Check if value changed [Solved]
Jumper3126
the lastupdate feature of DZventz is enormously handy, but for a new script I would like to know when a device (integer value) has changed. This specific devices is updated every minute but also if the value didn't change. Is this possible somehow or do i need to work with persistent data to store and compare?
- waaren
Re: Check if value changed
Yes you need to work with persistent data or a domoticz uservariable to compare current state with a previous state if your device is not a dimmer or selector. For these types you can use the lastLevel attribute.Jumper3126 wrote: Thursday 10 September 2020 22:18 the lastupdate feature of DZventz is enormously handy, but for a new script I would like to know when a device (integer value) has changed. This specific devices is updated every minute but also if the value didn't change. Is this possible somehow or do i need to work with persistent data to store and compare?
Jumper3126
Re: Check if value changed [Solved]
Thanks for that very quick respons waaren!
Patricen
- Domoticz version: Beta rel
This looks like it could solve my issue. I would like to trigger an event on sudden dewpoint rise. Do you have any example showing this?
using my algorithmic language it would look like
If sensor above stove's dewpoint rose more than 1°C since last update
Set cooker hood to "on"
- waaren
Something like below ?Patricen wrote: Wednesday 23 September 2020 16:27 This looks like it could solve my issue. I would like to trigger an event on sudden dewpoint rise. Do you have any example showing this?
return
on =
devices =
'myDewpointSensor', -- change to name of Sensor
data =
lastValue =
initial = 0,
logging =
level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when script is tested and OK
marker = 'dewPoint-rise',
execute = function(dz, item)
cookerHood = dz.devices('cooker hood') -- change to name of Cooker Hood device
dz.log('\nDevicename: ' .. item.name .. ', nValue: ' .. item.nValue .. ', sValue: ' .. item.sValue ..
'\nDevicetype: ' .. item.deviceType .. ', deviceSubType: ' .. item.deviceSubType ..
'\nlastValue: ' .. dz.data.lastValue, dz.LOG_DEBUG )
if item.dewPoint >= dz.data.lastValue + 1 then
cookerHood.switchOn().checkFirst()
if dz.data.lastValue ~= item.dewPoint then
dz.data.lastValue = item.dewPoint
}Debian buster, bullseye on RPI-4, Intel NUC.
Patricen
Thanks a lot, I'll try this and keep you updated
Patricen
waaren wrote: Wednesday 23 September 2020 22:54Something like below ?Patricen wrote: Wednesday 23 September 2020 16:27 This looks like it could solve my issue. I would like to trigger an event on sudden dewpoint rise. Do you have any example showing this?
return { on = { devices = { 'myDewpointSensor', -- change to name of Sensor }, }, data = { lastValue = { initial = 0, }, }, logging = { level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when script is tested and OK marker = 'dewPoint-rise', }, execute = function(dz, item) cookerHood = dz.devices('cooker hood') -- change to name of Cooker Hood device dz.log('\nDevicename: ' .. item.name .. ', nValue: ' .. item.nValue .. ', sValue: ' .. item.sValue .. '\nDevicetype: ' .. item.deviceType .. ', deviceSubType: ' .. item.deviceSubType .. '\nlastValue: ' .. dz.data.lastValue, dz.LOG_DEBUG ) if item.dewPoint >= dz.data.lastValue + 1 then cookerHood.switchOn().checkFirst() end if dz.data.lastValue ~= item.dewPoint then dz.data.lastValue = item.dewPoint end end }
Waahh!! Brilliant, this works like a charm, thanks!
