Zigbee thermostat controller with zigate error
RezaRose
Post by RezaRose »
I bought this thermostat controller. I don't know what it's brand is.
I got it working(sort of). But there are a lot of errors in my log.
Anyone have experience with these things?
I thought I had find that they where confirmed working. Are they?
I have them connected to my zigate. I am on version 4.12.053
https://m.nl.aliexpress.com/item/100500 ... 154&is_c=N
The error i get in domoticz:
2020-11-19 20:12:16.201 (Zigate USB TLL) Decode8002 - NwkId: 33be Ep: 01 Cluster: ef00 GlobalCommand: False Command: 01 Data: 05f07000001206001408000f0b1e0f0c1e0f111e1416000f
2020-11-19 20:12:26.720 (Zigate USB TLL) Decode8002 - NwkId: 33be Ep: 01 Cluster: ef00 GlobalCommand: False Command: 01 Data: 05f17100001286001408000f0b1e0f0c1e0f111e1416000f
2020-11-19 20:12:37.192 (Zigate USB TLL) Decode8002 - NwkId: 33be Ep: 01 Cluster: ef00 GlobalCommand: False Command: 01 Data: 05f2720200040000000f
2020-11-19 20:12:47.717 (Zigate USB TLL) Decode8002 - NwkId: 33be Ep: 01 Cluster: ef00 GlobalCommand: False Command: 01 Data: 05f37301000100
2020-11-19 20:12:58.175 (Zigate USB TLL) Decode8002 - NwkId: 33be Ep: 01 Cluster: ef00 GlobalCommand: False Command: 01 Data: 05f47401000100
2020-11-19 20:13:08.714 (Zigate USB TLL) Decode8002 - NwkId: 33be Ep: 01 Cluster: ef00 GlobalCommand: False Command: 01 Data: 05f57502000400000001
2020-11-19 18:31:04.916 (Zigate USB TLL) tuyaReadRawAPS - Unknown command 24 MsgPayload 190d240000
2020-11-19 18:31:22.124 (Zigate USB TLL) buildframe_read_attribute_request - NwkId: 460d Ep: 01 ClusterId: 000a nbAttribute: 1 Data: 0700 buildPayload: 11460d0101000a01000000010007
2020-11-19 18:31:22.129 (Zigate USB TLL) raw_APS_request - ackIsDisabled: True Addr: 460d Ep: 01 Cluster: 000a ProfileId: 0104 Payload: 181101070000237a764927
2020-11-19 18:36:04.904 (Zigate USB TLL) Decode8002 - NwkId: 33be Ep: 01 Cluster: ef00 GlobalCommand: False Command: 24 Data: 0000
2020-11-19 18:36:04.904 (Zigate USB TLL) tuyaReadRawAPS - Unknown command 24 MsgPayload 190e240000
Last edited by RezaRose on Thursday 19 November 2020 21:30, edited 1 time in total.
Raspberry Pi 4 - Raspbian bullseye - Python 3.9 - stable
Dashticz on apache2 - Mqqt - node red
Zigate - USB Tll - Philips hue - Ikea - Innr - Xiaomi - TPlink - Nest -v3
pipiche
Re: Zigbee thesmostat controller with zigate error
Post by pipiche »
A bit overloaded those days, but here is what I suggest:
1/ follow the step here https://github.com/pipiche38/Domoticz-Z ... -device.md to get the export.json and drop it here.
Looks like you are on Firmware 31d .. which is also good
So please provide me those requested information and we will see from there.
RezaRose
Re: Zigbee thermostat controller with zigate error
Post by RezaRose »
Thank you, no hurries!
export 20-11-2020.txt
(80.32 KiB) Downloaded 31 times
pipiche
Post by pipiche »
Thanks for the export. Brand is Tuya it should work. Did you see anything not working ?
I had a better look to the log you provided and they looks as just log messages ( we are on beta and didn't clean too much, and especially this device has recently be integrated, so we might need more info in case).
RezaRose
Post by RezaRose »
Ah i thought because it said error, unknown and false, it is something wrong :)
Have switched to stable-fix plugin and i am not getting the errors anymore.
But i it only get updates from the device in Domoticz when i wake it up with pushing a button on the device. that is normal behavior?
pipiche
Post by pipiche »
I beleive you are with firmware 31d .
The integration was made with someone from the French community and didn't get that feedback. My understand is:
- When you do an update on the device, you get it on Domoticz ( the update could take some time if you change the setpoint value, as the update will be done step by step towards Domoticz).
- You can command the device via Domoticz ( Setpoint ).
- As the local temperature I would believe that we get it automatically, but I have no information on the frequency.
So from your end what you feel working and not working ?
Could you kindly check if you do not have any Debug option enabled via the Tools -> Debug (adavnced) menu
RezaRose
Post by RezaRose »
Sorry fot the late answer. Busy days :)
- if i change the setpoint in domoticz, i updates on the controller too
- If i change setpoint on the device, i get it in domoticz
- if the temp in the room changes, i get very late or I do get an update in Domoticz but it is with a old value.
- When i push a button on the device to see the temp in the room, the devices updates the right value to Domoticz too.
I see that i get an update from the device every 5 min most of the times, sometime only every 2/3 ours. I can't find a pattern why. But the updates does not always contain the right value unless i pushed a button on the device.
In the picture you can see: I put the heating on at 18.00. At 18:05, 18:10, 18:15 etc i get a update from the device. But with the old value.
At 18:30 i pushed a button, and then i got the right value in Domoticz.
Same at 21:00 yesterday.
For the debug option, i have the standard values:
useDomoticzLog
logDeviceUpdate
capturePairingInfos
