Arilux / Magic Home LED Strip (timer does not work). Topic is solved
Hanss
Post by Hanss »
Dear Domoticz users,
I have a short question...
I use the Magic Home Led controller. When I manually switch on/off the lights (i.e. devices panel) everything works fine :-)
But when I use the timer option, nothing happens.
Can someone tell me what I am doing wrong (please see the enclosed files)?
Device: Synology DS214 play
- Version: 2020.2 (build 12394)
- Build Hash: d837b5c4e-modified
- Compile Date: 2020-09-23 22:32:29
- dzVents Version: 3.0.13
- Python Version: None
Arilux / Magic Home LED Strip help
Ernstp
Re: Arilux / Magic Home LED Strip (timer does not work).
Post by Ernstp »
Same problem here
Do you already have a solution or a work around?
mojso
Post by mojso »
I solve my problem.
i put the flux_led.py script in ON Action, and now it works timers option and On command from slider
Put script flux_led.py in domoticz/scripts folder
In On action
script://flux_led.py 192.168.1.115 -1
if it still does not work run this command in terminal
pip install flux_led
flux_led.py.zip
(9.97 KiB) Downloaded 86 times
Ernstp
Post by Ernstp »
I solved it in DZVents
This works for turning it on. :D
		timer = {
			'10 minutes after sunset',
	execute = function(domoticz, timer)
		domoticz.log('Timer event was triggered by ' .. timer.trigger, domoticz.LOG_INFO)
		domoticz.devices('wifiledstrip2').switchOn()
		domoticz.devices('Kast').switchOn()
mschaar
Post by mschaar »
I added the arilux hardware and light, but needed a dummy switch to be able to have a switch in the app I could use to dim, setcolor etc.. Not sure if that is only an issue in my setup?
I now use the dummy switch with dzvents to relay the commands sent to the dumm onto the arilux light. Now for me on, off, dimming (set level) and setcolor works.
So basically the commands are sent to dummy device idx 32 (LED muurcirkel) and I relay them to idx 33.
Only thing I could not solve was the fact that I cannot find the arilux device light, the one with idx 33. Not by name or idx. However, targeting that idx with the api commands works fine. Maybe because the device shows up in the unused section of devices?
Another thing is that when the script starts running, the device.color is the color from the previous command. I did not find a very pretty solution, but by fetching via http response I could make it work .
return
    on =
        devices =
            'LED muurcirkel', -- idx or 'name' of  your RGBW device
        httpResponses = {
            'httpLightInfo'
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'sendColor',
        if (item.isDevice) then
           if item.sValue == 'On' then
                domoticz.openURL({
                url = "https://url_to_my_pi/json.htm?type=command&param=switchlight&idx=33&switchcmd=On",
                method = "GET"})
           elseif item.sValue == 'Off' then
                domoticz.openURL({
                url = "https://url_to_my_pi/json.htm?type=command&param=switchlight&idx=33&switchcmd=Off",
                method = "GET"})
           elseif string.find(item.sValue,"Set Level") then
                domoticz.openURL({
                url = "https://url_to_my_pi/json.htm?type=command&param=switchlight&idx=33&switchcmd=Set%20Level&level=" .. item.levelVal .. "",
                method = "GET"})
                domoticz.openURL({
                url = "https://url_to_my_pi/json.htm?type=devices&rid=32",
                method = "GET",
                callback = 'httpLightInfo'})
         if (item.isJSON) then
               json = domoticz.utils.fromJSON(item.data)
               color_string = json.result[1].Color
               domoticz.openURL({
               url = "https://url_to_my_pi/json.htm?type=command&param=setcolbrightnessvalue&idx=33&color=" .. color_string .. "",
               method =  "GET"})
Maybe this is useful for you as well.
Maureen
