Check if value changed  [Solved]
Jumper3126
Post by Jumper3126 »
the lastupdate feature of DZventz is enormously handy, but for a new script I would like to know when a device (integer value) has changed. This specific devices is updated every minute but also if the value didn't change. Is this possible somehow or do i need to work with persistent data to store and compare?
Re: Check if value changed
Jumper3126 wrote: Thursday 10 September 2020 22:18 the lastupdate feature of DZventz is enormously handy, but for a new script I would like to know when a device (integer value) has changed. This specific devices is updated every minute but also if the value didn't change. Is this possible somehow or do i need to work with persistent data to store and compare?
Yes you need to work with persistent data or a domoticz uservariable to compare current state with a previous state if your device is not a dimmer or selector. For these types you can use the lastLevel attribute.
Jumper3126
Re: Check if value changed  [Solved]
Thanks for that very quick respons waaren!
Patricen
Domoticz version: Beta rel
Post by Patricen »
This looks like it could solve my issue. I would like to trigger an event on sudden dewpoint rise. Do you have any example showing this?
using my algorithmic language it would look like
If sensor above stove's dewpoint rose more than 1°C since last update
Set cooker hood to "on"
Patricen wrote: Wednesday 23 September 2020 16:27 This looks like it could solve my issue. I would like to trigger an event on sudden dewpoint rise. Do you have any example showing this?
Something like below ?
return
    on =
        devices =
            'myDewpointSensor', -- change to name of Sensor
    data =
        lastValue =
            initial = 0,
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when script is tested and OK
        marker = 'dewPoint-rise',
    execute = function(dz, item)
        cookerHood = dz.devices('cooker hood') -- change to name of Cooker Hood device
        dz.log('\nDevicename: ' .. item.name .. ', nValue: ' .. item.nValue .. ', sValue: ' .. item.sValue ..
               '\nDevicetype: ' .. item.deviceType .. ', deviceSubType: ' .. item.deviceSubType ..
               '\nlastValue: ' .. dz.data.lastValue, dz.LOG_DEBUG )
        if item.dewPoint >=  dz.data.lastValue + 1 then
            cookerHood.switchOn().checkFirst()
        if dz.data.lastValue ~= item.dewPoint then
            dz.data.lastValue = item.dewPoint
Patricen
Post by Patricen »
Thanks a lot, I'll try this and keep you updated
Patricen
Post by Patricen »
waaren wrote: Wednesday 23 September 2020 22:54
return
    on =
        devices =
    data =
        lastValue =
            initial = 0,
    logging =
Waahh!! Brilliant, this works like a charm, thanks!
