ok. any error in the logs ?
Zigate errors: onMessage' failed 'error':'argument out of range'.
Re: Zigate errors: onMessage' failed 'error':'argument out of range'.
Wiki is available here.
Zigbee for Domoticz FAQ
I'll order one, to fine tune it.
I attached a normal light and a normal bulb in it, but no power updates.
But no errors in the log anymore about the innr plug.
The Xiaomi sensor still stays on, sometimes giving this in the log:
It was working fine on the stable version this morning.
2020-10-25 19:48:44.375 (Zigate USB TLL) mgtCommand - You are trying to action not allowed for Device: Schuursensor Type: [('01', '85', 'Motion')] and DeviceType: Motion Command: Off Level:0
Raspberry Pi 4 - Raspbian bullseye - Python 3.9 - stable
Dashticz on apache2 - Mqqt - node red
Zigate - USB Tll - Philips hue - Ikea - Innr - Xiaomi - TPlink - Nest -v3
Just for your information the order is on its way. Will have a look what can be done for the power. It might simply be like the BlitzWolf plug that we need to poll(request) the information from the plug.
Will keep you posted
Support of INNR SP 120
@RezaRose , just to let you know that if you take the latest of stable-fix , restart plugin, then remove devices and redo the pairing.
Instant power should be there.
Sorry for the late answer. I just read the message. You are awesome!! I will try that tomorrow! So far I got the widgets but no data.
It work flawless! thank you so much!
Happy week-end @RezaRose . and thanks for the paypal
Your welcome!
Verstuurd vanaf mijn SM-G973F met Tapatalk
