monitor the switch on time  [Solved]
Johan1974
Post by Johan1974 »
Is it possible with Dzvents to display the switch on time in a counter? (Seconds or Minutes)
For example: switch name = 'Woonkamer' and Counter name = 'Tijd_aan’
Johan1974
Re: monitor the switch on time
Post by Johan1974 »
It's working but the real time does not match with the displayed time. The displayed time is faster then the real time.
Would it be possible to make this in DZvents instead of LUA?
Johan1974 wrote: Monday 26 October 2020 22:00 It's working but the real time does not match with the displayed time. The displayed time is faster then the real time.
Sure it's possible but what is the granularity you need? Does it need to be accurate on the second and should the counting sensor be updated every minute or is it enough to update the counter when "Woonkamer" is switched off?
Johan1974
Post by Johan1974 »
It would be nice if the time is accurate to the second, but updated when the device turns off no problem.
Johan1974 wrote: Monday 26 October 2020 22:00 The displayed time is faster then the real time.
Did you save it as a time triggered Lua script?
Johan1974 wrote: Monday 26 October 2020 22:34 It would be nice if the time is accurate to the second, but updated when the device turns off no problem.
Can you try below script?
           dzVents script to keep track of active device time
local scriptVar = 'Woonkamer'  -- must be a switch- or light type of device.
return
    on =
        devices =
            scriptVar,
        timer =
            'at *:29', -- twice / hour to update timer when device is on for a longer period.
            'at *:59',
    data =
        [scriptVar] =
            initial =
                ['active'] = false,
                ['lastSet'] = os.time(),
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all OK
        marker = 'timeKeeper for ' .. scriptVar,
    execute = function(dz, item)
        local deltaSeconds = os.time() - dz.data[scriptVar].lastSet
        local myCounter = dz.devices('Tijd_aan')  -- define as counter and set to type: Counter, value Quantity: time, value Units: seconds
        if item.isDevice and item.active and not(dz.data[scriptVar].active) then
            dz.data[scriptVar].active = true
            dz.data[scriptVar].lastSet = os.time()
            dz.log('Counting seconds started', dz.LOG_DEBUG)
        elseif item.isDevice and dz.data[scriptVar].active and not(item.active) then
            dz.data[scriptVar].active = false
            dz.log(item.name .. ' has been active for ' .. deltaSeconds .. ' seconds ', dz.LOG_DEBUG)
            myCounter.updateCounter(myCounter.counter + deltaSeconds)
        elseif item.isTimer and dz.data[scriptVar].active then
            dz.log('Updating the counter', dz.LOG_DEBUG)
            dz.log('No action needed', dz.LOG_DEBUG)
Johan1974
Post by Johan1974 »
This works perfectly. One more little question, is it possible to count in seconds, and display in minutes.?
Johan1974 wrote: Tuesday 27 October 2020 15:37 This works perfectly. One more little question, is it possible to count in seconds, and display in minutes.?
Yes but you will loose some accuracy..
change
to
myCounter.updateCounter(dz.utils.round( ( myCounter.counter * 60 + deltaSeconds ) / 60 , 1 ) )
at lines 52 and 56
Johan1974
Post by Johan1974 »
When the 'Living room' switch is on for 2 x 40 seconds (On off on), the counter should be at 1 minute. The counter will reset to 0 if it has not reached 60 seconds.??
Johan1974 wrote: Tuesday 27 October 2020 18:24 When the 'Living room' switch is on for 2 x 40 seconds (On off on), the counter should be at 1 minute. The counter will reset to 0 if it has not reached 60 seconds.??
No what i meant with loosing accuracy was this:
because of the round function the first time is will be 40/60 = 0.66667 ==> 0.7 minutes and the next time
( 0.7 * 60 + 40 ) / 60 ==> 1.36666 = 1.4
in seconds it would have been 80 / 60 = 1.3333 = 1.3
NB. If you start again and use the same counter you will not see the expected outcome. So better "start fresh"
Had another look at it and below version limits the loss of accuracy by keeping track of the total number of seconds in the background.
        History:
        20201026: Start coding
        20201027: Add timer section to update when device is active for a longer period
        20201027: Changed updating counter to minutes
        20201028: Add keeping track of total seconds to improve accuracy
return
    on =
        devices =
            scriptVar,
        timer =
            'at *:59',
    data =
        [scriptVar] =
            initial =
                ['active'] = false,
                ['activeAt'] = os.time(),
                ['total'] = 0,
    logging =
        local deltaSeconds = os.time() - dz.data[scriptVar].activeAt
        local myCounter = dz.devices('teller2')  -- define as counter and set to type: Counter, value Quantity: time, value Units: seconds
        local function managedUpdate(myCounter, deltaSeconds)
            if dz.data[scriptVar].total == nil or dz.data[scriptVar].total == 0 then
                dz.data[scriptVar].total = myCounter.counter * 60 + deltaSeconds
                dz.data[scriptVar].total = dz.data[scriptVar].total + deltaSeconds
            local newTotal = dz.utils.round( ( dz.data[scriptVar].total / 60 ), 1 )
            myCounter.updateCounter(newTotal)
            return newTotal
            dz.data[scriptVar].activeAt = os.time()
            dz.log(item.name .. ' has been active for ' .. deltaSeconds .. ' seconds since last update.', dz.LOG_DEBUG)
            local activeTotalMinutes = managedUpdate(myCounter, deltaSeconds)
            dz.log('Overall active time for ' .. item.name .. ' is ' .. activeTotalMinutes .. ' minutes.', dz.LOG_DEBUG)
            dz.log('Updated the counter to ' .. activeTotalMinutes .. ' minutes', dz.LOG_DEBUG)
Johan1974
Re: monitor the switch on time  [Solved]
Post by Johan1974 »
Thank you very much.!
The script is already running here ..
