Turn on a Group for a certain time [Solved]
gschmidt
I have a blockly script which turns on a Group of bulbs for 2 minutes, when an Security Door switch "Schuurdeur" is set to "Alarm" and the time is before sunrise or after sunset. But in blockly it is not possible to turn a group on for a certain amount of time. Therefor I have to use a second blockly script where a virtual switch triggers the group on/off. This Virtual Switch "Tuin Tijdelijk" is used in the first blockly script (see picture below) to turn on for 2 minutes.
Is it possible to create this flow in dzVents with a group which is turned on for 2 minutes?
Then I don't need the virtual switch plus the blockly script which triggers the group
- waaren
Re: Turn on a Group for a certain time
gschmidt wrote: Thursday 26 March 2020 22:48 Hi,
Turns on a Group of bulbs for 2 minutes, when an Security Door switch "Schuurdeur" is set to "Alarm" and the time is before sunrise or after sunset.
/quote]
Could be something like
return { on = { devices = { Schuurdeur = { 'at nighttime', }, }, }, logging = { level = domoticz.LOG_DEBUG, marker = 'Group switch', }, execute = function(dz, item) local tuin = dz.groups('Tuin') -- Change to name of your group if item.state == 'Alarm' then tuin.cancelQueuedCommands() tuin.switchOn() tuin.switchOff().afterSec(120) end end }
gschmidt
This is working thanx!
gschmidt
I have changed this working script from a group 'Tuin' to a device "Tuinverlichting"
Device "Tuin Verlichting" is a virtual ON/OFF switch which controls (dzVents script) a zigbee2mqtt group of bulbs
The script turns ON the device but it doesn't turn it OFF after 120 seconds.
Why is this, I have an equal type of script for the "Doorbel" and "Hallway Light", which is working?
-- Schuurdeur security dzVents script
return
on =
devices =
Schuurdeur =
'at nighttime',
logging =
marker = 'Schuurdeur Security Tuin Verlichting',
local tv = dz.devices('Tuin Verlichting')
if (item.state == 'Open' and tv.state == 'Off') then
tv.cancelQueuedCommands()
tv.switchOn()
tv.switchOff().afterSec(120)
}- waaren
What do you see in the log ? If nothing useful yet than I suggest to add some log statements at useful places and include relevant device states .gschmidt wrote: Wednesday 28 October 2020 20:36 The script turns ON the device but it doesn't turn it OFF after 120 seconds.
gschmidt
Hi waaren,waaren wrote: Wednesday 28 October 2020 22:16What do you see in the log ? If nothing useful yet than I suggest to add some log statements at useful places and include relevant device states .gschmidt wrote: Wednesday 28 October 2020 20:36 The script turns ON the device but it doesn't turn it OFF after 120 seconds.
Nope didn't see anything in the log.
More strange is that i went back to the previous setup & script and it is working again???
The difference between the previous and the new setup is:
I have 5 lights in the garden, which I want to turn on for 2 minutes when the schuurdeur alarm is triggered.
OLD setup:
1x "Tuinverlichting" virtual dimmer switch, which controls a zigbee2mqtt group with 4 IKEA Bulbs
1x KAKU ON/OFF Switch (Vijver Spotjes)
Added both Switches to a domoticz Group 'Schuurdeur Security'.....This way the script below has worked for months.
New setup:
I replaced the KAKU device (broken) by a IKEA Wall-Outlet to control the "Vijver Spotjes"
Therefore I added the IKEA Wall-Outlet in zigbee2mqtt to the same group as the 4 IKEA Bulbs.
"Tuinverlichting" virtual dimmer switch controls 5 lights now.
I thought that the script didn't have to use the Domoticz group anymore, but the switchOff().afterSec(120) function is not executed.
Then I added the "Tuin Verlichting" switch to a Group, and changed the script to......and it is working?
