Synology Surveillance Station Topic is solved
Atis
Post by Atis »
I find synology Surveillance Station plugin for domoticz. I try 3 plugins but not work. I would like enable and disable some cameras.
Thank you,
azonneveld
Domoticz version: 2024.4
Re: Synology Surveillance Station
Post by azonneveld »
This can be done using the surveillance station API.
Described at page 55.
https://global.download.synology.com/do ... eb_API.pdf
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe - open weather map - wol - BBQ detection - rsync backup
Atis
Post by Atis »
azonneveld wrote: Sunday 22 November 2020 15:55 This can be done using the surveillance station API.
Yes I find this API description, but I try and can not working.
http://192.168.10.2:5000/webapi/entry.c ... &password="*****"
I try enable Camera 1.
azonneveld
Atis wrote: Monday 23 November 2020 14:00
needs Admin account on SS. Test using a browser:
(I use '/cam' instead of the port)
Authenticate:
http://IP/cam/webapi/auth.cgi?api=SYNO.API.Auth&method=Login&version=1&account=USER&passwd=PW&session=SurveillanceStation
Execute command:
http://IP/cam/webapi/entry.cgi?&api="SYNO.SurveillanceStation.Camera"&version=9&method="Disable"&idList="ID"
If that works, create a bash script (not tested):
#!/bin/sh
wget --save-cookies /var/tmp/cookies.txt \
     --keep-session-cookies \
     -O "/var/tmp/cookies.txt" "http://IP/cam/webapi/auth.cgi?api=SYNO.API.Auth&method=Login&version=1&account=USER&passwd=PW&session=SurveillanceStation"
wget  --load-cookies /var/tmp/cookies.txt \
     "http://IP/cam/webapi/entry.cgi?&api="SYNO.SurveillanceStation.Camera"&version=9&method="Disable"&idList="ID""
Call script from Domoticz Lua using:
os.execute ('(/home/pi/domoticz/scripts/SCRIPTNAME.sh > /dev/null)&')
This addition prevents Domoticz waiting for the response:
 > /dev/null)&
Atis
Post by Atis »
azonneveld wrote: Tuesday 24 November 2020 8:40
Authenticate:
Execute command:
#!/bin/sh
 > /dev/null)&
One url can not include command, username, password? I need 2 steps? One login and one command?
azonneveld
Atis wrote: Tuesday 24 November 2020 9:56 One url can not include command, username, password? I need 2 steps? One login and one command?
Perhaps, but this is how i use it.
If you find out how to simplify the requests, please post your findings.
Atis
Post by Atis »
azonneveld wrote: Tuesday 24 November 2020 10:16
Thank you, the script working
