My first blockly script
ElMyggo
Domoticz version: 2024.4
Post by ElMyggo »
Hi, i am complety novise on this script thing and i have start to setup Domoticz on a Raspberry with some switches and have try this scripts and its seems to work but is it correct?
First i found this example and i created a virtual switch if its night or not
Then i want to start lightgroup at time 05:05 but only if there is night, then i want to switch of at 05:35 so i create this:
Is this correct way to do this?
AllesVanZelf
Domoticz version: 12467
Re: My first blockly script
Post by AllesVanZelf »
What also is possible is switching 'Natt' with a timer in the switch itself. I found out that this is working more reliable.
Treve
Domoticz version: v4.11474
Post by Treve »
I think this will do the job after making a variabele called 'Natt'
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
ElMyggo
Post by ElMyggo »
Ok i do a test whitout the virtual switch and use variable instead, thanks for help so far :-)
Treve
Post by Treve »
With use of a variable you can’t accidentally press the button.
There will be only a problem when Sunrise time is between 05:05 and 05:35. But you have a few months to find a solution for that.
For example: if Time is > 05:05 and < 05:35
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
