Bospieper wrote: ↑Saturday 14 November 2020 19:27
Hi Waaren,
I give you an example of one of my scripts. Maybe you can piont me out in the right direction.
Sure,
this extra script will be triggered on a master switch
return
on =
timer =
'at 05:13', -- a quiet time on a moment that you know everyone is sleeping (or at least should) to reset the master switch
devices =
'masterSwitch', -- virtual switch to trigger a Scene that will switch all lights off
logging =
level = domoticz.LOG_DEBUG -- set to domoticz.LOG_ERROR when all ok
marker = 'One switch to rule them all',
execute = function(dz, item )
local master = dz.devices('masterSwitch')
local allLights = dz.scenes('All lights Off')
if item.isTimer then
master.switchOff().checkFirst().silent()
elseif item.active then
allLights.switchOn() -- trigger the scene that switches off all lights
this is your modified script that will evaluate the state of the masterswitch to decide if any further action is required
return
active = true,
on =
timer =
'20 minutes before sunset',
'between sunset and 60 minutes after sunset',
'between 60 minutes after sunset and 120 minutes after sunset',
'between 120 minutes after sunset and 23:50',
'at 23:50'
devices =
'light'
logging =
level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when all ok
marker = 'Lamp bank',
execute = function(dz, timer )
local master = dz.devices('masterSwitch') -- virtual switch to trigger a Scene that will switch all lights off
if master.active then
dz.log('Rest of script will be ignored because master switch is activated and every light should stay off',dz.LOG_DEBUG )
return
local light = dz.devices('Switch- lamp boven bank')
if dz.time.matchesRule('20 minutes before sunset') then
light.dimTo(5)
elseif dz.time.matchesRule('between sunset and 60 minutes after sunset') then
light.dimTo(20)
if dz.time.matchesRule('between 60 minutes after sunset and 120 minutes after sunset') then
light.dimTo(25)
elseif dz.time.matchesRule('between 120 minutes after sunset and 23:50') then
light.dimTo(15)
if dz.time.matchesRule('at 23:50') then
light.switchOff().checkFirst()
dzVents wiki
