I am developing a Python Plug-in to handle my video-projector from Domoticz (see https://github.com/romainrossi/domoticz-epson-projector if interested).
I wanted to disable it from the Hardware page but it doesn't works : the plug-in is still running and writing in the logs.
The plug-in uses a SerialConnection. The onStop() function is not doing anything, like I have seen in the examples.
Maybe I am missing something ? Did someone have experimented the same behaviour ? Did my plugin should do something in the onStop() function to shutdown ?
I use the development branch of the Domoticz code and compiled it myself. It runs in a Ubuntu 20.04 Docker container.
Python Plugin still running after disabling in Hardware page
- TiXav
Re: Python Plugin still running after disabling in Hardware page
I have just seen the same behaviour with this plugin : https://github.com/Xenomes/Domoticz-TUYA-Plugin.git during I was modifying it for my own purpose
The domoticz version I use is 2020.2 build 12624
- Xenomes
- Domoticz version: 2025.2
On my live and test system, when i disable the plug-in there are no new log entries. Also i am interested in you modifications
. Is that something for the global plugin?
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.3 LTS (64Bit) - Domoticz 2025.2 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