Why is the switchOff().afterSec(120) function executed with a Domoticz Group, but not directly with the "Tuinverlichting" virtual dimmer switch?
return
on =
devices =
Schuurdeur =
'at nighttime',
logging =
marker = 'Schuurdeur Security Tuin Licht',
local tuin = dz.groups('Schuurdeur Security')
tuin.switchOn()
}- waaren
Sorry but I cannot help if you don't share the loglines. At least add a log statement where you show the state of the door and of tuinverlichting.gschmidt wrote: Wednesday 28 October 2020 23:10 Why is the switchOff().afterSec(120) function executed with a Domoticz Group, but not directly with the "Tuinverlichting" virtual dimmer switch?
Maybe I overlook something but In your earlier post you stated that tv was an On / Off switch and in your later post it is a dimmer
If you switch Off a dimmer, the reported state might well still be 'Set level'
gschmidt
Hi waaren,waaren wrote: Thursday 29 October 2020 0:07Sorry but I cannot help if you don't share the loglines. At least add a log statement where you show the state of the door and of tuinverlichting.gschmidt wrote: Wednesday 28 October 2020 23:10 Why is the switchOff().afterSec(120) function executed with a Domoticz Group, but not directly with the "Tuinverlichting" virtual dimmer switch?
You are right. I’ve made a typing error...it is a virtual dimmer switch, which probably needs a command like dimLevel instead of Off. That is why a group is working, because it is an on/off device.
I will share the log a.s.a.p.
gschmidt
Hi waaren,
I have the LOG details for Script #1. But (Virtual Dummy) Light/Switch (Tuin Verlichting) is not switched of
2020-10-29 20:26:50.615 (RFXtrx433XL) Security (Schuurdeur)
2020-10-29 20:26:50.801 (Virtual Dummy) Light/Switch (Tuin Verlichting)
2020-10-29 20:26:50.980 (Virtual Dummy) Light/Switch (Tuin Verlichting)
2020-10-29 20:26:50.771 Status: dzVents: Info: Handling events for: "Schuurdeur", value: "Open"
2020-10-29 20:26:50.771 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Start internal script: Script #1: Device: "Schuurdeur (RFXtrx433XL)", Index: 317
2020-10-29 20:26:50.773 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Processing device-adapter for Tuin Verlichting: Switch device adapter
2020-10-29 20:26:50.773 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Constructed timed-command: On
2020-10-29 20:26:50.773 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Constructed timed-command: Off
2020-10-29 20:26:50.773 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Constructed timed-command: Off AFTER 120 SECONDS
2020-10-29 20:26:50.773 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Finished Script #1
2020-10-29 20:26:50.775 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-10-29 20:26:50.909 Status: dzVents: Info: Handling events for: "Tuin Verlichting", value: "On"
2020-10-29 20:26:50.947 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-10-29 20:26:52.647 (RFXtrx433XL) Security (Schuurdeur)
2020-10-29 20:26:52.847 Status: dzVents: Info: Handling events for: "Schuurdeur", value: "Normal"
2020-10-29 20:26:52.847 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Start internal script: Script #1: Device: "Schuurdeur (RFXtrx433XL)", Index: 317
2020-10-29 20:26:52.849 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Processing device-adapter for Tuin Verlichting: Switch device adapter
2020-10-29 20:26:52.849 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Finished Script #1- waaren
I also asked togschmidt wrote: Thursday 29 October 2020 20:31 I have the LOG details for Script #1. But (Virtual Dummy) Light/Switch (Tuin Verlichting) is not switched of
Can you replace the script with this one? It will now show enough information to debug it.at least add a log statement where you show the state of the door and of tuinverlichting.
return
on =
devices =
Schuurdeur =
'at nighttime',
groups =
'Schuurdeur Security',
logging =
dz.log(tuin.name .. ' (' .. tuin.baseType ..') State is ' .. tuin.state ,dz.LOG_DEBUG )
dz.log(tv.name .. ' (' .. tv.baseType ..') State is ' .. tv.state ,dz.LOG_DEBUG )
dz.log(item.name .. ' (' .. item.baseType ..') State is ' .. item.state ,dz.LOG_DEBUG )
if item.isDevice and item.state == 'On' and tv.state == 'Off' then
tuin.switchOn()
tuin.switchOff().afterSec(11)
gschmidt
I have changed "item.state == 'On'" to "Open" to make it trigger the script. This is the command for the Kerui Door Sensorwaaren wrote: Thursday 29 October 2020 21:24 Can you replace the script with this one? It will now show enough information to debug it.
