Live status does not work? Aeotec...
I switched to z-wave for the "live status" / "reporting if the device is ON or OFF"
This doesn't seem to work - All of my devices are Aeotec z-wave+ devices - and i have the aeotec z-stick
But in Domoticz - if I manually go and press a switch to "ON" on a smart switch 6 - Domoticz does not know about the new state. Even if i refresh the page. It doesn't get told.
Can anyone help?
Thanks.
Can anyone help?
Thanks.
Re: Live status does not work? Aeotec...
Anyone?
This is main reason I switched to z-wave
- kiddigital
Look in the Z-Wave console (in Domoticz) to see if the device status reflects the actual situation.
Z-wave is capable of keeping things in sync but it also depends on what is actually implemented in the devices.
First figure out if your z-wave controller (the stick) is aware of the actual state. Otherwise Domoticz can not know this.
I finally managed to check this - thanks for the idea @kiddigital!
In my OpenZWave control panel - all devices are reporting correctly - but in domoticz - some are showing as “ON” when they are off, and they are correctly reported as off in OZW.
What does this mean? And what can I do?
Many thanks.
Many thanks.
- Domoticz version: 2020.2
Yes I have the same issue, it was introduced after the newer OZW1.6.
RPI3B, Z-WAVE AEOTEC GEN5, Zigbee2Mqtt, Xiaomi gateway, GPIO, I2C, 1-wire, DS18B20, P1 meter, Growatt, Buienradar, Harmony hub, Domoticz 2020.2
Any way to fix this anyone?
It kind of takes away the best feature of z-wave.
- kiddigital
Can you provide some screenshots of the OZW panel before and after switching.. same for the corresponding device in Domoticz and post the Domoticz log (preferably with Debug enabled, see startup parameters) of that time-window?binbo wrote:Hi,
Many thanks.
- Treve
- Domoticz version: v4.11474
Is your RPi a 3 or 4?
Aeotec 5 Z-Wave stick knows problems with RPi 4.
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- Arkie
I have the same issues, but running domotiz on my synology.
I even tried to make a fresh install of domoticz, my database and zwave components.
But still facing the issues
Synology DS412+
Philips Hue
Fibaro
Logitech Hamony elite
Foscam 9804 ip cam
RFXtrx433E USB 433.92MHz
ZXT 120 eu AC controller
Heatmiser NEO stat thermostats and Hub
Philips Hue
Fibaro
Foscam 9804 ip cam
- Treve
Aeotec Gen5 stick nows problems with USB 3 ports, it can be solved to use a USB 2 Hub.
This is what I read on Internet.
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- jumbotroll
Have you tested to use the USB 2.0 port in the front of DS412+ ?
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- Arkie
My z-wave stick is in the front usb portHave you tested to use the USB 2.0 port in the front of DS412+ ?
Synology DS412+
Philips Hue
Fibaro
Foscam 9804 ip cam
Philips Hue
Fibaro
Foscam 9804 ip cam
Cheers guys - I will find pi model, usb info, and get logs and stuff when I get home.
But...
I’ve got a feeling it’s not a usb 3 issue, or even a pi model issue - as the z-stick is reporting correct status to OZW
The status is always correct in OZW.
It makes me suspect it’s the link between ozw and domoticz.
But... I’ll get and provide info very soon
Many thanks.
But...
Many thanks.
- Domoticz version: V3_8394
any update on this?
seems multiple people are having this problem (see different topics)
https://domoticz.com/forum/viewtopic.ph ... 7&p=260824
Bit of a late reply - but I’m in same situation.
It’s 100% domoticz issue not talking to OZW.
Z-wave devices report perfect in open z-wave control panel.
In domoticz - it’s not working.
It’s not a usb3 or pi issue - as like I said, ozw is working fine.
