BlitzWolf BW-SHP13 Zigbee 3.0 and zigate
wuffer
Post by wuffer »
Are there others here that uses this zigbee plug? It shows up as TS0121.
https://www.blitzwolf.com/ZigBee-3.0-Sm ... p-518.html
I can get it to turn on/off and it does shows 2 different wattage and one with voltage but they stay on same watt/voltage and doesn't change.
Newest firmware and beta plugin.
pipiche
Re: BlitzWolf BW-SHP13 Zigbee 3.0 and zigate
Post by pipiche »
This device is supported since stable 4.11.002, but it is key that you do the pairing with a version which support this device.
So I strongly recommend you if you are on the latest 'beta' as you said which then must be 4.12.018 to remove all devices and redo the pairing
wuffer
Post by wuffer »
Thanks i will try that :)
pipiche
Post by pipiche »
In case it doesn't work.
I would need the logs from pairing and the export.json as explained here https://github.com/pipiche38/Domoticz-Z ... -device.md
wuffer
Post by wuffer »
This is a completly fresh installation, so i only have installed zigate. I have tried pairing a few times, but the value stays the same.
Here is the file.
export.zip
(2.08 KiB) Downloaded 49 times
pipiche
Post by pipiche »
wuffer wrote: Wednesday 28 October 2020 22:32 This is a completly fresh installation, so i only have installed zigate. I have tried pairing a few times, but the value stays the same.
Here is the file.
And please enable via the Settings only this parameter: pollingBlitzwolfPower where you have 0, put for instance 60 in order to have a refresh of Power/Meter every 60 secondes
wuffer
Post by wuffer »
Hmm when i went to bed, it didn't work. When i got up, it seems to be working. I don't get it. But i'm not complaining. :)
pipiche
Post by pipiche »
Those plug, do not really delivery Instant Power. In fact we have to poll/query the information to the device on a regular basic to get the information.
For sure the Metering will be more accurate as it is based on summation .
You can eventually change the 60 (secondes) to less if you want to have a more frequent query, but this will have an impact on the load on the Zigate and so on the overall setup. Taking in consideration that the plugin might consider other requests more important.
wuffer
Post by wuffer »
Okay good to know. I just wanted a cheap zigbee plug and this was the cheapest i could find. The metering is just a bonus and just used to see what different items uses of power, in a day/week.
Vopis
Post by Vopis »
@wuffer, can you tell me how did you add this devie to domoticz? I was able to add it into Zigbee2MQTT using domoticz webpage but domoticz can't see any devices and values and can't add any switches for this device.
In the log I see:
2020-10-30 15:55:52.563 (Zigbee2MQTT) This plugin does not support zigbee device with model "TS0121_plug" yet
2020-10-30 15:55:52.563 (Zigbee2MQTT) If you would like plugin to support this device, please create ticket by this link: https://github.com/stas-demydiuk/domoti ... support.md
Can you help me, please?
wuffer
Post by wuffer »
@vopis can't help you with that. I use zigate. Don't know how zigbee2MQTT works
Vopis
Post by Vopis »
The problem is not with zigbee2mqtt or zigate, I can pair the plug with zigbee2mqtt and I can see the payload from the device:
2020-10-30 16:03:59: MQTT publish: topic 'zigbee2mqtt/0x588e81fffed97d10', payload '{"current":0,"energy":0,"linkquality":23,"power":0,"state":"ON","voltage":230}'
The problem is with domoticz, it says this device is not compatible.
Vopis
Post by Vopis »
Sorry for bothering you.
It works perfect now after I updated zigbee2mqtt plugin for domoticz and restarted it.
Now I have all switches and values I need: Switch (power on / off), Consumption (once in 10 seconds), Voltage (once in 10 seconds).