-- Schuurdeur security dzVents script return { on = { devices = { Schuurdeur = { 'at nighttime', }, }, groups = { 'Schuurdeur Security', }, }, logging = { level = domoticz.LOG_DEBUG, marker = 'Schuurdeur Security Tuin Licht', }, execute = function(dz, item) local tv = dz.devices('Tuin Verlichting') local tuin = dz.groups('Schuurdeur Security') dz.log(tuin.name .. ' (' .. tuin.baseType ..') State is ' .. tuin.state ,dz.LOG_DEBUG ) dz.log(tv.name .. ' (' .. tv.baseType ..') State is ' .. tv.state ,dz.LOG_DEBUG ) dz.log(item.name .. ' (' .. item.baseType ..') State is ' .. item.state ,dz.LOG_DEBUG ) if item.isDevice and item.state == 'On' and tv.state == 'Off' then tuin.cancelQueuedCommands() tuin.switchOn() tuin.switchOff().afterSec(11) end end }
Here is the LOG:
2020-10-29 22:11:46.891 (RFXtrx433XL) Security (Schuurdeur)
2020-10-29 22:11:47.095 Activating Scene/Group: [Schuurdeur Security]
2020-10-29 22:11:47.100 Activating Scene/Group Device: Tuin Verlichting (On)
2020-10-29 22:11:47.106 (Virtual Dummy) Light/Switch (Tuin Verlichting)
2020-10-29 22:11:47.075 Status: dzVents: Info: Handling events for: "Schuurdeur", value: "Open"
2020-10-29 22:11:47.075 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Start internal script: Schuurdeur_Security_new: Device: "Schuurdeur (RFXtrx433XL)", Index: 317
2020-10-29 22:11:47.076 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Processing device-adapter for Tuin Verlichting: Switch device adapter
2020-10-29 22:11:47.077 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Processing device-adapter for Schuurdeur Security: Group device adapter
2020-10-29 22:11:47.077 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Schuurdeur Security (group) State is Off
2020-10-29 22:11:47.077 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Tuin Verlichting (device) State is Off
2020-10-29 22:11:47.077 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Schuurdeur (device) State is Open
2020-10-29 22:11:47.077 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Constructed timed-command: On
2020-10-29 22:11:47.077 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Constructed timed-command: Off
2020-10-29 22:11:47.077 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Constructed timed-command: Off AFTER 11 SECONDS
2020-10-29 22:11:47.077 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Finished Schuurdeur_Security_new
2020-10-29 22:11:47.079 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-10-29 22:11:47.206 Status: dzVents: Info: Handling events for: "Schuurdeur Security", value: "On"
2020-10-29 22:11:47.206 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Start internal script: Schuurdeur_Security_new: Group: "Schuurdeur Security", Index: 19
2020-10-29 22:11:47.207 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Processing device-adapter for Tuin Verlichting: Switch device adapter
2020-10-29 22:11:47.207 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Schuurdeur Security (group) State is On
2020-10-29 22:11:47.207 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Tuin Verlichting (device) State is Off
2020-10-29 22:11:47.208 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Schuurdeur Security (group) State is On
2020-10-29 22:11:47.208 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Finished Schuurdeur_Security_new
2020-10-29 22:11:49.979 (RFXtrx433XL) Security (Schuurdeur)
2020-10-29 22:11:50.135 Status: dzVents: Info: Handling events for: "Schuurdeur", value: "Normal"
2020-10-29 22:11:50.136 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Start internal script: Schuurdeur_Security_new: Device: "Schuurdeur (RFXtrx433XL)", Index: 317
2020-10-29 22:11:50.137 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Processing device-adapter for Tuin Verlichting: Switch device adapter
