BlitzWolf BW-SHP13 Zigbee 3.0 and zigate
wuffer
Are there others here that uses this zigbee plug? It shows up as TS0121.
https://www.blitzwolf.com/ZigBee-3.0-Sm ... p-518.html
I can get it to turn on/off and it does shows 2 different wattage and one with voltage but they stay on same watt/voltage and doesn't change.
Newest firmware and beta plugin.
Re: BlitzWolf BW-SHP13 Zigbee 3.0 and zigate
This device is supported since stable 4.11.002, but it is key that you do the pairing with a version which support this device.
So I strongly recommend you if you are on the latest 'beta' as you said which then must be 4.12.018 to remove all devices and redo the pairing
wuffer
Thanks i will try that
In case it doesn't work.
I would need the logs from pairing and the export.json as explained here https://github.com/pipiche38/Domoticz-Z ... -device.md
wuffer
This is a completly fresh installation, so i only have installed zigate. I have tried pairing a few times, but the value stays the same.
Here is the file.
Here is the file.
- export.zip
- (2.08 KiB) Downloaded 84 times
wuffer wrote: Wednesday 28 October 2020 22:32 This is a completly fresh installation, so i only have installed zigate. I have tried pairing a few times, but the value stays the same.
Here is the file.
And please enable via the Settings only this parameter: pollingBlitzwolfPower where you have 0, put for instance 60 in order to have a refresh of Power/Meter every 60 secondes
wuffer
Hmm when i went to bed, it didn't work. When i got up, it seems to be working. I don't get it. But i'm not complaining.
Those plug, do not really delivery Instant Power. In fact we have to poll/query the information to the device on a regular basic to get the information.
For sure the Metering will be more accurate as it is based on summation .
You can eventually change the 60 (secondes) to less if you want to have a more frequent query, but this will have an impact on the load on the Zigate and so on the overall setup. Taking in consideration that the plugin might consider other requests more important.
wuffer
Okay good to know. I just wanted a cheap zigbee plug and this was the cheapest i could find. The metering is just a bonus and just used to see what different items uses of power, in a day/week.
@wuffer, can you tell me how did you add this devie to domoticz? I was able to add it into Zigbee2MQTT using domoticz webpage but domoticz can't see any devices and values and can't add any switches for this device.
In the log I see:
2020-10-30 15:55:52.563 (Zigbee2MQTT) This plugin does not support zigbee device with model "TS0121_plug" yet
2020-10-30 15:55:52.563 (Zigbee2MQTT) If you would like plugin to support this device, please create ticket by this link: https://github.com/stas-demydiuk/domoti ... support.md
Can you help me, please?
In the log I see:
wuffer
@vopis can't help you with that. I use zigate. Don't know how zigbee2MQTT works
The problem is not with zigbee2mqtt or zigate, I can pair the plug with zigbee2mqtt and I can see the payload from the device:
2020-10-30 16:03:59: MQTT publish: topic 'zigbee2mqtt/0x588e81fffed97d10', payload '{"current":0,"energy":0,"linkquality":23,"power":0,"state":"ON","voltage":230}'
The problem is with domoticz, it says this device is not compatible.
Sorry for bothering you.
It works perfect now after I updated zigbee2mqtt plugin for domoticz and restarted it.
Now I have all switches and values I need: Switch (power on / off), Consumption (once in 10 seconds), Voltage (once in 10 seconds).
