Synology Surveillance Station Topic is solved
Atis
I find synology Surveillance Station plugin for domoticz. I try 3 plugins but not work. I would like enable and disable some cameras.
Thank you,
Thank you,
azonneveld
- Domoticz version: 2024.4
Re: Synology Surveillance Station
This can be done using the surveillance station API.
Described at page 55.
https://global.download.synology.com/do ... eb_API.pdf
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe - open weather map - wol - BBQ detection - rsync backup
Atis
Yes I find this API description, but I try and can not working.azonneveld wrote: Sunday 22 November 2020 15:55 This can be done using the surveillance station API.
http://192.168.10.2:5000/webapi/entry.c ... &password="*****"
I try enable Camera 1.
azonneveld
needs Admin account on SS. Test using a browser:Atis wrote: Monday 23 November 2020 14:00Yes I find this API description, but I try and can not working.azonneveld wrote: Sunday 22 November 2020 15:55 This can be done using the surveillance station API.
(I use '/cam' instead of the port)
Authenticate:
http://IP/cam/webapi/auth.cgi?api=SYNO.API.Auth&method=Login&version=1&account=USER&passwd=PW&session=SurveillanceStationCode: Select all
http://IP/cam/webapi/entry.cgi?&api="SYNO.SurveillanceStation.Camera"&version=9&method="Disable"&idList="ID"Code: Select all
#!/bin/sh
wget --save-cookies /var/tmp/cookies.txt \
--keep-session-cookies \
-O "/var/tmp/cookies.txt" "http://IP/cam/webapi/auth.cgi?api=SYNO.API.Auth&method=Login&version=1&account=USER&passwd=PW&session=SurveillanceStation"
wget --load-cookies /var/tmp/cookies.txt \
"http://IP/cam/webapi/entry.cgi?&api="SYNO.SurveillanceStation.Camera"&version=9&method="Disable"&idList="ID""Code: Select all
os.execute ('(/home/pi/domoticz/scripts/SCRIPTNAME.sh > /dev/null)&')Code: Select all
> /dev/null)&rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe - open weather map - wol - BBQ detection - rsync backup
Atis
azonneveld wrote: Tuesday 24 November 2020 8:40needs Admin account on SS. Test using a browser:Atis wrote: Monday 23 November 2020 14:00Yes I find this API description, but I try and can not working.azonneveld wrote: Sunday 22 November 2020 15:55 This can be done using the surveillance station API.
Authenticate:Execute command:Code: Select all
http://IP/cam/webapi/auth.cgi?api=SYNO.API.Auth&method=Login&version=1&account=USER&passwd=PW&session=SurveillanceStationIf that works, create a bash script (not tested):Code: Select all
http://IP/cam/webapi/entry.cgi?&api="SYNO.SurveillanceStation.Camera"&version=9&method="Disable"&idList="ID"Call script from Domoticz Lua using:Code: Select all
#!/bin/sh wget --save-cookies /var/tmp/cookies.txt \ --keep-session-cookies \ -O "/var/tmp/cookies.txt" "http://IP/cam/webapi/auth.cgi?api=SYNO.API.Auth&method=Login&version=1&account=USER&passwd=PW&session=SurveillanceStation" wget --load-cookies /var/tmp/cookies.txt \ "http://IP/cam/webapi/entry.cgi?&api="SYNO.SurveillanceStation.Camera"&version=9&method="Disable"&idList="ID""
This addition prevents Domoticz waiting for the response:Code: Select all
> /dev/null)&
One url can not include command, username, password? I need 2 steps? One login and one command?
azonneveld
Perhaps, but this is how i use it.Atis wrote: Tuesday 24 November 2020 9:56 One url can not include command, username, password? I need 2 steps? One login and one command?
If you find out how to simplify the requests, please post your findings.
Atis
Thank you, the script workingazonneveld wrote: Tuesday 24 November 2020 10:16Perhaps, but this is how i use it.Atis wrote: Tuesday 24 November 2020 9:56 One url can not include command, username, password? I need 2 steps? One login and one command?