2020-10-29 22:11:50.137 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Processing device-adapter for Schuurdeur Security: Group device adapter
2020-10-29 22:11:50.138 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Schuurdeur Security (group) State is On
2020-10-29 22:11:50.138 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Tuin Verlichting (device) State is On
2020-10-29 22:11:50.138 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Schuurdeur (device) State is Normal
2020-10-29 22:11:50.138 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Finished Schuurdeur_Security_new
2020-10-29 22:11:58.101 Activating Scene/Group: [Schuurdeur Security]
2020-10-29 22:11:58.110 Activating Scene/Group Device: Tuin Verlichting (Off)
2020-10-29 22:11:58.124 (Virtual Dummy) Light/Switch (Tuin Verlichting)
2020-10-29 22:11:58.276 Status: dzVents: Info: Handling events for: "Schuurdeur Security", value: "Off"
2020-10-29 22:11:58.276 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Start internal script: Schuurdeur_Security_new: Group: "Schuurdeur Security", Index: 19
2020-10-29 22:11:58.277 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Processing device-adapter for Tuin Verlichting: Switch device adapter
2020-10-29 22:11:58.278 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Schuurdeur Security (group) State is Off
2020-10-29 22:11:58.278 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Tuin Verlichting (device) State is On
2020-10-29 22:11:58.278 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Finished Schuurdeur_Security_new
2020-10-29 22:11:58.397 Status: dzVents: Info: Handling events for: "Tuin Verlichting", value: "Off"- waaren
So what I see in the log (summarized to make it clear)gschmidt wrote: Thursday 29 October 2020 22:22 I have changed "item.state == 'On'" to "Open" to make it trigger the script. This is the command for the Kerui Door Sensor
Here is the LOG:
2020-10-29 22:11:47.077 : Schuurdeur Security (group) State is Off -- Group is still Off
2020-10-29 22:11:47.077 : Constructed timed-command: On -- Switching group to On immediate
2020-10-29 22:11:47.077 : Constructed timed-command: Off AFTER 11 SECONDS -- Schedule Switching group to Off after 11 seconds
2020-10-29 22:11:47.207 : Schuurdeur Security (group) State is On -- Group is switched to On in 0.13 seconds
2020-10-29 22:11:58.278 : Schuurdeur Security (group) State is Off -- Group is switched to Off in 11.201 Seconds
gschmidt
Yes this script is working. This is also how my previous script worked.waaren wrote: Thursday 29 October 2020 23:13So what I see in the log (summarized to make it clear)gschmidt wrote: Thursday 29 October 2020 22:22 I have changed "item.state == 'On'" to "Open" to make it trigger the script. This is the command for the Kerui Door Sensor
Here is the LOG:Code: Select all
2020-10-29 22:11:47.077 : Schuurdeur Security (group) State is Off -- Group is still Off 2020-10-29 22:11:47.077 : Constructed timed-command: On -- Switching group to On immediate 2020-10-29 22:11:47.077 : Constructed timed-command: Off AFTER 11 SECONDS -- Schedule Switching group to Off after 11 seconds 2020-10-29 22:11:47.207 : Schuurdeur Security (group) State is On -- Group is switched to On in 0.13 seconds 2020-10-29 22:11:58.278 : Schuurdeur Security (group) State is Off -- Group is switched to Off in 11.201 Seconds
However, there used to be 2 devices in the “Schuur Security” group, one of the devices was a kaku on/off switch.
The other one is “(Virtual Dummy) Light/Switch (Tuin Verlichting)”, this is a virtual dimmer switch which is controlling a zigbee2mqtt group of 4 devices.
The kaku switch is broken, so bought an ikea wall outlet switch.
This is also a zigbee device, which I have added to the same Zigbee2mqtt group, which now exists of 5 devices.
