I use an fibaro motion sensor for measuring temperature, if temp comes below setpoint my heating starts for a while of 15 minutes.
Looks like it the sensor gives it value each 5 minutes or each 0,1 difference in degrees.
How could I change config this way the sensor would report each 30 minutes in example? I will try to attach some screenshots, thanks in advance,
Ger
Fibaro motion sensor, report temperature interval
Wilpshaar
- Domoticz version: 2020.1
- Screenshot_20201113-205533_1.jpg (71.44 KiB) Viewed 530 times
- Screenshot_20201113-205522_1.jpg (62.61 KiB) Viewed 530 times
- Screenshot_20201113-205157_1.jpg (278.74 KiB) Viewed 530 times
jake
Re: Fibaro motion sensor, report temperature interval
Go to the hardware page, open the zwave hardware, click on the sensor and adapt the sensor parameters to your wishes
