monitor the switch on time [Solved]
Is it possible with Dzvents to display the switch on time in a counter? (Seconds or Minutes)
For example: switch name = 'Woonkamer' and Counter name = 'Tijd_aan’
Re: monitor the switch on time
It's working but the real time does not match with the displayed time. The displayed time is faster then the real time.
Would it be possible to make this in DZvents instead of LUA?
- waaren
Sure it's possible but what is the granularity you need? Does it need to be accurate on the second and should the counting sensor be updated every minute or is it enough to update the counter when "Woonkamer" is switched off?
It would be nice if the time is accurate to the second, but updated when the device turns off no problem.
- waaren
Did you save it as a time triggered Lua script?
- waaren
Can you try below script?
dzVents script to keep track of active device time
local scriptVar = 'Woonkamer' -- must be a switch- or light type of device.
return
on =
devices =
scriptVar,
timer =
'at *:29', -- twice / hour to update timer when device is on for a longer period.
'at *:59',
data =
[scriptVar] =
initial =
['active'] = false,
['lastSet'] = os.time(),
logging =
level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all OK
marker = 'timeKeeper for ' .. scriptVar,
execute = function(dz, item)
local deltaSeconds = os.time() - dz.data[scriptVar].lastSet
local myCounter = dz.devices('Tijd_aan') -- define as counter and set to type: Counter, value Quantity: time, value Units: seconds
if item.isDevice and item.active and not(dz.data[scriptVar].active) then
dz.data[scriptVar].active = true
dz.data[scriptVar].lastSet = os.time()
dz.log('Counting seconds started', dz.LOG_DEBUG)
elseif item.isDevice and dz.data[scriptVar].active and not(item.active) then
dz.data[scriptVar].active = false
dz.log(item.name .. ' has been active for ' .. deltaSeconds .. ' seconds ', dz.LOG_DEBUG)
myCounter.updateCounter(myCounter.counter + deltaSeconds)
elseif item.isTimer and dz.data[scriptVar].active then
dz.log('Updating the counter', dz.LOG_DEBUG)
dz.log('No action needed', dz.LOG_DEBUG)
This works perfectly. One more little question, is it possible to count in seconds, and display in minutes.?
- waaren
Yes but you will loose some accuracy..
change
myCounter.updateCounter(dz.utils.round( ( myCounter.counter * 60 + deltaSeconds ) / 60 , 1 ) )
When the 'Living room' switch is on for 2 x 40 seconds (On off on), the counter should be at 1 minute. The counter will reset to 0 if it has not reached 60 seconds.??
- waaren
No what i meant with loosing accuracy was this:
because of the round function the first time is will be 40/60 = 0.66667 ==> 0.7 minutes and the next time
( 0.7 * 60 + 40 ) / 60 ==> 1.36666 = 1.4
in seconds it would have been 80 / 60 = 1.3333 = 1.3
NB. If you start again and use the same counter you will not see the expected outcome. So better "start fresh"
- waaren
Had another look at it and below version limits the loss of accuracy by keeping track of the total number of seconds in the background.
History:
20201026: Start coding
20201027: Add timer section to update when device is active for a longer period
20201027: Changed updating counter to minutes
20201028: Add keeping track of total seconds to improve accuracy
return
on =
devices =
scriptVar,
timer =
'at *:59',
data =
[scriptVar] =
initial =
['active'] = false,
['activeAt'] = os.time(),
['total'] = 0,
logging =
local deltaSeconds = os.time() - dz.data[scriptVar].activeAt
local myCounter = dz.devices('teller2') -- define as counter and set to type: Counter, value Quantity: time, value Units: seconds
local function managedUpdate(myCounter, deltaSeconds)
if dz.data[scriptVar].total == nil or dz.data[scriptVar].total == 0 then
dz.data[scriptVar].total = myCounter.counter * 60 + deltaSeconds
dz.data[scriptVar].total = dz.data[scriptVar].total + deltaSeconds
local newTotal = dz.utils.round( ( dz.data[scriptVar].total / 60 ), 1 )
myCounter.updateCounter(newTotal)
return newTotal
dz.data[scriptVar].activeAt = os.time()
dz.log(item.name .. ' has been active for ' .. deltaSeconds .. ' seconds since last update.', dz.LOG_DEBUG)
local activeTotalMinutes = managedUpdate(myCounter, deltaSeconds)
dz.log('Overall active time for ' .. item.name .. ' is ' .. activeTotalMinutes .. ' minutes.', dz.LOG_DEBUG)
dz.log('Updated the counter to ' .. activeTotalMinutes .. ' minutes', dz.LOG_DEBUG)
Re: monitor the switch on time [Solved]
Thank you very much.!
The script is already running here ..