As you can see in my log there is now only 1 device in the “Schuur Security” group: “(Virtual Dummy) Light/Switch (Tuin Verlichting)”.
So my idea was to remove the group from domoticz, and in the script only use “(Virtual Dummy) Light/Switch (Tuin Verlichting)” to switchOn() and SwitchOff().AfterSec(20)
The problem here is that it swiches On, but not Off.
- waaren
So what is the script you use for this setup and what do you see in the log when it is triggered?
gschmidt
Here the script:
return
on =
devices =
Schuurdeur =
'at daytime',
logging =
if item.isDevice and item.state == 'Open' and tv.state == 'Off' then
tv.switchOn()
tv.switchOff().afterSec(11)
}Code: Select all
2020-11-01 09:18:54.563 (RFXtrx433XL) Security (Schuurdeur)
2020-11-01 09:18:54.769 (Virtual Dummy) Light/Switch (Tuin Verlichting)
2020-11-01 09:18:54.946 (Virtual Dummy) Light/Switch (Tuin Verlichting)
2020-11-01 09:18:54.719 Status: dzVents: Info: Handling events for: "Schuurdeur", value: "Open"
2020-11-01 09:18:54.719 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Start internal script: Schuurdeur_Security_new: Device: "Schuurdeur (RFXtrx433XL)", Index: 317
2020-11-01 09:18:54.720 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Processing device-adapter for Tuin Verlichting: Switch device adapter
2020-11-01 09:18:54.720 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Tuin Verlichting (device) State is Off
2020-11-01 09:18:54.721 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Schuurdeur (device) State is Open
2020-11-01 09:18:54.721 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Constructed timed-command: On
2020-11-01 09:18:54.721 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Constructed timed-command: Off
2020-11-01 09:18:54.721 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Constructed timed-command: Off AFTER 11 SECONDS
2020-11-01 09:18:54.721 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Finished Schuurdeur_Security_new
2020-11-01 09:18:54.723 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-11-01 09:18:54.883 Status: dzVents: Info: Handling events for: "Tuin Verlichting", value: "On"
2020-11-01 09:18:54.919 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-11-01 09:18:57.514 (RFXtrx433XL) Security (Schuurdeur)
2020-11-01 09:18:57.708 Status: dzVents: Info: Handling events for: "Schuurdeur", value: "Normal"
2020-11-01 09:18:57.708 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Start internal script: Schuurdeur_Security_new: Device: "Schuurdeur (RFXtrx433XL)", Index: 317
2020-11-01 09:18:57.709 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Processing device-adapter for Tuin Verlichting: Switch device adapter
2020-11-01 09:18:57.709 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Tuin Verlichting (device) State is On
2020-11-01 09:18:57.709 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Schuurdeur (device) State is Normal
2020-11-01 09:18:57.709 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Finished Schuurdeur_Security_new- waaren
gschmidt wrote: Sunday 01 November 2020 9:21 Nothing happens afer 11 seconds...Tuin Verlichting (device) is still ON
I don't understand yet what is going wrong. I cannot replicate the issue on my system. It almost looks like the Tuin verlichting hardware ignores the afterSec.
Below script should give some more information.
