Custom http notification  [Solved]
Varazir
Post by Varazir »
Hello
I have written this and I just like to check if I could have done it in another way or if something is wrong.
Needed a bit mot flexible notification system.
API I'm using is from this site https://joaoapps.com/join/api/
I wised I could encrypt my message as well but then I need some thing i wrote in this script https://github.com/varazir/join/blob/ma ... message.pl ( top modules loaded ) and code
https://github.com/varazir/join/blob/11 ... ge.pl#L325
The API can be used to send command to my phone to execute and then I don't need the title and icon.
dzVents: global_data.lua
	helpers = {
		join = function(dz, deviceId, command, title)
		    icon = "&icon=https://raw.githubusercontent.com/domoticz/domoticz/master/www/images/logo.png"
		    toID = "&deviceId=" .. deviceId
		    if string.match(command, "=:=") then -- if command contains  "=:=" it's should not add title and a icon
		       message = "&text=" .. command
		        message = "&title=" .. title .. "&text=" .. command .. icon
		    message = message .. toID
			message = dz.urlEncode(message)
			dz.notify(message,dz.PRIORITY_NORMAL,dz.NSS_HTTP)
Last edited by Varazir on Wednesday 23 September 2020 21:53, edited 1 time in total.
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
Re: Custom http nonfiction
Varazir wrote: Wednesday 23 September 2020 21:38 I have written this and I just like to check if I could have done it in another way or if something is wrong.
I have no real clue what this is doing but I do see that the parms of dz.notify are not correct.
Varazir
Post by Varazir »
waaren wrote: Wednesday 23 September 2020 21:50
Well it's a over complicated way to use the http notification function in Domoticz :)
I guess I could just use the openurl() as well but then I need to have the API key in the script.
Strange as this command works just fine
dz.notify("Aktuell grupp",control[selectedGroupNumber],dz.PRIORITY_NORMAL,dz.NSS_HTTP)
Varazir
Post by Varazir »
Example could be that if I wish my phone to run a command it sends a message like this
&text=domoticz=:=RunMytask
The Tasker app on my phone will pick up that command and execute what I have set it up to run.
But if I just want a notification on my phone I need something like this
&title=warning&text=Window%20open&icon=UrltoIcon
Varazir wrote: Wednesday 23 September 2020 21:57 Strange as this command works just fine
It might look like its OK but what you send is
subject:"Aktuell grupp"
message:control[selectedGroupNumber]
priority: dz.PRIORITY_NORMAL
sound: dz.NSS_HTTP -- ignored for all subsystems except pushover
extra: nil -- ignored
subsystem: nil -- send to all configured subsystems
And for the notify in you helper
subject:message
message:dz.PRIORITY_NORMAL -- a number
priority: dz.NSS_HTTP -- a string
sound: nil -- ignored for all subsystems except pushover
Varazir
Post by Varazir »
waaren wrote: Wednesday 23 September 2020 22:07
subject:message
I misread the wiki, is there a way to only send a subject or a message ?
just add a extra , ?
Varazir wrote: Thursday 24 September 2020 18:52 I misread the wiki, is there a way to only send a subject or a message ?
Subject is the only required parameter. All other ones can be nil (implicit or explcit)
so
domoticz.notify('subject') -- OK will send message to all configured subsystems
domoticz.notify('subject',nil,nil,nil,nil,dz.NSS_PUSHOVER) -- OK will send message to Pushover
domoticz.notify('subject',,,,,dz.NSS_PUSHOVER) -- NOT OK (lua does not recognize ,,)
Varazir
Post by Varazir »
waaren wrote: Thursday 24 September 2020 20:47
so
Okay the wiki wasn't that clear about that.
I got it half way now.
This is the original url I have in the https notification settings
https://joinjoaomgcd.appspot.com/_ah/api/messaging/v1/sendPush?apikey=#FIELD1&title=#SUBJECT&text=#MESSAGE&deviceId=#TO&icon=#FIELD2
Works just fine but if I change it to
https://joinjoaomgcd.appspot.com/_ah/api/messaging/v1/sendPush?apikey=#FIELD1#SUBJECT
Nothing happens, I don't get any errors in the log.
The current script
	helpers = {
		        title = dz.urlEncode(title)
		        command = dz.urlEncode(command)
			dz.notify(message,nil,nil,nil,dz.PRIORITY_NORMAL,dz.NSS_HTTP)
I call it like this:
dz.helpers.join(dz,"group.all","domoticz","SovrumGN")
It looks okay in the log as far as I can understand it. would love the to see the whole https command
Varazir wrote: Thursday 24 September 2020 21:59 It looks okay in the log as far as I can understand it. would love the to see the whole https command
I guess I miss your point but if your objective is to send a url why taking the detour via dz.notify?
