Switch light/switches to Off with one switch  [SOLVED]
Bospieper
Domoticz version: 2022.1
Post by Bospieper »
I have in my home several lamps en switches running with dzvents timebased scripts. When I go to bed, in most cases the most of lamps and switches are on because there are persons in my household which going to bed much later then I :)
I've tried to program a device who can do this, but as soon all lights/switches are off one minute later they are activited by there own script and the light/switches go on. What I want: I am alone at home and a lamp is programmed to go off at 01:00. I am going to bed at 23:00 and I want the lamp switched off. How do I program this ? If only I have a hint in the right direction :)
Thanx in advance.
re: Switch light/switches to Off with one switch
Bospieper wrote: Saturday 14 November 2020 13:45 they are activited by there own script and the light/switches go on.
I guess you need to modify this 'own' script so the logic in the script can check if the lights need to be switched on in this case.
Bospieper
Re: Switch light/switches to Off with one switch
Post by Bospieper »
Hi Waaren,
I give you an example of one of my scripts. Maybe you can piont me out in the right direction.
Thanx.
    active = true,
    on =
        timer =
            '20 minutes before sunset',
            'between sunset and 60 minutes after sunset',
            'between 60 minutes after sunset and 120 minutes after sunset',
            'between 120 minutes after sunset and 23:50',
            'at 23:50'
        devices =
            'light'
    logging =
        level = domoticz.LOG_INFO, -- set to domoticz.LOG_ERROR when all ok
        marker = 'Lamp bank',
    execute = function(dz, timer )
        local light = dz.devices('Switch- lamp boven bank')
            if dz.time.matchesRule('20 minutes before sunset') then
               light.dimTo(5)
            elseif dz.time.matchesRule('between sunset and 60 minutes after sunset') then
               light.dimTo(20)
             if dz.time.matchesRule('between 60 minutes after sunset and 120 minutes after sunset') then
                light.dimTo(25)
             elseif dz.time.matchesRule('between 120 minutes after sunset and 23:50') then
                 light.dimTo(15)
             if  dz.time.matchesRule('at 23:50') then
                 light.switchOff().checkFirst()
Bospieper wrote: Saturday 14 November 2020 19:27 Hi Waaren,
Sure,
this extra script will be triggered on a master switch
return
    on =
        timer =
            'at 05:13', -- a quiet time on a moment that you know everyone is sleeping (or at least should) to reset the master switch
        devices =
            'masterSwitch',  -- virtual switch to trigger a Scene that will switch all lights off
    logging =
        level = domoticz.LOG_DEBUG -- set to domoticz.LOG_ERROR when all ok
        marker = 'One switch to rule them all',
    execute = function(dz, item )
        local master = dz.devices('masterSwitch')
        local allLights = dz.scenes('All lights Off')
        if item.isTimer then
            master.switchOff().checkFirst().silent()
        elseif item.active then
            allLights.switchOn() -- trigger the scene that switches off all lights
this is your modified script that will evaluate the state of the masterswitch to decide if any further action is required
return
    active = true,
    on =
        timer =
            'at 23:50'
        devices =
            'light'
    logging =
        level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when all ok
        local master = dz.devices('masterSwitch') -- virtual switch to trigger a Scene that will switch all lights off
        if master.active then
            dz.log('Rest of script will be ignored because master switch is activated and every light should stay off',dz.LOG_DEBUG )
            return
           light.dimTo(5)
           light.dimTo(20)
            light.dimTo(25)
             light.dimTo(15)
Bospieper
Post by Bospieper »
Hi Waaren,
Thanks for the help. If I'am correct then the first script checks at the given time if the masterswitch is off, if not then the second script is activated and causus the lamp to switch to OFF.
But when I'am allone at home and I want the lamp by masterswitch go off before the off-time in its own script ?
Bospieper wrote: Saturday 14 November 2020 20:25 If I'am correct then the first script checks at the given time if the masterswitch is off, if not then the second script is activated and causus the lamp to switch to OFF.
No that is not how it works.
The first script is triggered by the masterswitch and triggers a scene (that you have to create) That scene should switch Off all lights.
The second script (a modified version of yours) only does something when the masterswitch is Off.
Bospieper
Re: Switch light/switches to Off with one switch (SOLVED)  [SOLVED]
Post by Bospieper »
Yes, I understand now how it's working. I am gonna adjust my scripts and try this tonight.
Thanx again for your assistence, I let you no if it's working.
For now the problem is SOLVED.