return
on =
devices =
Schuurdeur =
'at daytime',
'Tuin Verlichting',
logging =
local door = dz.devices('Schuurdeur')
dz.log(door.name .. ' (' .. door.baseType ..') State is ' .. door.state ,dz.LOG_DEBUG )
dz.log(tv.deviceType,dz.LOG_DEBUG)
dz.log(tv.deviceSubType,dz.LOG_DEBUG)
dz.log(tv.rawData,dz.LOG_DEBUG)
dz.log(tv.nValue,dz.LOG_DEBUG)
dz.log(tv.hardwareName,dz.LOG_DEBUG)
if item == door and item.state == 'Open' and tv.state == 'Off' then
tv.switchOn()
gschmidt
This is the LOG:waaren wrote: Sunday 01 November 2020 11:11gschmidt wrote: Sunday 01 November 2020 9:21 Nothing happens afer 11 seconds...Tuin Verlichting (device) is still ON![]()
-- Schuurdeur security dzVents script return { on = { devices = { Schuurdeur = { 'at daytime', }, 'Tuin Verlichting', }, }, logging = { level = domoticz.LOG_DEBUG, marker = 'Schuurdeur Security Tuin Licht', }, execute = function(dz, item) local tv = dz.devices('Tuin Verlichting') local door = dz.devices('Schuurdeur') dz.log(tv.name .. ' (' .. tv.baseType ..') State is ' .. tv.state ,dz.LOG_DEBUG ) dz.log(door.name .. ' (' .. door.baseType ..') State is ' .. door.state ,dz.LOG_DEBUG ) dz.log(tv.deviceType,dz.LOG_DEBUG) dz.log(tv.deviceSubType,dz.LOG_DEBUG) dz.log(tv.rawData,dz.LOG_DEBUG) dz.log(tv.nValue,dz.LOG_DEBUG) dz.log(tv.hardwareName,dz.LOG_DEBUG) if item == door and item.state == 'Open' and tv.state == 'Off' then tv.cancelQueuedCommands() tv.switchOn() tv.switchOff().afterSec(11) end end }
020-11-01 12:23:49.098 (RFXtrx433XL) Security (Schuurdeur)
2020-11-01 12:23:49.286 (Virtual Dummy) Light/Switch (Tuin Verlichting)
2020-11-01 12:23:49.432 (Virtual Dummy) Light/Switch (Tuin Verlichting)
2020-11-01 12:23:49.244 Status: dzVents: Info: Handling events for: "Schuurdeur", value: "Open"
2020-11-01 12:23:49.244 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Start internal script: Schuurdeur_Security_new: Device: "Schuurdeur (RFXtrx433XL)", Index: 317
2020-11-01 12:23:49.245 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Processing device-adapter for Tuin Verlichting: Switch device adapter
2020-11-01 12:23:49.245 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Tuin Verlichting (device) State is Off
2020-11-01 12:23:49.245 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Schuurdeur (device) State is Open
2020-11-01 12:23:49.245 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Light/Switch
2020-11-01 12:23:49.245 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Switch
2020-11-01 12:23:49.245 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: {"78"}
2020-11-01 12:23:49.245 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: 0
2020-11-01 12:23:49.245 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Virtual Dummy
2020-11-01 12:23:49.245 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Constructed timed-command: On
2020-11-01 12:23:49.245 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Constructed timed-command: Off
2020-11-01 12:23:49.246 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Constructed timed-command: Off AFTER 11 SECONDS
2020-11-01 12:23:49.246 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Finished Schuurdeur_Security_new
2020-11-01 12:23:49.247 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-11-01 12:23:49.387 Status: dzVents: Info: Handling events for: "Tuin Verlichting", value: "On"
2020-11-01 12:23:49.420 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-11-01 12:23:52.476 (RFXtrx433XL) Security (Schuurdeur)
2020-11-01 12:23:52.885 (RFXtrx433XL) Security (Schuurdeur)
2020-11-01 12:23:52.655 Status: dzVents: Info: Handling events for: "Schuurdeur", value: "Normal"
2020-11-01 12:23:52.655 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Start internal script: Schuurdeur_Security_new: Device: "Schuurdeur (RFXtrx433XL)", Index: 317
2020-11-01 12:23:52.656 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Processing device-adapter for Tuin Verlichting: Switch device adapter
2020-11-01 12:23:52.656 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Tuin Verlichting (device) State is On
2020-11-01 12:23:52.656 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Schuurdeur (device) State is Normal
2020-11-01 12:23:52.656 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Light/Switch
2020-11-01 12:23:52.656 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Switch
2020-11-01 12:23:52.656 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: {"78"}
2020-11-01 12:23:52.656 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: 2
2020-11-01 12:23:52.657 Status: dzVents: Debug: Schuurdeur Security Tuin Licht: Virtual Dummy
2020-11-01 12:23:52.657 Status: dzVents: Info: Schuurdeur Security Tuin Licht: ------ Finished Schuurdeur_Security_newYou created this for my kitchen light, but I also used it for "Tuin Verlichting".