You might want to try the domoticz.openURL() method instead.
Varazir
Post by Varazir »
Been thinking of that. My concern is to have the api key in the script.
Skickat från min EML-L29 via Tapatalk
Varazir wrote:Been thinking of that. My concern is to have the api key in the script.
You could store the key in a domoticz uservariable and retrieve it during script execution. You might want to use base64 code/decode for that to ensure the password is not direct readable.
(or encryption / decryption if you really want to make it fancy)
Varazir
Post by Varazir »
waaren wrote: Friday 25 September 2020 9:30
That is a solution, I'll tak a look at that.
Do Domoticz have PBKDF2, CBC/AES encryption support ?
Varazir wrote: Sunday 27 September 2020 9:44 That is a solution, I'll tak a look at that.
Don't know but dzVents has not natively. You could use external Lua to do that but for this purpose I guess you could also use
dz.utils.toBase64 / dz.utils.fromBase64 and add your own key to the coded string before storing (and remove it before using) to obscure it even more.
Varazir
Post by Varazir »
waaren wrote: Sunday 27 September 2020 11:49
Hmm okay, is there a way to call a external perl script and get value back ?
Varazir wrote: Sunday 27 September 2020 18:01 Is there a way to call a external perl script and get value back ?
Yes if you are on the latest Beta you can use
returnValue, returnCode = dz.utils.osCommand('perl /pathToScript/scriptName.pl')
If on an older version
use
        local function osCommand(cmd)
            dz.log('Executing Command: ' .. cmd,dz.LOG_DEBUG)
            local fileHandle = assert(io.popen(cmd))
            local commandOutput = assert(fileHandle:read('*a'))
            local returnTable = {fileHandle:close()}
            dz.log('ReturnCode: ' .. returnTable[3] .. '\ncommandOutput:\n' .. commandOutput, dz.LOG_DEBUG)
            return commandOutput,returnTable[3] -- rc[3] contains returnCode
returnValue, returnCode = osCommand('perl /pathToScript/scriptName.pl'
Varazir
Post by Varazir »
waaren wrote: Sunday 27 September 2020 22:17 Yes.
Ya I'm using beta
Something like this then ?
	-- global persistent data
	data = {
		-- myGlobalVar = { initial = 12 }
	-- global helper functions
	helpers = {
		    JoinKey = "apikey=" .. dz.variables('JoinKey')
		    JoinURL = "https://joinjoaomgcd.appspot.com/_ah/api/messaging/v1/sendPush?"
		    returnMessage, returnCode = dz.utils.osCommand('perl /opt/join/encode.pl' .. message )
		    message = JoinKey .. returnMessage .. toID
		    dz.openurl( JoinURL .. message )
			-- dz.notify(message,nil,nil,nil,dz.PRIORITY_NORMAL,dz.NSS_HTTP)
Varazir wrote: Monday 28 September 2020 14:22
Ya I'm using beta
Some typos in your code... See my remarks
return
	helpers = {
		    JoinKey = "apikey=" .. dz.variables('JoinKey').value -- You only need the value; not the complete variable object
		        title = dz.utils.urlEncode(title) -- urlEncode is a method in utils
		        command = dz.utils.urlEncode(command)
		    returnMessage, returnCode = dz.utils.osCommand('perl /opt/join/encode.pl ' .. message ) -- mind the space before the message parm
Varazir
Post by Varazir »
waaren wrote: Monday 28 September 2020 15:58
Ya I'm using beta
return
	helpers = {
Hmm, I got stuck
I'm getting
2020-09-30 19:05:25.258 Error: dzVents: Error: (3.0.12) An error occurred when calling event handler test
2020-09-30 19:05:25.258 Error: dzVents: Error: (3.0.12) ...moticz/scripts/dzVents/generated_scripts/global_data.lua:31: attempt to call a nil value (field 'osCommand'
Varazir wrote: Wednesday 30 September 2020 19:09 Hmm, I got stuck
I'm getting
dz.utils.osCommand is available in dzVents versions >= 3.0.13 (domoticz version 2002.2 build 12394) If you cannot upgrade to that Beta version yet you will have to include the function I posted earlier (see below to see how.
return
    helpers =
            returnMessage, returnCode = osCommand('perl /opt/join/encode.pl ' .. message ) -- mind the space before the message parm
Varazir
Post by Varazir »
I'm getting
return
    helpers =
I'm running
About Domoticz
Version: 2020.2 (build 12393)
Build Hash: 46660897d-modified
Compile Date: 2020-09-21 13:52:00
dzVents Version: 3.0.12
Python Version: 3.7.3 (default, Jul 25 2020, 13:03:44) [GCC 8.3.0]
See it now, well I have to wait for next beta release.
