician from Stedin told me not to worry, it would work. And so far it does indeed. We have even accidently run the washing machine and dryer at overlapping times and it didn't cause a black-out yet.
Also the 16 solar panels on my roof generate well over 6KW on a sunny summer day. Again, this is much more than this 4KW limit. This check of 4KW is ridiculously low. Especially given that our government is pushing everyone away from natural gas, towards electric cooking, so this is going to happen in more and more households. Better find and fix the cause of those random incorrect values instead of dismissing perfectly valid values...
rrozema wrote: Monday 23 November 2020 19:44 Better find and fix the cause of those random incorrect values instead of dismissing perfectly valid values...
Fully agree if the prevention of these incorrect values could be done from within domoticz which is not the case in the issues created by other members of this forum. In latest Beta's a value of 6000 was chosen as an an initial value (first it was set at 4000) but this value can be adjusted to a much higher (or lower) value if that is what your household requires.
rrozema
Post by rrozema »
I have those random values too occasionally. Not just for electric power devices though, all devices seem to have these glitches. To me the values don't seem really random though: they look more like sign problems, negative values in an unsigned variable or other variations. It should be possible to find their cause, isn't it? This max power setting is only a work around for a small number of the issues, it doesn't fix anything and it's confusing to the users.
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
rrozema wrote: Monday 23 November 2020 23:08 I have those random values too occasionally. Not just for electric power devices though, all devices seem to have these glitches. To me the values don't seem really random though: they look more like sign problems, negative values in an unsigned variable or other variations. It should be possible to find their cause, isn't it? This max power setting is only a work around for a small number of the issues, it doesn't fix anything and it's confusing to the users.
Faced the same errors today. Thanks to your posting, I could find it quickly how to changes this level.
I second your opinion it is a work around to avoid some problems, does not fix anything.
Greetings McMelloW
fricosk
Domoticz version: 12252
Post by fricosk »
Mam ten istý problém skúšal som popisované kroky ale nepomohlo. Domoticz mi beží na Ubuntu servery
Domoticz V2020.2 (build 12711)
I have the same problem I tried the steps described but it didn't help. Domoticz runs on Ubuntu servers Domoticz V2020.2 (build 12711)
It's in the settings for Domoticz under Meters/Tellers, labeled "Max Power" položku nemám
2020-11-30 19:52:36.604 Error: P1 Meter: Power usage to high! Usage: 8760 Watt. Max Usage configured: 6000. (NodeID: 0x0000, ChildID: 0x0003, SID: Usage L3)
2020-11-30 19:52:42.124 Error: P1MeterTCP: Can not connect to: 172.27.1.10:8088
2020-11-30 19:52:46.624 Error: P1 Meter: Power usage to high! Usage: 6840 Watt. Max Usage configured: 6000. (NodeID: 0x0000, ChildID: 0x0002, SID: Usage L2)
2020-11-30 19:52:46.624 Error: P1 Meter: Power usage to high! Usage: 8760 Watt. Max Usage configured: 6000. (NodeID: 0x0000, ChildID: 0x0003, SID: Usage L3)
2020-11-30 19:52:56.644 Error: P1 Meter: Power usage to high! Usage: 6840 Watt. Max Usage configured: 6000. (NodeID: 0x0000, ChildID: 0x0002, SID: Usage L2)
2020-11-30 19:52:56.644 Error: P1 Meter: Power usage to high! Usage: 8760 Watt. Max Usage configured: 6000. (NodeID: 0x0000, ChildID: 0x0003, SID: Usage L3)
2020-11-30 19:53:06.666 Error: P1 Meter: Power usage to high! Usage: 6720 Watt. Max Usage configured: 6000. (NodeID: 0x0000, ChildID: 0x0002, SID: Usage L2)
2020-11-30 19:53:06.666 Error: P1 Meter: Power usage to high! Usage: 8880 Watt. Max Usage configured: 6000. (NodeID: 0x0000, ChildID: 0x0003, SID: Usage L3)
rrozema
Post by rrozema »
My Slovakian is a bit rusty ;-), I think you'll get a bigger audience if you post your question in English. Lucky for you we've got google translate and I was curious what you wrote ... This check was added in recent betas only. So if you get the error message you'll for sure also have the setting.
fricosk
Post by fricosk »
I greet but I did not find such a possibility
Bez názvu.jpg (129.76 KiB) Viewed 2658 times
fricosk wrote: Wednesday 02 December 2020 8:53 I greet but I did not find such a possibility
Please try again after clearing browsercache / appcache (different things)
fricosk
Post by fricosk »
And how do I do it? as a lama
fricosk wrote: Wednesday 02 December 2020 9:09 And how do I do it?
browser cache.png (10.47 KiB) Viewed 2639 times
fricosk
Post by fricosk »
Thank you helped until restart domoticz. ;)
I don't know if the problem has already been solved, it doesn't show performance values ​​but the subscription there is is graphing.
If I'm on the wrong topic please relocate.
Bez názvu1.jpg (86.33 KiB) Viewed 2636 times
Bez názvu.jpg (168.6 KiB) Viewed 2636 times
zicht
Domoticz version: 2023.1+
Post by zicht »
waaren wrote: Monday 23 November 2020 15:53
I am also seeing this messages in log in recent beta's
2020-12-06 11:10:08.875 Error: P1 Meter: Power usage to high! Usage: 6066 Watt. Max Usage configured: 6000. (NodeID: 0x0000, ChildID: 0x0001, SID: Usage L1)
2020-12-06 11:10:38.874 Error: P1 Meter: Power usage to high! Usage: 6044 Watt. Max Usage configured: 6000. (NodeID: 0x0000, ChildID: 0x0001, SID: Usage L1)
2020-12-06 11:12:38.869 Error: P1 Meter: Power usage to high! Usage: 6387 Watt. Max Usage configured: 6000. (NodeID: 0x0000, ChildID: 0x0001, SID: Usage L1)
Version: 2020.2 (build 12716)
Build Hash: ee672d111
Compile Date: 2020-12-02 08:53:23
In settings i have set Max Power: 8100 as this reflects my mains fuse 35A at 230V.
I will perform some further testing today, washing & drying & cooking & heating together.
In my opinion :
The prober setting for max power in settings should be related to mains voltage and main fuse value.
Not a random max value. In NL we have 230v +-10% and 1X25A 1x35A to 3x25A 3X35A or higher for business. (see https://www.mijnaansluiting.nl/bepalen- ... capaciteit) .So this is how domoticz should be configured ....
This has to be the user input somehow.
I am afraid my scripts that smart messages via Google speaker that alert on high power are effectively killed as it never can reach the real trigger values. I am under the impression not only Watt is dropped but also the ampere value is skipped. ( based on a quick test this morning)
The false spikes in power consumption i have seen in the past where always related to my solar panels, suddenly getting or loosing the sun = power in combination with high electricity use (current). But i have seen some strange reports of different situations from other users.
zicht wrote: Sunday 06 December 2020 13:24 This has to be the user input somehow.
And it is...
zicht
Post by zicht »
waaren wrote: Sunday 06 December 2020 14:02
And it is...
See just below the version data :)
I have set 8100 , but today still got the message in the log ....
Today with testing, again. Will update this evening to latest build and try again as soon as i have high currents running from the grid.
This is depending on use but also on the amount of sun....
sincze
Domoticz version: 2024.4
Post by sincze »
Thanks experienced the same issue with Solaredge so was looking for a solution and digging through API code.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
