if [time set in switch <> "0:00"
If actual time >= [time set in switch]
do actions..
[time set in switch] = "0:00"
endif
endif
The only thing my wife needs to do is setting the time in the timer
For the dzVents script below you will need a selector switch. Level 0 should be named 'Off' and other levels can be times in hh:mm format. When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents disabled' is not checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."michelb wrote: Wednesday 30 October 2019 20:33 The only thing my wife needs to do is setting the time in the timer![]()
-- Alarm clock [ dzVents >= 2.4 ]
scriptVar = '20191030 Alarmclock'
return
on =
timer = { "at 00:07" }, -- daily run once to pick up target time
httpResponses = { scriptVar }, -- Trigger the handle Json part
logging = { level = domoticz.LOG_DEBUG },
execute = function(dz, item)
local alarmTime = dz.devices('Alarm clock').levelName
local minutesIn24Hours = 24 * 60
local now = dz.time -- Get current time into time object
local Time = require('Time')
local targetTime = Time(dz.time.rawDate .. ' ' .. alarmTime .. ':00') -- Create target time object
local function triggerAlarm(delay)
local message = 'tring, trrring, trrring alarmclock ringing now. Was set on '.. dz.time.rawDate .. ', at ' .. dz.time.rawTime
local url = dz.settings['Domoticz url'] .. "/json.htm?type=command¶m=addlogmessage&message=" .. dz.utils.urlEncode(message)
dz.openURL({ url = url, callback = scriptVar }).afterMin(math.floor(delay))
if not(item.isHTTPResponse) then
dz.log('Alarm time is set at : ' .. alarmTime)
local deltaMinutes = math.floor(now.compare(targetTime).minutes)
if now.compare(targetTime).compare < 1 then -- targetTime is in future
deltaMinutes = minutesIn24Hours - deltaMinutes
dz.log('Alarmactions will be triggered in ' .. deltaMinutes .. ' minutes' ,dz.LOG_DEBUG)
triggerAlarm(deltaMinutes)
-- do wakeup actions.. here
dz.log('wake up actions here....' ,dz.LOG_DEBUG)
}Code: Select all
2020-10-31 14:05:00.484 Error: dzVents: Error: (3.0.2) sDate was invalid. Reset to 2020-10-31 14:5:0.320 Code: Select all
return
{ active = true,
on =
timer = { 'every hour' }, -- hourly run once to pick up target time
local alarmTime = dz.devices('Wekker').levelName
dz.devices('Kachel badkamer').switchOn()
dz.devices('Kachel badkamer').switchOff().afterMin(15)
dz.openURL('http://192.xxx.x.xxx:5005/Slaapkamer/volume/10')
dz.openURL('http://192.xxx.x.xxx:5005/Slaapkamer/unmute')
dz.openURL('http://192.xxx.x.xxx:5005/Slaapkamer/favorite/ClassicFM')
dz.scenes('Awaken').switchOn()
}That seems indeed to be the issue. Should be fixed in below modified script.Dutchsea wrote: Saturday 31 October 2020 14:18 I expect this is because the alarmtime input is a string "Off" while it expects a time. Or did i miss something in the code of the alarm clock?
return
{ active = true,
on =
if alarmTime ~= 'Off' then
