kazze
Re: Domoticz app 2.0
Post by kazze »
To anyone who might still have this problem (the sudden crash, not the slider affecting other dimmers!): the workaround is to lookup the switch that has a level higher than 100 (oh yes, you will find it) and lower it in the web UI - then restart the app. Magic ! ;-)
More info: https://github.com/domoticz/domoticz-android/issues/603
Johndomo
Post by Johndomo »
galadril wrote: Wednesday 30 September 2020 13:57
Sorry guys, im fixing the dimmers as we speak!
Many thanks for your efforts! However I still experience the same problem? The app was updated via "auto-update".
Should I do more to force that changes take effort?
Thx
John
Johndomo
Post by Johndomo »
I did some more testing. I can see that the working has changed.
Before the update, when I changed the level of dimmer 1, dimmer 2, 3 and 4 reacted. After the update only dimmer 3 reacts.
So things have been improved, but it is not perfect yet...
Luigi87
Post by Luigi87 »
galadril wrote: Thursday 01 October 2020 8:57
Zoonie81 wrote: Sunday 13 September 2020 20:42 I've had the app for a year or two. The latest updates seem to have caused a bug where the slider for a particular z-wave dimmer activates other devices randomly. It can turn on/off other devices or adjust dimming on other devices - randomly every time.
Have you checked the latest update, that should fix the dimmers/sliders
@galadril
Have you also checked the room plans bug?
Everytime i use the app, i need to go the settings first to use the room plans.
Luigi87 wrote: Sunday 23 August 2020 14:07 There seems to be somthing wrong in the app. The switches in the room plans are most of the time not working. I have to switch the switch from slider or buttons in the settings to get the app working again.
There are more people with this:
viewtopic.php?f=37&t=33696
Its in the payed app and in the lite version also!
galadril
Domoticz version: latest
Post by galadril »
Luigi87 wrote: Thursday 15 October 2020 19:26
@galadril
I have no issues with my test setup.
If you like, i can debug against your system if you send me the connection+credential details (viewer account)?
[email protected]
Luigi87
Post by Luigi87 »
galadril wrote: Friday 16 October 2020 14:49
@galadril
[email protected]
Sorry for my late response.
I would love to give you a possibility to debug against my system, but this is nearly impossible due to security measures in my system.
I there a way i can create a debug log?
the bug is there since the last update from I think 5 aug?
"Android app 0.2.232 (7878)"
also described by an other user here:
"Switches not working in "Plans" after force close"
Hope this helps a bit.
sammyke007
Domoticz version: 2022.1
Post by sammyke007 »
Any idea why the sorting doesn't work?
I use the dashboard as the default screen in the app and every time when I sort my devices, they get reset after opening the app 30 minutes or so later?
I already tried messing with the 2 sorting settings, but none of them help.
galadril
Post by galadril »
I;ve updated the app multiple times this weekend, with a lot of crash report fixes..
So i hope that some of your crashes are fixed now (should be)
kniazio
Domoticz version: 3.7243
Post by kniazio »
After the last update, the Domoticz application does not work on Android11. Finds server and devices but after approval everything disappears.
I get a message: Incorect setting detected. Please reconfigure app
I am asking for a link to the penultimate version that worked properly for me.
I will also add that I have a paid application
woppybob
Post by woppybob »
For me the same problem??
samourai47
Post by samourai47 »
Same problem for me on my mi mix2s with android 10
woppybob wrote: Tuesday 03 November 2020 15:59 For me the same problem??
CarstenK
Post by CarstenK »
Same Problem wird Android 10 on Samsung S10
gennapium
Domoticz version: Stable
Post by gennapium »
Same here on Samsung S20 Android 10
Ubuntu server, Raspberry Pi, PiFace 2, RFXCom, Z-wave Stick, Kaku, Sensor
sdmg
Post by sdmg »
Same Problem with Android 10 on Samsung S9
sammyke007
Same here since latest update today. Incorrect settings detected, please reconfigure. Clean reconfigure detects DZ version and devices, but crashes...
Android 11
Verstuurd vanaf mijn IN2013 met Tapatalk
f12004
Post by f12004 »
Same error, here crash on startup with remote, in local it works.
Huawei P20 Android 11
gdmr
Post by gdmr »
Same problem
rtfmjoey
Post by rtfmjoey »
Same issue here; I was greeted with the notification wizard after the update and needed to fill in my server details again. After filling them in, discovery found all devices etc but wheb saving I get an message 'incorrect settings detected' and the wizard starts over.
I've uninstalled the app/removed all cached data and reinstalled but the issue persists.
martk
Post by martk »
Same here...
rira2005
Post by rira2005 »
Same here on Samsung S20+ Android 10