--[[ dumpMQTT
return
on =
devices =
'Tuin Verlichting'
logging =
level = domoticz.LOG_ERROR, --domoticz.LOG_ERROR
marker = 'Tuin_Verlichting',
data =
lastState =
initial = 'Off',
-- ************** Your settings (when not default) below this line *********************
local MQTTBrokerHost
local MQTTTopic = 'zigbee2mqtt/Tuin_Licht_ct/set'
local mosquitto_pub = '/usr/bin/mosquitto_pub'
local mqttUser = 'mqtt'
local mqttPass = 'xxx'
local initialDimLevel = 200
-- ************** No changes required below this line ************************
local MQTTBrokerHost = MQTTBrokerHost or 'localhost'
local MQTTTopic = MQTTTopic or 'domoticz/out'
local mosquitto_pub = mosquitto_pub or '/usr/bin/mosquitto_pub'
local function osCommand(cmd)
dz.log('Executing Command: ' .. cmd,dz.LOG_DEBUG)
local fileHandle = assert(io.popen(cmd .. ' 2>&1 || echo ::ERROR::', 'r'))
local commandOutput = assert(fileHandle:read('*a'))
local returnTable = {fileHandle:close()}
if commandOutput:find '::ERROR::' then -- something went wrong
dz.log('Error ==>> ' .. tostring(commandOutput:match('^(.*)%s+::ERROR::') or ' ... but no error message ' ) ,dz.LOG_ERROR)
else -- all is fine!!
if returnTable[3] ~= 0 then
dz.log('ReturnCode: ' .. returnTable[3] .. '\ncommandOutput:\n' .. commandOutput, dz.LOG_DEBUG)
return commandOutput,returnTable[3] -- rc[3] contains returnCode
local function composeMQTT(item)
local message = {}
if item.state == 'Off' then
message.state = 'OFF'
dz.data.lastState = 'Off'
message.brightness = 0
message.state = "ON"
if dz.data.lastState == 'Off' then
message.brightness = initialDimLevel
dz.data.lastState = 'On'
item.setLevel( initialDimLevel / 2.55 ).silent()
message.brightness = math.floor(item.level * 2.55 + 0.5)
message.color_temp = 350
message = dz.utils.toJSON(message)
message = message:gsub(',',',\n '):gsub('}','\n } \n'):gsub('{','\n { \n '):gsub(':',' : ')
return ( mosquitto_pub .. ' -d -u ' .. mqttUser .. ' -P ' .. mqttPass .. ' -h '.. MQTTBrokerHost .. ' -t ' .. MQTTTopic .. " -m '" .. message .. "'")
-- Main code
osCommand(composeMQTT(item))
}- waaren
Can you show a bit more log? Not only the first couple of seconds but at least 2 cycles of opening and closing the door ?
Sorry but I don't see how this could be connected. The only thing the new script should do is switching a virtual device to On immediate and Off after 11 seconds. But maybe I am overlooking something ?Maybe this would help you....This is the Script (you have created for me a few months ago) for the "(Virtual Switch) Tuin Verlichting".
gschmidt
Re: Turn on a Group for a certain time [Solved]
Sadly 2 cycles of opening and closing the door have exactly the same LOG messages.waaren wrote: Sunday 01 November 2020 12:46Can you show a bit more log? Not only the first couple of seconds but at least 2 cycles of opening and closing the door ?
Today I have re-placed in the script: device "Tuin Verlichting" with device "Tuin_Licht_ct".
This (dimmer switch) device is automatically created with the "domoticz-zigbee2mqtt-plugin".
It controls the same zigbee2mqtt group as "Tuin Verlichting" does
And this devices has no problem switching off with afterSec(11)....so strange...
I am using this device now instead of "Tuin Verlichting"