Grz
Bospieper
Post by Bospieper »
Hi Waaren,
After handling some device name problems the scripts are working but not with the expected result. Here is a copy from my log:
2020-11-15 18:14:45.169 Activating Scene/Group Device: Switch- masterswitch (On)
2020-11-15 18:14:45.175 (Test) Light/Switch (Switch- masterswitch)
2020-11-15 18:14:45.183 (Nefit) onMessage called with: PUBLISH
2020-11-15 18:14:45.334 (Nefit) onMessage called with: PUBLISH
2020-11-15 18:14:45.358 Activating Scene/Group: [Alles uit]
2020-11-15 18:14:45.360 Activating Scene/Group Device: Switch- masterswitch (On)
2020-11-15 18:14:45.365 (Test) Light/Switch (Switch- masterswitch)
2020-11-15 18:14:45.505 Activating Scene/Group: [Alles uit]
2020-11-15 18:14:45.507 Activating Scene/Group Device: Switch- masterswitch (On)
2020-11-15 18:14:45.512 (Test) Light/Switch (Switch- masterswitch)
2020-11-15 18:14:45.648 Activating Scene/Group: [Alles uit]
2020-11-15 18:14:45.650 Activating Scene/Group Device: Switch- masterswitch (On)
2020-11-15 18:14:45.655 (Test) Light/Switch (Switch- masterswitch)
2020-11-15 18:14:45.830 Activating Scene/Group: [Alles uit]
2020-11-15 18:14:45.832 Activating Scene/Group Device: Switch- masterswitch (On)
2020-11-15 18:14:45.837 (Test) Light/Switch (Switch- masterswitch)
2020-11-15 18:14:45.973 Activating Scene/Group: [Alles uit]
2020-11-15 18:14:45.975 Activating Scene/Group Device: Switch- masterswitch (On)
2020-11-15 18:14:45.979 (Test) Light/Switch (Switch- masterswitch)
2020-11-15 18:14:45.159 Status: dzVents: Info: Handling events for: "Switch- masterswitch", value: "On"
2020-11-15 18:14:45.159 Status: dzVents: Info: One switch to rule them all: ------ Start internal script: Allesuit: Device: "Switch- masterswitch (Test)", Index: 1197
2020-11-15 18:14:45.160 Status: dzVents: Debug: One switch to rule them all: Processing device-adapter for Alles uit: Scene device adapter
2020-11-15 18:14:45.160 Status: dzVents: Debug: One switch to rule them all: Constructed timed-command: On
2020-11-15 18:14:45.160 Status: dzVents: Info: One switch to rule them all: ------ Finished Allesuit
2020-11-15 18:14:45.161 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-11-15 18:14:45.322 Status: dzVents: Info: Handling events for: "Switch- masterswitch", value: "On"
2020-11-15 18:14:45.322 Status: dzVents: Info: One switch to rule them all: ------ Start internal script: Allesuit: Device: "Switch- masterswitch (Test)", Index: 1197
2020-11-15 18:14:45.323 Status: dzVents: Debug: One switch to rule them all: Processing device-adapter for Alles uit: Scene device adapter
2020-11-15 18:14:45.323 Status: dzVents: Debug: One switch to rule them all: Constructed timed-command: On
2020-11-15 18:14:45.323 Status: dzVents: Info: One switch to rule them all: ------ Finished Allesuit
2020-11-15 18:14:45.324 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-11-15 18:14:45.479 Status: dzVents: Info: Handling events for: "Switch- masterswitch", value: "On"
2020-11-15 18:14:45.479 Status: dzVents: Info: One switch to rule them all: ------ Start internal script: Allesuit: Device: "Switch- masterswitch (Test)", Index: 1197
2020-11-15 18:14:45.479 Status: dzVents: Debug: One switch to rule them all: Processing device-adapter for Alles uit: Scene device adapter
2020-11-15 18:14:45.480 Status: dzVents: Debug: One switch to rule them all: Constructed timed-command: On
2020-11-15 18:14:45.480 Status: dzVents: Info: One switch to rule them all: ------ Finished Allesuit
2020-11-15 18:14:45.481 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-11-15 18:14:45.639 Status: dzVents: Info: Handling events for: "Switch- masterswitch", value: "On"
2020-11-15 18:14:45.639 Status: dzVents: Info: One switch to rule them all: ------ Start internal script: Allesuit: Device: "Switch- masterswitch (Test)", Index: 1197
2020-11-15 18:14:45.640 Status: dzVents: Debug: One switch to rule them all: Processing device-adapter for Alles uit: Scene device adapter
2020-11-15 18:14:45.640 Status: dzVents: Debug: One switch to rule them all: Constructed timed-command: On
2020-11-15 18:14:45.640 Status: dzVents: Info: One switch to rule them all: ------ Finished Allesuit
2020-11-15 18:14:45.641 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-11-15 18:14:45.799 Status: dzVents: Info: Handling events for: "Switch- masterswitch", value: "On"
2020-11-15 18:14:45.799 Status: dzVents: Info: One switch to rule them all: ------ Start internal script: Allesuit: Device: "Switch- masterswitch (Test)", Index: 1197
2020-11-15 18:14:45.800 Status: dzVents: Debug: One switch to rule them all: Processing device-adapter for Alles uit: Scene device adapter
2020-11-15 18:14:45.800 Status: dzVents: Debug: One switch to rule them all: Constructed timed-command: On
2020-11-15 18:14:45.800 Status: dzVents: Info: One switch to rule them all: ------ Finished Allesuit
2020-11-15 18:14:45.801 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-11-15 18:14:45.955 Status: dzVents: Info: Handling events for: "Switch- masterswitch", value: "On"
2020-11-15 18:14:45.955 Status: dzVents: Info: One switch to rule them all: ------ Start internal script: Allesuit: Device: "Switch- masterswitch (Test)", Index: 1197
2020-11-15 18:14:45.956 Status: dzVents: Debug: One switch to rule them all: Processing device-adapter for Alles uit: Scene device adapter
2020-11-15 18:14:45.956 Status: dzVents: Debug: One switch to rule them all: Constructed timed-command: On
2020-11-15 18:14:45.956 Status: dzVents: Info: One switch to rule them all: ------ Finished Allesuit
Bospieper wrote: Sunday 15 November 2020 18:16 After handling some device name problems the scripts are working but not with the expected result. Here is a copy from my log:
It seems that you included the master Switch as one of the devices in the scene. That will not work.
Bospieper
Post by Bospieper »
Hi Waaren,
It took me some time before I could test the script but I can tell you now that it's working. As you had noted I had for some strange reason the masterswitch included in the scene 'Alles uit' . After removing the switch the script works !
Thanxs for your help.
